查看: 4536|回复: 5
[求助] calibre svrf相关问题求助
发表于 2017-5-18 16:35:47 | 显示全部楼层 |阅读模式
悬赏300资产未解决
做一个dfm的课程设计,要求用calibre工具计算print之后的line-end pullback。之前从来没写过calibre相关的script,有没有大神能指导一下这个要怎么写,并且怎么在calibre工具里运行?
问了一下老师说,大概思路是用shrink命令,shrink layer之后做AND取line-end再做处理。
Blue one is original layer and red one is printed layer (print after OPC).
Calculate the length difference at all line-ends (wire end).Pull back = difference between original layer and printed layer at wire end.
Sorry can't type Chinese.
Any SVRF tutorial would help.I used c++ do coordinates selected and capture for now.
I am stuck in another related question: how to use SVRF calculate critical area.
发表于 2017-5-22 12:52:38 | 显示全部楼层
最后画个示意图,说详细点
发表于 2017-5-23 15:51:42 | 显示全部楼层
详细解释下
发表于 2017-5-23 16:13:17 | 显示全部楼层
有个图示意比较好, 不知道你说得 line-end pullback 是什么意思
 楼主| 发表于 2017-5-27 04:24:23 | 显示全部楼层
A little bit detail updated.
发表于 2018-5-15 18:50:13 | 显示全部楼层
GOOD MATERIAL
GMT+8, 2025-12-25 06:54 , Processed in 0.016064 second(s), 4 queries , Gzip On, Redis On.
