查看: 5580|回复: 21
[求助] 请上传Design of a process and temperature compensated CMOS ring osc谢谢。
发表于 2017-5-11 10:23:43 | 显示全部楼层 |阅读模式
请上传Design and realization of a process and temperature compensated CMOS ring oscillator 谢谢。
Date of Conference: 16-18 May 2012
http://ieeexplore.ieee.org/document/6254225/
Abstract:
This paper describes the design and realization of a process and temperature compensated CMOS ring oscillator. The proposed circuit employs a current-starved ring oscillator with a compensated bias circuit, which generates an adaptive control voltage to maintain a fixed oscillation frequency against temperature and process variations. Simulation results using process parameters from a 0.18-μm CMOS technology and 1.8-V power supply voltage showed that the worst-case frequency variation of 4.49% and 2.29% could be obtained at the oscillation frequencies of 100 MHz and 150 MHz, respectively, over the temperature range of - 40°C to 125°C. The overall circuit consumes 437μW at 100MHz and 537μW at 150MHz.
发表于 2017-5-11 10:52:02 | 显示全部楼层
谢谢分享
发表于 2017-5-11 13:15:40 | 显示全部楼层
见附件
panyai2012.pdf
283.8 KB, 下载次数: 165 , 下载积分: 资产 -2 信元, 下载支出 2 信元
发表于 2017-5-11 15:53:30 | 显示全部楼层
thanks for your sharing!
发表于 2017-5-11 19:43:09 | 显示全部楼层
thanks
发表于 2017-5-12 01:01:10 | 显示全部楼层
非常感謝~~~~
发表于 2017-5-12 08:47:55 | 显示全部楼层
thanks
发表于 2017-5-12 15:58:29 | 显示全部楼层
thanks~
 楼主| 发表于 2017-5-15 10:33:08 | 显示全部楼层
回复 3# elwin_huxr
非常感謝~~~~
发表于 2018-2-4 03:57:59 | 显示全部楼层
Thanks
站长推荐 上一条 /3 下一条
GMT+8, 2025-9-11 05:17 , Processed in 0.021958 second(s), 4 queries , Gzip On, Redis On.
