查看: 2332|回复: 2
[求助] map出现下面的错误,之前能够编译通过的,现在就这样了。
发表于 2017-4-19 20:39:16 | 显示全部楼层 |阅读模式
ERRORack:2412 - The number of logical LUT blocks exceeds the capacity for the target device.
ERROR:Map:237 - The design is too large to fit the device.  Please check the Design Summary section to see which resource requirement for
   your design exceeds the resources available in the device. Note that the number of slices reported may not be reflected accurately as
   their packing might not have been completed.
发表于 2017-4-19 20:45:45 | 显示全部楼层
资源不够了。。。是不是设计做改动了,或者一些编译选项修改了比如策略那些?
 楼主| 发表于 2017-4-20 19:16:13 | 显示全部楼层
回复 2# 大宝好好
   没有啊,啥都没动,很奇怪,还是原来的工程的基础上加的ucf
GMT+8, 2025-12-30 15:02 , Processed in 0.016699 second(s), 4 queries , Gzip On, Redis On.
