查看: 27683|回复: 147
LDO IEEE论文合集part4
发表于 2007-6-14 18:53:40 | 显示全部楼层 |阅读模式
LDO IEEE论文合集
我手上有许多LDO的资料,大约几百兆,发不完,有需要的朋友请留个联系方式吧
A 150mA Low Noise, High PSRR Low-Dropout.pdf
A Capacitor-Free CMOS Low-Dropout Regulator.pdf
A Current-Mode DC-DC Buck Converter with High Stability Independent of Load and Supply Voltage.pdf
A frequency compensation scheme for LDO voltage regulators.pdf
A Linear LDO Regulator with Modified NMCF Frequency Compensation Independent of Off-chip Capacitor and ESR.pdf
A Low Dropout, CMOS Regulator with High PSR over Wideband Frequencies.pdf
A Low Noise, High Power Supply Rejection Low Dropout Regulator for Wireless System-on-Chip Applications.pdf
A Low-dropout Regulator with Unconditional.pdf
A Low-Noise Low-Drift Transducer ADC.pdf
A low-voltage, low quiescent current, low drop-out regulator.pdf
a multi-mode ldo-based .pdf
A Power Efficient and Fast Transient Response Low Drop-Out Regulator in Standard CMOS Process.pdf
A robust frequency compensation scheme for ldo regulators.pdf
All CMOS Low Drop-Out Regulator with Large Supply Currents for System using Li-ion Battery.pdf
Analysis and design of monolithic,High PSR, Linear Regulators for soc applications.pdf
Analysis and Design of Voltage Controlled Current Source for LDO Frequency Compensation.pdf
Analysis of low-dropout regulator topologies for low-voltage regulation.pdf
ldo.part07.rar
1.81 MB, 下载次数: 490 , 下载积分: 资产 -2 信元, 下载支出 2 信元
ldo.part08.rar
1.38 MB, 下载次数: 469 , 下载积分: 资产 -2 信元, 下载支出 2 信元
 楼主| 发表于 2007-6-14 19:01:55 | 显示全部楼层
LDO IEEE的论文我还有好多,但是上传速度太慢,只能先发这些了
 楼主| 发表于 2007-6-14 19:04:16 | 显示全部楼层
有谁需要的话我还可以通过email或其他方式发给你们,留个联系方式就可以了
发表于 2007-6-14 19:08:19 | 显示全部楼层
赶上了首班车了,LZ给我来一份吧,谢谢!
vidarson2002@hotmail.com
回复 支持 0 反对 1
发表于 2007-6-14 19:19:05 | 显示全部楼层
谢谢!支持,鼓励。楼主挑好的上传吧!
发表于 2007-7-6 23:07:34 | 显示全部楼层
支持楼主上传
发表于 2007-7-7 12:57:36 | 显示全部楼层
好人啊,楼主给我也发一份lube.wei@gmail.com
发表于 2007-7-10 14:00:38 | 显示全部楼层
多谢搂主,也给我一份吧。
迫切需要,谢谢!!!
hawk3130@126.com
发表于 2007-7-12 16:22:00 | 显示全部楼层
thanks
发表于 2007-9-4 18:49:21 | 显示全部楼层
好东东
支持
GMT+8, 2025-12-28 23:56 , Processed in 0.023033 second(s), 7 queries , Gzip On, Redis On.
