查看: 4141|回复: 3
[求助] 时序分析时出现大量removal违例,求解决办法
发表于 2017-3-25 15:16:18 | 显示全部楼层 |阅读模式
时序分析时出现大量removal违例,部分违例如下所示:
removal
   Endpoint                                                  Slack
   uut_filter3_v6/M4/mac8_reg_40_/RN                         -1.72  (VIOLATED)
   uut_filter3_v6/M4/mac7_reg_40_/RN                         -1.72  (VIOLATED)
   uut_filter3_v6/M4/mac8_reg_41_/RN                         -1.70  (VIOLATED)
   uut_filter3_v6/M4/mac7_reg_39_/RN                         -1.70  (VIOLATED)
   uut_filter3_v6/M4/mac7_reg_38_/RN                         -1.70  (VIOLATED)
   uut_filter3_v6/M4/mac8_reg_39_/RN                         -1.70  (VIOLATED)
   uut_filter3_v6/M4/mac8_reg_38_/RN                         -1.70  (VIOLATED)
   uut_filter3_v6/M4/mac7_reg_37_/RN                         -1.70  (VIOLATED)
   uut_filter3_v6/M4/mac7_reg_36_/RN                         -1.70  (VIOLATED)
   uut_filter3_v6/M4/mac6_reg_18_/RN                         -1.70  (VIOLATED)
   uut_filter3_v6/M4/mac6_reg_17_/RN                         -1.70  (VIOLATED)
   uut_filter3_v6/M4/mac8_reg_34_/RN                         -1.64  (VIOLATED)
   uut_filter3_v6/M4/mac8_reg_35_/RN                         -1.64  (VIOLATED)
   uut_filter3_v6/M4/mac7_reg_33_/RN                         -1.64  (VIOLATED)
   uut_filter3_v6/M4/mac7_reg_35_/RN                         -1.64  (VIOLATED)
   uut_filter3_v6/M4/mac7_reg_34_/RN                         -1.64  (VIOLATED)
   uut_filter3_v6/M4/mac8_reg_37_/RN                         -1.64  (VIOLATED)
   uut_filter3_v6/M4/mac8_reg_36_/RN                         -1.64  (VIOLATED)
   uut_filter3_v6/M4/mac8_reg_33_/RN                         -1.64  (VIOLATED)
   uut_filter3_v6/M4/mac7_reg_32_/RN                         -1.64  (VIOLATED)
   uut_filter3_v6/M4/mac7_reg_31_/RN                         -1.64  (VIOLATED)
   uut_filter3_v6/M4/mac6_reg_15_/RN                         -1.64  (VIOLATED)
   uut_filter3_v6/M4/mac6_reg_16_/RN                         -1.64  (VIOLATED)
   uut_filter3_v6/M4/mac4_reg_34_/RN                         -1.63  (VIOLATED)
   uut_filter3_v6/M4/mac9_reg_33_/RN                         -1.63  (VIOLATED)
   uut_filter3_v6/M4/mac2_reg_31_/RN                         -1.63  (VIOLATED)
   uut_filter3_v6/M4/tap22_reg_10_/RN                        -1.63  (VIOLATED)
   uut_filter3_v6/M4/tap21_reg_10_/RN                        -1.63  (VIOLATED)
   uut_filter3_v6/M4/tap22_reg_9_/RN                         -1.63  (VIOLATED)
   uut_filter3_v6/M4/mac1_reg_37_/RN                         -1.61  (VIOLATED)
   uut_filter3_v6/M4/mac5_reg_37_/RN                         -1.61  (VIOLATED)
   uut_filter3_v6/M4/mac6_reg_38_/RN                         -1.61  (VIOLATED)
   uut_filter3_v6/M4/mac8_reg_32_/RN                         -1.60  (VIOLATED)
   uut_filter3_v6/M4/mac7_reg_30_/RN                         -1.60  (VIOLATED)
   uut_filter3_v6/M4/mac7_reg_27_/RN                         -1.60  (VIOLATED)
   uut_filter3_v6/M4/mac7_reg_29_/RN                         -1.60  (VIOLATED)
   uut_filter3_v6/M4/mac8_reg_30_/RN                         -1.60  (VIOLATED)
   uut_filter3_v6/M4/mac7_reg_28_/RN                         -1.60  (VIOLATED)
   uut_filter3_v6/M4/mac8_reg_31_/RN                         -1.60  (VIOLATED)
   uut_filter3_v6/M4/mac6_reg_11_/RN                         -1.60  (VIOLATED)
   uut_filter3_v6/M4/mac6_reg_10_/RN                         -1.60  (VIOLATED)
   uut_filter3_v6/M4/mac6_reg_9_/RN                          -1.60  (VIOLATED)
   uut_filter3_v6/M4/mac6_reg_12_/RN                         -1.60  (VIOLATED)
   uut_filter3_v6/M4/mac7_reg_26_/RN                         -1.60  (VIOLATED)
   uut_filter3_v6/M4/mac6_reg_14_/RN                         -1.60  (VIOLATED)
   uut_filter3_v6/M4/mac6_reg_13_/RN                         -1.60  (VIOLATED)
   uut_filter3_v6/M4/mac6_reg_36_/RN                         -1.59  (VIOLATED)
   uut_filter3_v6/M4/mac6_reg_33_/RN                         -1.59  (VIOLATED)
发表于 2017-3-26 11:04:35 | 显示全部楼层
分析你的复位时异步复位还是同步复位,复位采样出错一拍对你的设计会不会有影响,如果没有,那么这些复位的violation可以false_path
 楼主| 发表于 2017-3-27 09:30:43 | 显示全部楼层
回复 2# 出尘入世
   我的复位是异步复位,跟时钟没有关系,现在已设置为false_path,谢谢您
发表于 2017-3-27 13:58:57 | 显示全部楼层
从你的报告中可以看到,这个虽然是异步复位但是代码中这样处理是有问题的,应该是把异步复位信号先同步到对应的时钟域下再使用。
GMT+8, 2025-12-25 21:02 , Processed in 0.015566 second(s), 4 queries , Gzip On, Redis On.
