查看: 15713|回复: 5
[求助] ERROR :Analysis was skipped due to inability to compute operating point.
发表于 2017-2-20 10:52:54 | 显示全部楼层 |阅读模式
频段较高,无源部分sonnet 电磁仿真,有源部分cadence spectre提参,然后整体仿真,现在做cadence和sonnet联合仿真,出现这个问题: QQ截图20170220105223.png Error found by spectre during DC analysis, during info `dcOpInfo'.
    ERROR (SPECTRE-16041): Analysis was skipped due to inability to compute operating point.
Analysis `dcOpInfo' was terminated prematurely due to an error.
modelParameter: writing model parameter values to rawfile.
element: writing instance parameter values to rawfile.
outputParameter: writing output parameter values to rawfile.
designParamVals: writing netlist parameters to rawfile.
primitives: writing primitives to rawfile.
subckts: writing subcircuits to rawfile.
Warning from spectre.
    WARNING (SPECTRE-16707): Only tran supports psfxl format, result of other analyses will be in psfbin format.
DC Analysis `dcOp'
Error found by spectre during DC analysis `dcOp'.
Analysis `dcOp' was terminated prematurely due to an error.
dcOpInfo: writing operating point information to rawfile.
还请不吝赐教!!!万分感谢!!!
 楼主| 发表于 2017-2-21 16:39:54 | 显示全部楼层
问题解决了,mark一下,是因为我sonnet仿真的时候没有添加DC扫描,因此联合仿真时扫描DC会报错,无法收敛,找不到直流点;
回复 支持 2 反对 0
发表于 2019-9-20 09:56:31 | 显示全部楼层
楼主大佬,那个waringnly tran supports psfxl format,result of other analyses will be in psfbin 你是怎么解决的?
发表于 2020-5-23 20:34:33 | 显示全部楼层
楼主问一下,你说的mark是什么操作,
回复 支持 3 反对 0
发表于 2023-8-5 15:33:31 来自手机 | 显示全部楼层
能不能详细说一下怎么mark?
发表于 2023-12-20 13:53:54 | 显示全部楼层
可以详细说明一下怎么mark吗?
GMT+8, 2025-10-4 23:15 , Processed in 0.017518 second(s), 7 queries , Gzip On, Redis On.
