查看: 1226|回复: 0
[求助] help in P and R in IC compiler, internal clocks
发表于 2017-2-9 00:55:11 | 显示全部楼层 |阅读模式
I have a module, there is not a clock pin to/from the module, but one sub-module generates quite a few clocksignals, as low as 10MHz, but as high as 5GHz, to the other sub-modules.
Please help:
1) how do I handle those internal clock signals in IC compiler?
2) the module was synthesized hierarchically as whole, without any constraints for those clocks, should I go back
synthesize them, those receiving those high speed clocks one by one?
GMT+8, 2025-10-20 05:32 , Processed in 0.016779 second(s), 4 queries , Gzip On, Redis On.
