查看: 1935|回复: 2
[求助] IC compiler route not cover pinsing
发表于 2017-2-1 06:07:58 | 显示全部楼层 |阅读模式
I used M2 pins in in design planning stage, or floor planning stage:- resetn + NET resetn
  + DIRECTION input
  + PORT
  + LAYER M2 ( 0 0 ) ( 70 70 )
  + PLACED ( 735.00 0.00 ) N ;
then finished everything for tsmc 28nm node place and route in IC compiler.
but I noticed, in the finished database,  that most often than not, the M2 metal would not cover the M2 pin
which is a 0.07X0.07 square.
Since I use M2 label, (M2, pin) to label the center of the pin, the problem would cause the unattached label, and fails LVS in
calibre run.
Please help
发表于 2017-2-1 09:00:51 | 显示全部楼层
maybe the boundary constraints has caused this .
besides , M2 pin is too low layer
 楼主| 发表于 2017-2-2 01:47:28 | 显示全部楼层
回复 2# yangzai1236
   thank you, yangzai1236, for the reply. I will try those.one question: why IC compiler did not output gds with my original pin shape M2 (0 0) (70 70)?
the strange things are that not every case outputing the same way.
GMT+8, 2025-10-20 05:44 , Processed in 0.015282 second(s), 4 queries , Gzip On, Redis On.
