查看: 2128|回复: 3
[求助] IC compiler P and R not DRC clean
发表于 2017-1-7 08:41:41 | 显示全部楼层 |阅读模式
ICC reports DRC clean for tsmc 28nm tech node, but calibre run in cadence still generated a lot of DRC errors.here are summary
RULECHECK G.4:M2i ........................................ TOTAL Result Count = 30  (30)
RULECHECK PO.W.20__PO.S.44 ............................... TOTAL Result Count = 124 (124)
RULECHECK M2.W.1 ......................................... TOTAL Result Count = 10  (10)
RULECHECK M2.W.4 ......................................... TOTAL Result Count = 10  (10)
RULECHECK M2.S.7 ......................................... TOTAL Result Count = 208 (208)
RULECHECK M2.S.8 ......................................... TOTAL Result Count = 22  (22)
RULECHECK M2.S.12 ........................................ TOTAL Result Count = 43  (43)
RULECHECK M2.A.2 ......................................... TOTAL Result Count = 177 (177)
RULECHECK M2.A.3 ......................................... TOTAL Result Count = 1   (1)
please help,
发表于 2017-1-11 15:58:21 | 显示全部楼层
同问?
发表于 2017-1-13 13:43:22 | 显示全部楼层
ICC用的是tf,calibre用的是foundary提供的runset去check drc的。如果flow正常的话,icc一般正常跑出来的DRC应该接近于甚至要比calibre悲观点。不过从你的结果上看,有几个问题:
1.边边角角的地方可能存在一些filler没插的情况或者是边界上没有endcap;
2.M2.S.7 这个DRC有点多,是不是绕线时,一些setting有问题,比如std cell 出pin相关的设置;分析下改下setting应该就好了;
这两个问题解决了,DRC就很少了。
 楼主| 发表于 2017-1-14 06:39:32 | 显示全部楼层
回复 3# seuxiaoj
thank you for your suggestions. In my case, I felt that the M2 spacing errors are from power/ground networking creation. I did use create ring and create straps to build power/ground network, any idea if I missed some necessary steps
Many thanks.
GMT+8, 2025-9-14 07:10 , Processed in 0.013262 second(s), 5 queries , Gzip On, Redis On.
