查看: 3840|回复: 3
[求助] RTL logic design help
发表于 2016-12-31 02:53:29 | 显示全部楼层 |阅读模式
my design have these code:
`define BYTE_BURT7   3'b111
output    [7:0]    parallel_mon,
reg    [9:0]    select;
reg    [2:0]    byteselect;
but I got the following with ncverilog run:
ncvlog: *E,NOTPAR (shiftreg4chipB.v,561|16): Illegal operand for constant expression [4(IEEE)].
  if (select[9] & (byteselect == `BYTE_BURT7 )) assign parallel_mon = reg_data[693:686];
I don't know what could have gone wrong
Please help
发表于 2017-6-15 22:22:16 | 显示全部楼层
`parallel_mon` is `reg` type or `wire` type?
It seems to be `reg` so that you tried to use if statement to assign the value.
You just need to remove the `assign` in the code. The value assignment in
always block does not need any `assign` in front of that.
发表于 2017-6-16 14:37:53 | 显示全部楼层
change  if (select[9] & (byteselect == `BYTE_BURT7 ))    to   if (select[9] && (byteselect == `BYTE_BURT7 )) .   it is logic and
发表于 2017-6-17 05:04:34 | 显示全部楼层
how come "assign" is used in this way? try :
assign parallel_mon = ((select[9] && (byteselect == `BYTE_BURT7 ))) ? reg_data[693:686] : something else
GMT+8, 2025-12-29 22:44 , Processed in 0.016657 second(s), 4 queries , Gzip On, Redis On.
