查看: 2604|回复: 3
[求助] XILINX fifo核调用问题
发表于 2016-12-23 12:55:19 | 显示全部楼层 |阅读模式
工程利用ISE自带的FIFO核将32位的并行数据经过缓存以单bit输出,读写时钟相同,首先将32位数据经过FIFO1变成8位输出,再将8位数据经过FIFO2变成1位输出,对程序仿真结果显示正确,但是下载到板子测试的时候,却得不到输出数据,求大神帮忙看看是否是代码的问题呢?多谢啦
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
use IEEE.STD_LOGIC_unsigned.ALL;
use ieee.std_logic_arith.all;
USE ieee.numeric_std.ALL;
-- Uncomment the following library declaration if using
-- arithmetic functions with Signed or Unsigned values
--use IEEE.NUMERIC_STD.ALL;
-- Uncomment the following library declaration if instantiating
-- any Xilinx primitives in this code.
--library UNISIM;
--use UNISIM.VComponents.all;
entity transmit is
PORT(
clk_100M      : in std_logic;
-- clk_100M       : in std_logic;
nrst          : in std_logic;
fifo_data_in  : in std_logic_vector(31 downto 0);
empty_1       : in std_logic;
reden         : out std_logic;
fifo_data_out : out std_logic_vector(0 downto 0)
end transmit;
architecture Behavioral of transmit is
COMPONENT fifo1
  PORT (
    rst    : IN STD_LOGIC;
    wr_clk : IN STD_LOGIC;
    rd_clk : IN STD_LOGIC;
    din    : IN STD_LOGIC_VECTOR(31 DOWNTO 0);
    wr_en  : IN STD_LOGIC;
    rd_en  : IN STD_LOGIC;
    dout   : OUT STD_LOGIC_VECTOR(7 DOWNTO 0);
    full   : OUT STD_LOGIC;
    empty  : OUT STD_LOGIC
END COMPONENT;
COMPONENT fifo2
  PORT (
    rst : IN STD_LOGIC;
    din : IN STD_LOGIC_VECTOR(7 DOWNTO 0);
    dout : OUT STD_LOGIC_VECTOR(0 DOWNTO 0);
END COMPONENT;
signal fifo1_data_in_1   : std_logic_vector(31 downto 0);
signal fifo1_data_in_2   : std_logic_vector(31 downto 0);
signal empty_2           :  std_logic;
signal reden_1           :  std_logic;
signal fifo1_data_out_1  : std_logic_vector(7 downto 0);
signal fifo2_data_out_2  : std_logic_vector(0 downto 0);
signal reden_1_d1        :  std_logic;
--signal clk_100M        :  std_logic;
--signal clk_40M         :  std_logic;
----fifo1
signal wr_en_d1          :  std_logic;
signal wr_en_d1_1        :  std_logic;
signal wr_en_d1_2        :  std_logic;
signal rd_en_d1          :  std_logic;
signal full_d1           :  std_logic;
signal empty_d1          :  std_logic;
----fifo2
signal wr_en_d2          :  std_logic;
signal rd_en_d2          :  std_logic;
signal full_d2           :  std_logic;
signal empty_d2          :  std_logic;
begin
fifo_data_out<=fifo2_data_out_2;
process(clk_100M)
begin
        if(clk_100M'event and clk_100M='1') then
        fifo1_data_in_1<=fifo1_data_in_2;
        fifo1_data_in_2<=fifo_data_in;
        reden_1_d1<=reden_1;
        end if;
end process;
----fifo1
process(nrst,clk_100M,reden_1,empty_2)
begin
  if (nrst='0') then
    wr_en_d1    <='0';
         wr_en_d1_1  <='0';
    wr_en_d1_2  <='0';
--    rd_en_d1    <='0';
--         rd_en_d1    <='0';
  elsif (clk_100M'event and clk_100M='1') then
                 empty_2<=empty_1;
                         wr_en_d1_1<= wr_en_d1;
        if (empty_2='0' and full_d1='0') then
               wr_en_d1 <='1';
                                        reden_1  <='1';
             else
                                        wr_en_d1 <='0';
                                        reden_1  <='0';
        end if;
   end if;
end process;
wr_en_d1_2  <= wr_en_d1;
reden  <= reden_1_d1;
process(nrst,clk_100M,empty_d1)
begin
  if (nrst='0') then
    wr_en_d2<='0';
             if (empty_d1='0' and full_d2='0') then
               wr_en_d2<='1';
                                        rd_en_d1<='1';
             else
                    wr_en_d2<='0';
                                        rd_en_d1<='0';
        end if;
   end if;
end process;
process(clk_100M,empty_d2)
begin
             if (empty_d2='0' ) then
              rd_en_d2<='1';
             else
                                        rd_en_d2<='0';
        end if;
   end if;
end process;
fifo_save : fifo1
  PORT MAP (
    rst => nrst,
    wr_clk => clk_100M,
    rd_clk => clk_100M,
    din => fifo1_data_in_1,
    wr_en => wr_en_d1,
    rd_en => rd_en_d1,
    dout => fifo1_data_out_1,
    full => full_d1,
    empty => empty_d1
fifo_trans : fifo2
  PORT MAP (
    rst => nrst,
    wr_clk => clk_100M,
    rd_clk => clk_100M,
    din => fifo1_data_out_1,
    wr_en => wr_en_d2,
    rd_en => rd_en_d2,
    dout =>fifo2_data_out_2,
    full => full_d2,
    empty => empty_d2
end Behavioral;
发表于 2016-12-23 18:09:41 | 显示全部楼层
看了VHDL头都大, 很讨厌的说。。。。
发表于 2016-12-24 12:13:12 | 显示全部楼层
首先用debug抓的是什么情况,是没有数据还是数据是错的。
 楼主| 发表于 2016-12-25 15:26:44 | 显示全部楼层
回复 3# 谁枫而飘
   是用ChipsCope抓取的信号,就是fifo输入端口可以看到32位的数据,但是FIFO的输出数据一直是0,如果单独把FIFO模块拿出来测试,可以用ChipsCope看到输入的32位数据,FIFO1输出的8位数据和FIFO2输出的1位数据
GMT+8, 2025-12-27 02:57 , Processed in 0.014914 second(s), 4 queries , Gzip On, Redis On.
