查看: 2073|回复: 3
[求助] The target library does not contain all required gates
发表于 2016-12-23 05:48:30 | 显示全部楼层 |阅读模式
I know my design only used standard cells from tsmc 28 hvt library, I checked that the library did get loaded OK:shiftreg4chipA              __auto_cel_houston.<companyname>.com_33978.CEL
  tcbn28hpmbwp35hvtss0p81v125c_ecsm (library) <path to>/tcbn28hpmbwp35hvtss0p81v125c_ecsm.db
and yet ICC complained the following:
Please help, I have no clue what to do.
发表于 2016-12-26 12:49:16 | 显示全部楼层
check why library did not load well.
发表于 2016-12-27 15:40:04 | 显示全部楼层
意思是,你的target library不可以单独使用滴,因为这不是一个完整的lib,需要配合别的lib一起使用。
 楼主| 发表于 2016-12-28 01:22:19 | 显示全部楼层
回复 3# 大龄文艺男青年
   谢谢回复能具体说一下与什么lib一起用? 如何连起来呢?
万分感谢
GMT+8, 2025-11-3 04:05 , Processed in 0.012861 second(s), 3 queries , Gzip On, Redis On.
