查看: 2713|回复: 3
[求助] synopsys ICC usage
发表于 2016-12-13 01:51:15 | 显示全部楼层 |阅读模式
I am new for IC compiler, I could open my design in PartitionEditorWindow, and got layoutWindow like this screen capture:
but when I tried floorPlan
I got this error:
create_floorplan -core_aspect_ratio 1.6 -start_first_row -flip_first_row -left_io2core 0.5 -bottom_io2core 0.5 -right_io2core 0.5 -top_io2core 0.5
Fail to run Floorplanner due to failing to get unit's CellId!
Error: Planner run through unsuccessful.  (APLUI-102)
0
Please help
发表于 2016-12-14 10:02:29 | 显示全部楼层
Maybe you need a command like this:set_fp_options -unit_tile_name XXX.Please check your documents and maybe you can find the answer.
 楼主| 发表于 2016-12-18 04:28:40 | 显示全部楼层
回复 2# aiqiongqiong
thank you for respondingsomehow my man page did not see "set_fp_options"
发表于 2016-12-19 09:29:04 | 显示全部楼层
回复 3# xiaoyisimonguo
    oh,maybe now it is the new one "set_fp_strategy"
GMT+8, 2025-9-14 07:22 , Processed in 0.014314 second(s), 4 queries , Gzip On, Redis On.
