查看: 2838|回复: 2
[讨论] UVM register model仿真报错
发表于 2016-12-8 16:24:53 | 显示全部楼层 |阅读模式
使用的是VCS,编译没有问题在仿真时出现如下错误,“W1C”感觉不应该报unknown access right. 有没有大神帮忙解释一下。非常感谢!
错误提示如下所示:
UVM_INFO @ 0: reporter [RNTST] Running test case0...
UVM_ERROR /eda/synopsys/uvm-1.1d/src/reg/uvm_reg_field.svh(953) @ 0: reporter [RegModel] Register 'rm.status_1' containing field 'overrun_err' is mapped in map 'rm.default_map' with unknown access right 'W1C'
UVM_FATAL @ 0: reporter [BUILDERR] stopping due to build errors
 楼主| 发表于 2016-12-8 16:29:24 | 显示全部楼层
走过路过不要错过,大家一起来讨论讨论!
 楼主| 发表于 2016-12-9 11:15:39 | 显示全部楼层
坐等大神来解答!
GMT+8, 2025-12-18 17:05 , Processed in 0.012366 second(s), 4 queries , Gzip On, Redis On.
