查看: 3178|回复: 2
[讨论] 如何根据工艺厂给的.clf文件写出antenna.tcl文件,不知下面的定义是否正确
发表于 2016-12-2 15:09:01 | 显示全部楼层 |阅读模式
工艺厂给的.clf文件如下:
define _libId (dbGetCurrentLibId)
dbClearLibAntennaRules _libId
dbDefineAntennaRule _libId 5 2 600 0
dbAddAntennaLayerRule  _libId 5 "M1" 600 '(0.159 0 600 7000)
dbAddAntennaLayerRule  _libId 5 "M2" 600 '(0.159 0 600 7000)
dbAddAntennaLayerRule  _libId 5 "M3" 600 '(0.159 0 600 7000)
dbAddAntennaLayerRule  _libId 5 "M4" 600 '(0.159 0 600 7000)
dbAddAntennaLayerRule  _libId 5 "M5" 600 '(0.159 0 8000 30000)
dbDefineAntennaRule _libId 2 2 0 20
dbAddAntennaLayerRule  _libId 2 "MV1" 20 '(0.159 0 83.33 75)
dbAddAntennaLayerRule  _libId 2 "MV2" 20 '(0.159 0 83.33 75)
dbAddAntennaLayerRule  _libId 2 "MV3" 20 '(0.159 0 83.33 75)
dbAddAntennaLayerRule  _libId 2 "MV4" 20 '(0.159 0 83.33 75)
本人写的antenna.tcl文件如下:
define_antenna_rule -mode 5 -diode_mode 2 -metal_ratio 600 -cut_ratio 0
define_antenna_layer_rule -mode 5 -layer "M1" -ratio 600 -diode_ratio {0.159 0 600 7000}
define_antenna_layer_rule -mode 5 -layer "M2" -ratio 600 -diode_ratio {0.159 0 600 7000}
define_antenna_layer_rule -mode 5 -layer "M3" -ratio 600 -diode_ratio {0.159 0 600 7000}
define_antenna_layer_rule -mode 5 -layer "M4" -ratio 600 -diode_ratio {0.159 0 600 7000}
define_antenna_layer_rule -mode 5 -layer "M5" -ratio 600 -diode_ratio {0.159 0 8000 30000}
define_antenna_rule -mode 2 -diode_mode 2  -metal_ratio 20 -cut_ratio 0
define_antenna_layer_rule -mode 2 -layer "MV1" -ratio 20 -diode_ratio {0.159 0 83.33 75}
define_antenna_layer_rule -mode 2 -layer "MV2" -ratio 20 -diode_ratio {0.159 0 83.33 75}
define_antenna_layer_rule -mode 2 -layer "MV3" -ratio 20 -diode_ratio {0.159 0 83.33 75}
define_antenna_layer_rule -mode 2 -layer "MV4" -ratio 20 -diode_ratio {0.159 0 83.33 75}
问:(1)dbDefineAntennaRule _libId 5 2 600 0与dbDefineAntennaRule _libId 2 2 0 20中的数值分别对应define_antenna_rule、define_antenna_layer_rule中的哪个options?(2)我的antenna.tcl文件是否写正确?
 楼主| 发表于 2016-12-3 14:47:07 | 显示全部楼层
dbDefineAntennaRule _libId 5 2 600 0与dbDefineAntennaRule _libId 2 2 0 20中的数值分别对应define_antenna_rule、define_antenna_layer_rule中的哪个options?求解疑
发表于 2021-5-15 23:00:53 | 显示全部楼层
居然没有答复。。。
GMT+8, 2025-11-3 03:44 , Processed in 0.018990 second(s), 3 queries , Gzip On, Redis On.
