ISE8.2i和Modelsim仿真器,用如下命令编译xilinx的仿真库
compxlib -s mti_se -arch all -l verilog -w -lib all
结果出现下面一堆错误,请大虾们指教:
# --> Compiling verilog unisim library
# > Unisim compiled to E:\Xilinx\verilog\mti_se\unisims_ver
# > Log file E:\Xilinx\verilog\mti_se\unisims_ver\cxl_unisim.log generated
# > Library mapping successful, setup file(s) modelsim.ini updated
# compxlib[unisims_ver]: 18 error(s), no warning(s)
# --> Compiling verilog simprim library
# > Simprim compiled to E:\Xilinx\verilog\mti_se\simprims_ver
# > Log file E:\Xilinx\verilog\mti_se\simprims_ver\cxl_simprim.log generated
# compxlib[simprims_ver]: 29 error(s), no warning(s)
# --> Compiling verilog XilinxCoreLib library
# > XilinxCoreLib compiled to E:\Xilinx\verilog\mti_se\XilinxCoreLib_ver
# > Log file E:\Xilinx\verilog\mti_se\XilinxCoreLib_ver\cxl_XilinxCoreLib.log generated
# compxlib[XilinxCoreLib_ver]: 209 error(s), 30 warning(s)
# --> Compiling verilog smartmodel(simprim) library
# > unable to parse initialization file. Check if the
# file modelsim.ini is present in the current directory
# with read/write permissions
# > SWIFT Interface configuration procedure failed
# > Simprim Smart-Models compiled to E:\Xilinx\verilog\mti_se\simprims_ver
# > Log file E:\Xilinx\verilog\mti_se\simprims_ver\cxl_smartmodel.log generated
# compxlib[smartmodel]: 4 error(s), no warning(s)
尤其在编译[XilinxCoreLib_ver]: 出错最多,求救? |
