查看: 4003|回复: 0
[讨论] “connect_pg_net”和“connect_supply_net”区别?
发表于 2016-6-17 23:04:19 | 显示全部楼层 |阅读模式
connect_pg_net              Connects  power, ground, and tie-off pins to the specified power and ground nets.
connect_supply_net        Connects  the supply net to the specified supply ports and pins.
请问supply net 和 supply ports supply pins分别指什么呢?
supply net 和 power/ground nets 不是一回事吗?
supply ports and pins 和 power/ground pins 不一样吗?
GMT+8, 2025-10-30 07:29 , Processed in 0.015397 second(s), 6 queries , Gzip On, Redis On.
