查看: 2066|回复: 2
[求助] 可否发我一个 .cshrc 文件?
发表于 2016-6-13 16:11:18 | 显示全部楼层 |阅读模式
刚刚从 bash 转为 cshell, 没有在home 下看到 .cshrc文件。
可否发我一个 .cshrc 文件?
谢谢
发表于 2016-6-14 10:40:13 | 显示全部楼层
回复 1# IR888
Some Suggestions for your .cshrc file# some shortcutsalias h historyalias m morealias q lpq -Pgoyaalias l ls -F              # this marks directories with / and executables with *set path = ($path ~/bin)   # include ~/bin in search path for commandssetenv PRINTER goya        # make lpr/lpq/lprm default to goyaA Suggestion for your .login fileecho "The current system load average is:"uptime
You could find more from the below link:http://info.eps.surrey.ac.uk/FAQ/loginfiles.html
 楼主| 发表于 2016-6-14 13:56:28 | 显示全部楼层
回复 2# spzhu2010
many thanks
GMT+8, 2025-10-20 02:45 , Processed in 0.015344 second(s), 4 queries , Gzip On, Redis On.
