查看: 3161|回复: 5
[求助] formality验证问题,求大神解疑!急急急!!!!!
发表于 2016-5-14 22:11:31 | 显示全部楼层 |阅读模式
Net i:/WORK/halfband2_CSD_DW01_sub_142/DIFF[7] is undriven.
Info:  Net i:/WORK/halfband2_CSD_DW01_sub_142/DIFF[6] is undriven.
Info:  Net i:/WORK/halfband2_CSD_DW01_sub_142/DIFF[5] is undriven.
Info:  Net i:/WORK/halfband2_CSD_DW01_sub_142/DIFF[4] is undriven.
Info:  Net i:/WORK/halfband2_CSD_DW01_sub_142/DIFF[3] is undriven.
Info:  Net i:/WORK/halfband2_CSD_DW01_sub_142/DIFF[2] is undriven.
Info:  Net i:/WORK/halfband2_CSD_DW01_sub_142/DIFF[1] is undriven.
Info:  Net i:/WORK/halfband2_CSD_DW01_sub_142/DIFF[0] is undriven.
Info:  Net i:/WORK/halfband2_CSD_DW01_sub_142/CO is undriven.
Info:  Net i:/WORK/halfband2_CSD_DW01_add_488/SUM[1] is undriven.
Info:  Net i:/WORK/halfband2_CSD_DW01_add_488/SUM[0] is undriven.
Info:  Net i:/WORK/halfband2_CSD_DW01_add_488/CO is undriven.
Info:  Net i:/WORK/halfband2_CSD_DW01_add_491/CO is undriven.
Warning: 26 (4207) undriven nets found in reference (implementation) design; see formality.log for list (FM-399)
Warning: 75 (0) undriven pins found in reference (implementation) design; see formality.log for list (FM-399)
*********************************** Matching Results ***********************************
11588 Compare points matched by name
0 Compare points matched by signature analysis
0 Compare points matched by topology
8 Matched primary inputs, black-box outputs
196(0) Unmatched reference(implementation) compare points
0(0) Unmatched reference(implementation) primary inputs, black-box outputs
42017(0) Unmatched reference(implementation) unread points
Unmatched Objects                                                        REF        IMPL
Cut-points (Cut)                                                         24           0
Registers                                                               172           0
   Constrained 0X                                                        172           0
Formality (match)> man FM-399
messages                         N.  Messages                Command Reference
NAME
       FM-399  (warning)  %d  (%d) undriven %s found in reference (implementa-
       tion) design; see %s for list
DESCRIPTION
       Nets or pins with no driving logic  were  found  in  the  reference  or
       implementation  design.  These  nets/pins are assumed to have the value
       specified by the verification_set_undriven_signals TCL variable.
WHAT NEXT
       Verify the connections on the indicated nets and correct the design  if
       it is not what you intended. You can specify the value Formality should
       assume   for   undriven    signals    by    setting    the    verifica-
       tion_set_undriven_signals  variable  to X(default), Z, 0, 1, or PI(pri-
       mary input).
D-2010.03        Synopsys Inc. 1988-2010. All rights reserved.             n-1
问:match failed是否与以上提示的undriven信息相关?man FM-399得到 上述结果,但仍然不知如何修正?跪求解决办法
发表于 2016-5-17 11:29:32 | 显示全部楼层
verfication_set_unfriven_signals
发表于 2016-5-17 13:48:46 | 显示全部楼层
是不是需要检查一下这些undriven net,确认你的设计有没有问题。
发表于 2016-5-17 16:48:28 | 显示全部楼层
检查undrivern net,或者用start_gui命令看下电路logic
 楼主| 发表于 2016-5-19 12:47:52 | 显示全部楼层
已解决
发表于 2017-4-19 13:57:02 | 显示全部楼层
回复 5# 1027199631
问一下是什么原因导致undriven,是RTL问题吗?后来你们怎么解决的
GMT+8, 2025-10-18 19:01 , Processed in 0.022784 second(s), 4 queries , Gzip On, Redis On.
