我用的是quartus,我在工程中调用了lpm ip核,用quartus仿真没问题,但用modelsim仿真出现错误,错误如下
# Warning : Address pointed at port A is out of bound!
# Time: 750 Instance: viterbi_test.i1.dRam1.altsyncram_component
# Time: 770 Instance: viterbi_test.i1.dRam1.altsyncram_component
# Time: 1490 Instance: viterbi_test.i1.dRam2.altsyncram_component
# Time: 1510 Instance: viterbi_test.i1.dRam2.altsyncram_component
# Time: 1670 Instance: viterbi_test.i1.dRam1.altsyncram_component
# Time: 2230 Instance: viterbi_test.i1.dRam3.altsyncram_component
# Time: 2250 Instance: viterbi_test.i1.dRam3.altsyncram_component
# Time: 2390 Instance: viterbi_test.i1.dRam2.altsyncram_component
# Time: 2970 Instance: viterbi_test.i1.dRam1.altsyncram_component
# Time: 2990 Instance: viterbi_test.i1.dRam1.altsyncram_component
# Time: 3110 Instance: viterbi_test.i1.dRam3.altsyncram_component
# Time: 3710 Instance: viterbi_test.i1.dRam2.altsyncram_component
# Time: 3730 Instance: viterbi_test.i1.dRam2.altsyncram_component
# Time: 3830 Instance: viterbi_test.i1.dRam1.altsyncram_component
# Time: 4450 Instance: viterbi_test.i1.dRam3.altsyncram_component
# Time: 4470 Instance: viterbi_test.i1.dRam3.altsyncram_component
# Time: 4550 Instance: viterbi_test.i1.dRam2.altsyncram_component
这是工程中的相关代码
dRam dRam1 (.clock(clk),.wren(wrRamEnable1),.address(ramAddress1),.data(dataInRamTemp),.q(dataOutRamTemp1));
dRam dRam2 (.clock(clk),.wren(wrRamEnable2),.address(ramAddress2),.data(dataInRamTemp),.q(dataOutRamTemp2));
dRam dRam3 (.clock(clk),.wren(wrRamEnable3),.address(ramAddress3),.data(dataInRamTemp),.q(dataOutRamTemp3));
我感觉是第三方软件没有识别ip核,导致出错,希望有经验的大牛可以帮解答一下,谢谢了。 |
