查看: 3897|回复: 2
[求助] 有没有人遇到过quartus 15.1(或with update1)无法用modelsim仿真的问题
发表于 2016-4-27 16:19:21 | 显示全部楼层 |阅读模式
我在调用rtl simulation工具的时候报错,错误在下面,重点部分已加粗:我有点方。。我用的器件是cyIV的,我没装cyIII的库,quartus15.1也没有cyIII的库好像,报了这个错是啥意思。。
Info: Start Nativelink Simulation process
========= EDA Simulation Settings =====================
Sim Mode              :  RTL
Family                :  cycloneive
Quartus root          :  c:/altera/15.1/quartus/bin64/
Quartus sim root      :  c:/altera/15.1/quartus/eda/sim_lib
Simulation Tool       :  modelsim-altera
Simulation Language   :  verilog
Simulation Mode       :  GUI
Sim Output File       :
Sim SDF file          :
Sim dir               :  simulation\modelsim
Info: Starting NativeLink simulation with ModelSim-Altera software
Sourced NativeLink script c:/altera/15.1/quartus/common/tcl/internal/nativelink/modelsim.tcl
Warning: File SOPC_VIBE_run_msim_rtl_verilog.do already exists - backing up current file as SOPC_VIBE_run_msim_rtl_verilog.do.bak1
TCL READ VARNAME
Error: NativeLink simulation flow was NOT successful
================The following additional information is provided to help identify the cause of error while running nativelink scripts=================
Nativelink TCL script failed with errorCode:  NONE
Nativelink TCL script failed with errorInfo:  can't read "lib_list(cycloneiii)": no such element in array
    while executing
"set my_lib_list $lib_list($library)"
    (procedure "::quartus::sim_lib_info::get_sim_models_for_library" line 4)
    invoked from within
"::quartus::sim_lib_info::get_sim_models_for_library $library $tool $hdl_version"
    (procedure "get_sim_models_for_tb" line 11)
    invoked from within
"get_sim_models_for_tb $extra_lib $tool"
    invoked from within
"set extra_libs [get_sim_models_for_tb $extra_lib $tool]"
    invoked from within
"foreach_in_collection asgn_id $extra_lib_asgn {
            set extra_lib [string tolower [get_assignment_info $asgn_id -value]]
            set extra..."
    (procedure "get_sim_models_for_design" line 16)
    invoked from within
"get_sim_models_for_design $lang $rtl_sim "modelsim""
    invoked from within
"if [ catch { open $msim_do_file_name w } msim_do_file ] {
        nl_postmsg  error "Error: Can't open file $msim_do_file_name: $file_id"
        set msim_do_file_n..."
    (procedure "gen_msim_script" line 69)
    invoked from within
"gen_msim_script args_hash"
    ("eval" body line 1)
    invoked from within
"eval gen_msim_script args_hash"
    invoked from within
"if [ catch {eval gen_msim_script args_hash} msim_do_file_name] {
        error "$::errorCode" "$::errorInfo"
    } elseif {$script_mode == 0} {
        post_message..."
    (procedure "launch_sim" line 109)
    invoked from within
"launch_sim launch_args_hash"
    invoked from within
"eval launch_sim launch_args_hash"
    invoked from within
"if [ info exists ::errorCode ] {
                set savedCode $::errorCode
                set savedInfo $::errorInfo
                error $result $..."
    invoked from within
"if [catch {eval launch_sim launch_args_hash} result ] {
            set status 1
                set save..."
    (procedure "run_sim" line 74)
    invoked from within
"run_sim run_sim_args_hash"
    invoked from within
            error "$result" $savedInfo ..."
    (procedure "run_eda_simulation_tool" line 335)
    invoked from within
"run_eda_simulation_tool eda_opts_hash"
发表于 2016-4-29 10:11:54 | 显示全部楼层
回复 1# gothinkbig
   哥,你有quartus 15.1 的license么?求~
发表于 2016-4-30 16:16:08 | 显示全部楼层
没有库文件支持啊。
GMT+8, 2025-12-26 07:25 , Processed in 0.021408 second(s), 6 queries , Gzip On, Redis On.
