查看: 11599|回复: 6
[求助] starRC抽取spf网表问题【已解决】
发表于 2016-4-27 11:11:28 | 显示全部楼层 |阅读模式
我想用starRC软件从def文件抽取出spf网表,但是最后却没有生成我想要的spf文件。
求各位帮忙看看是哪个部分出了问题。
cmd代码如下
  1. BLOCK: s38417
  2. LEF_FILE: /root/simulation/lib/28nm/SAED_EDK32.28nm_CORE_RVT_v_01132015/SAED32_EDK/lib/stdcell_rvt/lef/saed32nm_rvt_1p9m.lef
  3. TOP_DEF_FILE  /home/rsh/Desktop/run_area/icc/s38417/s38417.def
  4. * EXTRACTION: RKC
  5. TCAD_GRD_FILE:/root/simulation/lib/28nm/SAED_iPDK_32.28_v1.3_04102014/SAED32_28_iPDK/starrc/max/saed32nm_1p9m_Cmax.nxtgrd
  6. MAPPING_FILE:/root/simulation/lib/28nm/SAED_iPDK_32.28_v1.3_04102014/SAED32_28_iPDK/starrc/saed32nm_tf_itf_tluplus.map
  7. POWER_NETS: VDD VSS
  8. POWER_EXTRACT: YES
  9. COUPLING_MULTIPLIER : 0.99
  10. COUPLING_ABS_THRESHOLD: 1e-14
  11. COUPLING_REL_THRESHOLD: 0.15
  12. COUPLE_TO_GROUND: NO
  13. COUPLING_MULTIPLIER: 1
  14. * OPERATING_FREQUENCY: 1e+6
  15. EXTRACTION: RC
  16. MILKYWAY_EXTRACT_VIEW: YES
  17. CASE_SENSITIVE: NO
  18. NETLIST_FORMAT: SPF
  19. NETLIST_NODE_SECTION: YES
  20. NETLIST_CONNECT_SECTION: YES
  21. NETLIST_SUBCKT: YES
  22. NETLIST_PASSIVE_PARAMS: YES
  23. NETLIST_TAIL_COMMENTS: YES
  24. * NETLIST_DELIMITER: s38417.spf
  25. NETLIST_REMOVE_LOOPS: NO
  26. INTRANET_CAPS: YES
  27. SHORT_PINS: NO
  28. NETLIST_FILE: s38417.spf
  29. REDUCTION: NO
  30. * XREF: YES
  31. EXTRACT_VIA_CAPS: YES
  32. IGNORE_CAPACITANCE: NONE
  33. KEEP_VIA_NODES: YES
  34. MAGNIFY_DEVICE_PARAMS: YES
  35. METAL_FILL_POLYGON_HANDLING: IGNORE
  36. MODE: 200
  37. MOS_GATE_DELTA_RESISTANCE: YES
  38. REMOVE_DANGLING_NETS: NO
  39. REMOVE_FLOATING_NETS: NO
  40. TRANSLATE_RETAIN_BULK_LAYERS: YES
  41. HIERARCHICAL_SEPARATOR: |
  42. OBSERVATION_POINTS:*
  43. EXTRA_GEOMETRY_INFO: NONE
  44. OA_LIB_NAME:
  45. OA_VIEW_NAME: starrc
  46. OA_MARKER_SIZE: 0.1
  47. OA_REMOVE_SPICECARD_PREFIX: NO
  48. OA_DEVICE_MAPPING_FILE:/root/simulation/lib/28nm/SAED_iPDK_32.28_v1.3_04102014/SAED32_28_iPDK/starrc/saed32nm_1p9m_device.map
  49.
    复制代码
 楼主| 发表于 2016-4-28 09:47:57 | 显示全部楼层
这是starRC的运行结果
  1. xTractorName:/root/simulation/install_path/synopsys/starrc/amd64_starrc/bin/xTractor
  2. Version: J-2014.12-SP2
  3. Built on: Mar  2 2015 00:48:50
  4. Start Time: Wed Apr 27 10:44:52 2016
  5. Block ........... s38417
  6. Star Directory .. /home/rsh/Desktop/run_area/hs/aes/star
  7. LEF file ........
  8. '/root/simulation/lib/28nm/SAED_EDK32.28nm_CORE_RVT_v_01132015/SAED32_EDK/lib/stdcell_rvt/lef/saed32nm_rvt_1p9m.lef' (SX-2066)
  9. Top DEF File .... '/home/rsh/Desktop/run_area/icc/s38417/s38417.def' (SX-2068)
  10. Map Layers:  Wed Apr 27 10:44:59 2016
  11. NOT RUNNING Layers !!  Using previous results.
  12.   Previous Layers Elp=00:00:01 Cpu=00:00:00 Usr=0.3 Sys=0.0 Mem=100.5 (SX-1107)
  13. Done
  14. Create Models:  Wed Apr 27 10:44:59 2016
  15. NOT RUNNING Models !!  Using previous results.
  16.   Previous Models Elp=00:00:00 Cpu=00:00:00 Usr=0.0 Sys=0.0 Mem=83.9 (SX-1107)
  17. Done
  18. Build HN:  Wed Apr 27 10:44:59 2016
  19. NOT RUNNING HN !!  Using previous results.
  20.   Previous HN Elp=00:00:00 Cpu=00:00:00 Usr=0.4 Sys=0.0 Mem=112.0 (SX-1107)
  21. Done
  22. Process Cells:  Wed Apr 27 10:44:59 2016
  23. NOT RUNNING Cells !!  Using previous results.
  24.   Previous Cells Elp=00:00:01 Cpu=00:00:00 Usr=0.4 Sys=0.0 Mem=114.7 (SX-1107)
  25. Done
  26. Translate DB:  Wed Apr 27 10:44:59 2016
  27. NOT RUNNING Translate !!  Using previous results.
  28.   Previous Translate Elp=00:00:00 Cpu=00:00:00 Usr=0.1 Sys=0.0 Mem=104.2 (SX-1107)
  29. Done
  30. XinMerge DB:  Wed Apr 27 10:44:59 2016
  31. NOT RUNNING XinMerge !!  Using previous results.
  32.   Previous XinMerge Elp=00:00:01 Cpu=00:00:01 Usr=1.1 Sys=0.1 Mem=181.1 (SX-1107)
  33. Done
  34. Netlist Setup:  Wed Apr 27 10:44:59 2016
  35. NOT RUNNING NetlistSetup !!  Using previous results.
  36.   Previous NetlistSetup Elp=00:00:00 Cpu=00:00:00 Usr=0.0 Sys=0.0 Mem=83.9 (SX-1107)
  37. Done
  38. Partition_part1 DB:  Wed Apr 27 10:44:59 2016
  39. NOT RUNNING Partition_part1 !!  Using previous results.
  40.   Previous Partition_part1 Elp=00:00:01 Cpu=00:00:00 Usr=0.7 Sys=0.1 Mem=145.0 (SX-1107)
  41. Done
  42. PartitionPP:  Wed Apr 27 10:44:59 2016
  43. NOT RUNNING PartitionPP !!  Using previous results.
  44.   Previous PartitionPP Elp=00:00:00 Cpu=00:00:00 Usr=0.0 Sys=0.0 Mem=88.1 (SX-1107)
  45. Done
  46. xTract_part1 DB:  Wed Apr 27 10:44:59 2016
  47. NOT RUNNING xTract_part1 !!  Using previous results.
  48.   Previous xTract_part1 Elp=00:01:08 Cpu=00:01:07 Usr=66.2 Sys=0.8 Mem=291.4 (SX-1107)
  49. Done
  50. xTract Post Process DB:  Wed Apr 27 10:45:05 2016
  51. NOT RUNNING xTractPP !!  Using previous results.
  52.   Previous xTractPP Elp=00:00:02 Cpu=00:00:02 Usr=1.9 Sys=0.1 Mem=84.8 (SX-1107)
  53. Done
  54. Report Violations:  Wed Apr 27 10:45:07 2016
  55. NOT RUNNING ReportViolations !!  Using previous results.
  56.   Previous ReportViolations Elp=00:00:00 Cpu=00:00:00 Usr=0.0 Sys=0.0 Mem=0.0 (SX-1107)
  57. Done
  58. Netlist DB:  Wed Apr 27 10:45:09 2016
  59. NOT RUNNING Netlist !!  Using previous results.
  60.   Previous Netlist Elp=00:00:13 Cpu=00:00:12 Usr=12.5 Sys=0.3 Mem=290.4 (SX-1107)
  61. Done
  62.
  63.
  64. Done          Elp=00:00:00 Cpu=00:00:00 Usr=0.0    Sys=0.0    Mem=0.0
  65. End Time: Wed Apr 27 10:45:13 2016
  66.
    复制代码
 楼主| 发表于 2016-4-28 17:35:53 | 显示全部楼层
问题解决,命令行
StarXtract -clean star.cmd
清空之前的运行结果,否则跑出来的是上次生成的文件
发表于 2017-6-29 21:29:31 | 显示全部楼层
回复 3# 墨小央
   美女,请问在抽RC过程中,你是怎么处理不同corner的?谢谢。
发表于 2018-8-21 08:43:27 | 显示全部楼层
学习学习!
发表于 2019-4-11 10:43:40 | 显示全部楼层
学习学习
发表于 2022-9-9 14:48:52 | 显示全部楼层
mark mark
GMT+8, 2025-12-28 09:44 , Processed in 0.027479 second(s), 5 queries , Gzip On, Redis On.
