查看: 2672|回复: 3
[原创] 关于bottom-up下的critical path问题
发表于 2016-4-1 16:42:18 | 显示全部楼层 |阅读模式
请教各位前辈!我最近在用bottom-up的方式做综合,具体的流程与下面这段code一样,但是在timing上碰到了问题。我在synthesize 所有subblock的时候,DC给出的最长的路径不超过4ns,但是在做top-level synthesize的时候,最长的路径却变成了10ns,我对所有的subblock都做了set_dont_touch,但是貌似没有用。我参考的code如下:
remove_design –all
read_verilog DoubleCore.v
current_design AddressGenerator
Link
check_design
include subblocks.const
compile -map_effort high
report_timing -path full -delaymax -max_paths 20 -nworst 100
#Generate Verilog Netlist and ddcand sdf
write -hierarchy -format verilog-output"/home/AddressGenerator.v“
write -hierarchy -format ddc-output"/home/AddressGenerator.ddc“
write_sdf"/home/AddressGenerator.sdf“
report_power
current_design fixmultiply
Link
check_design
write -hierarchy -format verilog-output "/home/fixmultiply.v“
write -hierarchy -format ddc-output "/home/fixmultiply.ddc“
write_sdf"/home/fixmultiply.sdf“
report_power
current_design expon
Link
check_design
write -hierarchy -format verilog-output "/home/expon.v“
write -hierarchy -format ddc-output "/home/expon.ddc“
write_sdf "/home/expon.sdf“
report_power
current_design MMU
Link
check_design
write -hierarchy -format verilog-output "/home/MMU.v“
write -hierarchy -format ddc-output "/home/MMU.ddc“
write_sdf "/home/MMU.sdf“
report_power
current_design FSM
Link
check_design
write -hierarchy -format verilog-output "/home/FSM.v“
write -hierarchy -format ddc-output "/home/FSM.ddc“
write_sdf "/home/FSM.sdf“
report_power
current_design MUX_A
Link
check_design
write -hierarchy -format verilog-output "/home/ MUX_A.v“
write -hierarchy -format ddc-output "/home/ MUX_A.ddc“
write_sdf "/home/ MUX_A.sdf“
report_power
current_design MUX_D
Link
check_design
write -hierarchy -format verilog-output "/home/ MUX_D.v“
write -hierarchy -format ddc-output "/home/ MUX_D.ddc“
write_sdf "/home/ MUX_D.sdf“
report_power
current_design GlobalFSM
Link
check_design
write -hierarchy -format verilog-output "/home/ GlobalFSM.v“
write -hierarchy -format ddc-output "/home/ GlobalFSM.ddc“
write_sdf "/home/GlobalFSM.sdf“
report_power
current_design LayerTrans
Link
check_design
write -hierarchy -format verilog-output "/home/ LayerTrans.v“
write -hierarchy -format ddc-output "/home/ LayerTrans.ddc“
write_sdf "/home/LayerTrans.sdf“
report_power
current_design Core
Link
check_design
write -hierarchy -format verilog-output "/home/ Core.v“
write -hierarchy -format ddc-output "/home/Core.ddc“
write_sdf "/home/LearningUnit.sdf“
report_power
remove_design –all
read_ddc [list"/home/LearningUnit.ddc"]
read_ddc [list"/home/MMU.ddc"]
read_ddc [list"/home/FSM.ddc"]
read_ddc [list"/home/MUX_A.ddc"]
read_ddc [list"/home/MUX_D.ddc"]
read_ddc [list"/home/GlobalFSM.ddc"]
read_ddc [list"/home/LayerTrans.ddc"]
read_verilog [list"/home/TOP.v"]
current_design TOP
set_dont_touch Learning
set_dont_touch MMU
set_dont_touch FSM
set_dont_touch MUX_A
set_dont_touch MUX_D
set_dont_touch GlobalFSM
set_dont_touch LayerTrans
check_design
include top.const
write_sdc "/home/TOP.sdc“
write -hierarchy -format verilog-output"/home/TOP_nl.v“
write_sdf"/home/TOP.sdf"report_power
来自 <http://bbs.eetop.cn/thread-404761-1-1.html>
 楼主| 发表于 2016-4-1 17:01:37 | 显示全部楼层
希望各位大神指点一下!
发表于 2016-4-1 23:55:46 | 显示全部楼层
猜测,是因为顶层考虑了各个子模块的互连问题导致的,这个时候他是会在连线上插buf之类的。
 楼主| 发表于 2016-4-2 14:12:25 | 显示全部楼层
回复 3# renxx333
   谢谢你的回复!   我又检查了一下top level的综合结果,发现最长的路径是在两个subblock之间,我怀疑是因为其中一个subblock的input没有加register,所以在做subblock单独综合的时候,timing constrain没有约束到该subblock input的combination logic。我现在想可以把那两个subblock合并成一个大的subblock来综合。
GMT+8, 2025-12-14 10:17 , Processed in 0.015057 second(s), 3 queries , Gzip On, Redis On.
