查看: 5058|回复: 3
[求助] spectre下veriloga仿真报错
发表于 2016-3-26 12:13:40 | 显示全部楼层 |阅读模式
我用的是5141,按照这篇博客上说的,http://www.eetop.cn/blog/html/34/840234-23976.html,建立了一个veriloga的symbol,然后在schematic中打开,设了一些参数,仿真之后报错:
Command line:
    /home/cadence/mmsim61/tools.lnx86/spectre/bin/32bit/spectre -env  \
        artist5.1.0 +escchars +log ../psf/spectre.out +inter=mpsc  \
        +mpssession=spectre7_5372_3 -format sst2 -raw ../psf +lqtimeout  \
        900 -maxw 5 -maxn 5 input.scs
spectre pid = 5077
Loading /home/cadence/mmsim61/tools.lnx86/cmi/lib/4.0/libinfineon_sh.so ...
Loading /home/cadence/mmsim61/tools.lnx86/cmi/lib/4.0/libnortel_sh.so ...
Loading /home/cadence/mmsim61/tools.lnx86/cmi/lib/4.0/libphilips_sh.so ...
Internal error found in spectre.  Please run `getSpectreFiles' or send the netlist, the spectre log file, the behavioral model files, and any other information that can help identify the problem to support@cadence.com.
    Segmentation fault.
本人还是初学,对于报错信息不太了解,大家帮忙看看,到底是参数问题,还是另外的问题?
发表于 2016-11-10 13:23:16 | 显示全部楼层
博客地址,拿走。。。谢楼主
发表于 2016-11-10 13:24:35 | 显示全部楼层
楼主还有其他使用spectre软件的入门资料或者网址么?
发表于 2018-3-27 23:28:20 | 显示全部楼层
顶一下,拷的别人的虚拟机仿真时也遇到这个问题,求大神帮忙分析下。
spectre.out内容:
Command line:
    /eda/cadence/mmsim611/tools.lnx86/spectre/bin/32bit/spectre -env  \
        +mpssession=spectre0_5196_1 -format sst2 -raw ../psf +lqtimeout  \
spectre pid = 5382
Loading /eda/cadence/mmsim611/tools.lnx86/cmi/lib/4.0/libinfineon_sh.so ...
Loading /eda/cadence/mmsim611/tools.lnx86/cmi/lib/4.0/libnortel_sh.so ...
Loading /eda/cadence/mmsim611/tools.lnx86/cmi/lib/4.0/libphilips_sh.so ...
    Segmentation fault.
GMT+8, 2025-12-3 01:14 , Processed in 0.020641 second(s), 5 queries , Gzip On, Redis On.
