查看: 3780|回复: 0
[求助] 请问tetramax中的add_nofaults到底是什么意思?谢谢~
发表于 2016-3-23 10:21:17 | 显示全部楼层 |阅读模式
下面是说明文档,看不懂什么意思,既然是no faults,还用得着add吗?
add_nofaults
[<instance_name> | <pin_pathname>  | -module <module_name>]
[-stuck <0 | 1 | 01>] [-instance {instance_name_list}]
                    Arguments
instance_name
Adds the nofault attribute to all faults associated with the hierarchical [url=]instancepathname.[/url]
pin_pathname [-stuck <0 | 1 | 01>]
Adds the nofault attribute to faults on the [url=]pinpathname.[/url] You can use the -stuck option to select either stuck 0, stuck 1, or both. The default isboth stuck 0 and stuck 1. A stuck 0/1/01 nofault also blocks the creation of any slow-to-rise/fall/rise&fallfaults or IDDQ faults at the specified site.
-module <module_name> [-stuck <0 | 1 | 01>]
Adds the nofault attribute to one or more pins of every instantiation of a given module, where <name> could be a fixed string or a [url=]limitedregular expression[/url]. If no pins are specified, then all pins of the module are used. The -stuck option may be used to select either stuck 0, stuck 1, or both. The default is both stuck 0 and stuck 1.
Adds the nofault attribute to all faults specified in the instance_name_list.
            Allowed Command Modes
DRC, Test
            Description
Use this command to inhibit the placement of faults at specific locations. You must define nofaults priorto using the [url=]addfaults[/url] or [url=]readfaults[/url] command to inhibit adding a fault to selected locations. You can use the [url=]addequivalent nofaults[/url] command to set the nofault attribute for all faults that are equivalent tofaults that currently have the nofault attribute.
            Examples
                 # nofault stuck-at-1 fault of pin 'SL' of every instance
# of module MUX2H
TEST> add_nofaults -module MUX2H -stuck 1 SL
  4 faults were added to nofault list.
                 # nofault a specific pin
TEST> add_nofaults mux3/MUX2_UDP_1/Q
  2 faults were added to nofault list.
                 # nofault an instance
TEST> add_nofaults mux0
  15 faults were added to nofault list.
GMT+8, 2025-12-27 04:47 , Processed in 0.020972 second(s), 6 queries , Gzip On, Redis On.
