查看: 9218|回复: 10
[求助] 提取寄生后进行primetime分析,执行read_parasitics时出现错误,求大神解疑
发表于 2016-3-14 14:53:17 | 显示全部楼层 |阅读模式
pt_shell>read_parasitics -format SPEF -keep_capacitive_coupling  -verbose  XX.spef.max__0
Information: Checked out license 'PrimeTime-SI' (PT-019)
Information: Derived library resistance unit is 1.000000 Kohm (Time unit is 1 ns, and Capacitance unit is 1.000000 pF). (DES-028)
Error: Cannot find port/pin 'uut_m/dataout_reg[6]/D' in design 'SPI_S' (DES-002)
Error: Invalid capacitor (uut_m/dataout_reg[6] 0.00782438) on net uut_m/n615:
        node not found (PARA-044)
Error: Cannot find port/pin 'uut_m/bit_cnt_reg[2]/D' in design 'SPI_S' (DES-002)
Error: Invalid capacitor (uut_m/bit_cnt_reg[2] 0.00502328) on net uut_m/n849:
Error: Cannot find port/pin 'uut_m/DRDY_c_reg[1]/D' in design 'SPI_S' (DES-002)
Error: Invalid capacitor (uut_m/DRDY_c_reg[1] 0.00319042) on net uut_m/n604:
Error: Cannot find port/pin 'uut_m/dataout_reg[7]/D' in design 'SPI_S' (DES-002)
Error: Invalid capacitor (uut_m/dataout_reg[7] 0.00191792) on net uut_m/n610:
Error: Cannot find port/pin 'uut_m/bit_cnt_reg[1]/D' in design 'SPI_S' (DES-002)
Error: Invalid capacitor (uut_m/bit_cnt_reg[1] 0.00205893) on net uut_m/n847:
Error: Cannot find port/pin 'uut_m/DRDY_c_reg[0]/D' in design 'SPI_S' (DES-002)
Error: Invalid capacitor (uut_m/DRDY_c_reg[0] 0.00480318) on net uut_m/n607:
Error: Cannot find port/pin 'uut_m/bit_cnt_reg[2]/Q' in design 'SPI_S' (DES-002)
Error: Invalid capacitor (uut_m/bit_cnt_reg[2] 0.00467754) on net uut_m/n1004:
Error: Cannot find port/pin 'uut_m/bit_cnt_reg[0]/D' in design 'SPI_S' (DES-002)
Error: Invalid capacitor (uut_m/bit_cnt_reg[0] 0.00243063) on net uut_m/n845:
Error: Cannot find port/pin 'uut_m/byte_cnt_reg[0]/D' in design 'SPI_S' (DES-002)
Error: Invalid capacitor (uut_m/byte_cnt_reg[0] 0.00493988) on net uut_m/n656:
Error: Cannot find port/pin 'uut_m/dataout_reg[5]/D' in design 'SPI_S' (DES-002)
Error: Invalid capacitor (uut_m/dataout_reg[5] 0.003506) on net uut_m/n625:
Error: Cannot find port/pin 'uut_m/dataout_reg[4]/D' in design 'SPI_S' (DES-002)
Error: Invalid capacitor (uut_m/dataout_reg[4] 0.00232004) on net uut_m/n620:
Error: Cannot find port/pin 'uut_m/wr_cnt_reg[4]/D' in design 'SPI_S' (DES-002)
Error: Invalid capacitor (uut_m/wr_cnt_reg[4] 0.00200325) on net uut_m/n924:
Error: Cannot find port/pin 'uut_m/dataout_reg[1]/D' in design 'SPI_S' (DES-002)
Error: Invalid capacitor (uut_m/dataout_reg[1] 0.00490669) on net uut_m/n630:
Error: Cannot find port/pin 'uut_m/mem_adr_reg[2]/D' in design 'SPI_S' (DES-002)
发表于 2016-3-14 20:10:10 | 显示全部楼层
回复 1# 1027199631
        lihai
发表于 2016-3-23 17:30:12 | 显示全部楼层
网表和spef不匹配吧
 楼主| 发表于 2016-3-23 21:56:02 | 显示全部楼层
回复 3# 大龄文艺男青年
多谢回复,已解决
发表于 2016-4-23 19:13:15 | 显示全部楼层
回复 4# 1027199631
是因为网表和spef不一致的原因么  楼主?
发表于 2016-4-24 16:58:05 | 显示全部楼层
可能是lef库文件读错了吧
发表于 2016-12-13 12:31:30 | 显示全部楼层
请问最后是怎么解决的?
发表于 2016-12-14 11:04:42 | 显示全部楼层
楼主应该说下是怎么解决的,希望论坛活跃起来,更多的人愿意分享自己的经验,送人玫瑰手留余香,自己也会从中获益的。
 楼主| 发表于 2016-12-22 21:17:23 | 显示全部楼层
由于在保存网表之前使用了change_names -rules verilog -hierarchy 导致所导出的网表与所提出的.spef文件的名字对应不上,从而出现上述错误。解决办法:在导出网表前不使用上述语句即可
发表于 2022-3-22 15:08:43 | 显示全部楼层
怎么没人继续讨论了
GMT+8, 2025-12-24 04:50 , Processed in 0.027276 second(s), 5 queries , Gzip On, Redis On.
