楼主: SkipLou
[原创] 有关相位噪声的offset frequency
 楼主| 发表于 2016-3-3 11:33:40 | 显示全部楼层
回复 10# hughhuang
   可是我的电路里没有VCO额
发表于 2016-3-3 14:46:34 | 显示全部楼层
回复 11# SkipLou
   ……那你的电路有什么……?
 楼主| 发表于 2016-3-3 19:00:07 | 显示全部楼层
回复 12# hughhuang
  只是个简单的RC振荡电路,输出一个频率稳定的方波
发表于 2016-3-3 22:35:41 | 显示全部楼层
回复 10# hughhuang
    Strictly speaking, noise in oscillator is not additive, since vco is non-linear by its nature.
发表于 2016-3-4 09:48:33 | 显示全部楼层
回复 14# liuqilong8819
   恩恩,有道理,我说的不严谨。前辈,请问,如果是在一个很小的频率范围内,能不能近似看作是加性的呢?
发表于 2016-3-4 14:03:51 | 显示全部楼层
同困扰
发表于 2016-3-4 23:41:05 | 显示全部楼层
回复 15# hughhuang
    You can have a try: build a simple VCO in Spice, and inject a current with frequency different than the central one.  At the output you will not observe f0 or f_injection. That is due to non-linearity.
  When noise frequency is far away from DC, then linear model is a good approximation.
发表于 2016-3-6 09:41:39 | 显示全部楼层
学习了,谢谢
 楼主| 发表于 2016-3-7 10:34:00 | 显示全部楼层
回复 17# liuqilong8819
  Get it! thx ~~
发表于 2020-7-20 16:40:39 | 显示全部楼层
感谢分享讨论~
GMT+8, 2025-12-26 14:00 , Processed in 0.018276 second(s), 4 queries , Gzip On, Redis On.
