查看: 3055|回复: 1
[求助] 配置Xilinx PROM XCF01S问题
发表于 2016-2-25 20:51:56 | 显示全部楼层 |阅读模式
PCB电路是根据手册自己设计的。采用ISE 10.1版本。Xilinx PROM为xcf01s,配置的FPGA为Virtex-ii系列XC2V40。采用主串模式配置,M[2:0] = 000。用JTAG下载配置程序给PROM后,不能自动配置FPGA。iMPACT配置过程信息如下:// *** BATCH CMD : Program -p 1 -e -v -loadfpga
Maximum TCK operating frequency for this device chain: 15000000.
Validating chain...
Boundary-scan chain validated successfully.
'1': Erasing device...
PROGRESS_START - Starting Operation.
'1': Erasure completed successfully.
'1': Programming device...
done.
'1': Putting device in ISP mode...done.
'1': Verifying device...done.
'1': Verification completed successfully.
'1': Calculated checksum matches expected checksum, 0011b0790
'1': Setting user-programmable bits...
done.
'1': Starting FPGA Load with Prom Data...INFO:iMPACT:563 - '1'  please ensure proper connections as specified by the data book ...
'1': Programming completed successfully.
PROGRESS_END - End Operation.
Elapsed time =      8 sec.
我觉得是红色地方可能提示些什么,但是不知道这具体暗示什么。
下图为电路连接,没看出有什么问题。
 楼主| 发表于 2016-2-26 20:18:50 | 显示全部楼层
通过回读PROM中配置数据,可以确定配置数据已经加载到PROM中,就是上电后,PROM不能自动配置FPGA。
GMT+8, 2025-12-29 10:38 , Processed in 0.020881 second(s), 7 queries , Gzip On, Redis On.
