查看: 3971|回复: 2
[求助] GTX问题
发表于 2016-1-28 19:49:20 | 显示全部楼层 |阅读模式
我在例化GTX时,altera的C4芯片,用了2通道的收发器,
报警告:CMU altgx:altgx_inst|altgx_alt_c3gxb_component|cnt_unit0 is not connected to a GXB reconfig logic block, but the RX offset cancellation feature requires that it must be
请问有知道怎么解决的么,
谢谢
发表于 2016-1-28 22:43:50 | 显示全部楼层
The warning is told that you didn't connect reconfigure module to transceiver module.
发表于 2016-1-29 09:27:03 | 显示全部楼层
正解,要还把reconfigure加进去才行。也是要例化并连线的,还要注意对RST时序的要求。
GMT+8, 2025-12-27 20:28 , Processed in 0.013510 second(s), 4 queries , Gzip On, Redis On.
