查看: 15114|回复: 24
[资料] << Galaxy common Galaxy ICC not enabled>> Why this error?
发表于 2016-1-28 12:43:02 | 显示全部楼层 |阅读模式
Hi Friends,
I installed Synopsys ICC in 'Linux Mint 15 cinnamon' version (Not Debian version).
Used SCL 10.9.3 and ICC 2010.12 (AMD 64 & Common.tar files).
Generated valid license using EFA LicGen .4b.
my .bashrc file is below
export SYNOPSYS=/usr/synopsys
export SNPSLMD_LICENSE_FILE=27000@jithin-vm
export LM_LICENSE_FILE=/usr/synopsys/synopsys.dat
export SCL_HOME=/usr/synopsys/10.9.3/linux
export PATH=$SCL_HOME/binPATH
export ICC_HOME=/usr/synopsys/E-2010.12
export PATH=$ICC_HOME/binPATH
alias lmli3="/usr/synopsys/10.9.3/linux/bin/lmgrd -c /usr/synopsys/synopsys.dat -l ou5.log"
alias lmst3="/usr/synopsys/10.9.3/linux/bin/lmstat -c /usr/synopsys/synopsys.dat"
alias dc="dc_shell &"
alias icc="icc_shell -gui &"
my lmstat report is below
lmstat - Copyright (c) 1989-2006 Macrovision Europe Ltd. and/or Macrovision Corporation. All Rights Reserved.
Flexible License Manager status on Wed 1/27/2016 22:16
License server status: 27000@jithin-vm
    License file(s) on jithin-vm: /usr/synopsys/synopsys.dat:
jithin-vm: license server UP (MASTER) v10.8
Vendor daemon status (on jithin-vm):
   snpslmd: UP v10.8
After sourcing .bashrc file I got below error when I type icc_shell.
Unable to obtain features 'Galaxy-Common Galaxy-ICC '
Error: internal licensing error -92.
Fatal: Galaxy-Common+Galaxy-ICC is not enabled. (DCSH-1)
Exit IC Compiler!
Problem may due to the absence of Galaxy common and Galaxy ICC feature in my generated license.
Can you share any other ICC crack, with valid .src file for SCL 10.9.3
why this happens? Please help me
 楼主| 发表于 2016-1-28 16:22:43 | 显示全部楼层
My lmgrd file is below
  1. 22:15:46 (lmgrd) -----------------------------------------------
  2. 22:15:46 (lmgrd)   Please Note:
  3. 22:15:46 (lmgrd)
  4. 22:15:46 (lmgrd)   This log is intended for debug purposes only.
  5. 22:15:46 (lmgrd)   In order to capture accurate license
  6. 22:15:46 (lmgrd)   usage data into an organized repository,
  7. 22:15:46 (lmgrd)   please enable report logging. Use Macrovision's
  8. 22:15:46 (lmgrd)   software license administration  solution,
  9. 22:15:46 (lmgrd)   FLEXnet Manager, to  readily gain visibility
  10. 22:15:46 (lmgrd)   into license usage data and to create
  11. 22:15:46 (lmgrd)   insightful reports on critical information like
  12. 22:15:46 (lmgrd)   license availability and usage. FLEXnet Manager
  13. 22:15:46 (lmgrd)   can be fully automated to run these reports on
  14. 22:15:46 (lmgrd)   schedule and can be used to track license
  15. 22:15:46 (lmgrd)   servers and usage across a heterogeneous
  16. 22:15:46 (lmgrd)   network of servers including Windows NT, Linux
  17. 22:15:46 (lmgrd)   and UNIX. Contact Macrovision at
  18. 22:15:46 (lmgrd)   www.macrovision.com for more details on how to
  19. 22:15:46 (lmgrd)   obtain an evaluation copy of FLEXnet Manager
  20. 22:15:46 (lmgrd)   for your enterprise.
  21. 22:15:46 (lmgrd)
  22. 22:15:46 (lmgrd) -----------------------------------------------
  23. 22:15:46 (lmgrd)
  24. 22:15:46 (lmgrd)
  25. 22:15:46 (lmgrd) FLEXnet Licensing (v10.8.5.0 build 31891 i86_re3) started on jithin-vm (linux) (1/27/2016)
  26. 22:15:46 (lmgrd) Copyright (c) 1988-2006 Macrovision Europe Ltd. and/or Macrovision Corporation. All Rights Reserved.
  27. 22:15:46 (lmgrd) US Patents 5,390,297 and 5,671,412.
  28. 22:15:46 (lmgrd) World Wide Web:  http://www.macrovision.com
  29. 22:15:46 (lmgrd) License file(s): /usr/synopsys/synopsys.dat
  30. 22:15:46 (lmgrd) lmgrd tcp-port 27000
  31. 22:15:46 (lmgrd) Starting vendor daemons ...
  32. 22:15:46 (lmgrd) Started snpslmd (internet tcp_port 45297 pid 2789)
  33. 22:15:46 (snpslmd) FLEXnet Licensing version v10.8.5.3 build 59306 i86_re3
  34. 22:15:59 (snpslmd) Synopsys Corporate Licensing (SCL) Release: version SCL_10.9.3
  35. 22:16:00 (snpslmd) Server started on jithin-vm for:        SSS
  36. 22:16:00 (snpslmd) nanochar        hspice_pack        cosmos_other
  37. 22:16:00 (snpslmd) cxp                Synopsys_VCS_cmv Design-Expert
  38. 22:16:00 (snpslmd) him_mm_pi        CXp_GUI                CXp_Analysis
  39. 22:16:00 (snpslmd) CXp_CircuitEnvironment COSMOS_SCOPE        CmMonitor
  40. 22:16:00 (snpslmd) VCSiRuntimeLimited_Node VCSiRuntimeLimited_Net VMCCompiler_Node
  41. 22:16:00 (snpslmd) VMCRuntime_Node VMCEvaluation_Node VMCGeneratorUnlocked_Node
  42. 22:16:00 (snpslmd) VMCExpress_Compiler_Node VMCCompiler_Net VMCRuntime_Net
  43. 22:16:00 (snpslmd) VMCEvaluation_Net VMCGeneratorUnlocked_Net VMCExpress_Compiler_Net
  44. 22:16:00 (snpslmd) LMCSwift_Node        SNPS-Assertions VT_SystemVerilog
  45. 22:16:00 (snpslmd) VCSMXRunTime_Net VCSMXiRunTime_Net Magellan-Sim
  46. 22:16:00 (snpslmd) VT_SVAssertions VT_SVTestbench        VT_NativeTestbench
  47. 22:16:00 (snpslmd) VT_DVE                VT_UCLI                VT_LCA_Testbench
  48. 22:16:00 (snpslmd) PVCSCompiler_Net PVCSRuntime_Net VT_VCS_Power_Management
  49. 22:16:00 (snpslmd) VT_VCS_Checker        VT_VCS_Echo        RMAN_RUN
  50. 22:16:00 (snpslmd) VT_VCS_NTBE        XVVCDebugger        VT_UnifiedCoverage
  51. 22:16:00 (snpslmd) VT_64Bit        VT_OtherTechnology VT_NativeTBDebuggerGui
  52. 22:16:00 (snpslmd) VT_CBUG                VT_SVAssertionCompiler VT_SDebug
  53. 22:16:00 (snpslmd) VT_DVENTB        VT_Pioneer        VT_SYSTEMC21
  54. 22:16:00 (snpslmd) VT_LCA_Coverage VT_LCA_DEBUG        VT_LCA_Assertions
  55. 22:16:00 (snpslmd) VT_LCA_MixedSignal VT_DVE_COV        VT_VCS_Advanced_Features
  56. 22:16:00 (snpslmd) VT_VCS_BETA_Program VT_PVCSCompiler_Net DesignWare-ETHERNET
  57. 22:16:00 (snpslmd) Primepower        Primepower_gui        fpc_foundation
  58. 22:16:00 (snpslmd) fpc_pna                fpc_utils        fpc_special1
  59. 22:16:00 (snpslmd) fpc_special2        fpc_special3        Test-Validate
  60. 22:16:00 (snpslmd) Test-Accelerate-Max chiparch_migrate planet_migrate
  61. 22:16:00 (snpslmd) DesignWare-ARMCORES-tlm DesignWare-AMBA-tlm Test-LBIST-Integration
  62. 22:16:00 (snpslmd) VHDL-Compiler-Presto primepower_vcd        Test-Beta-7
  63. 22:16:00 (snpslmd) Test-Beta-8        Test-Beta-9        Test-STDVR
  64. 22:16:00 (snpslmd) Test-MBIST-Integration HDL-Compiler-SystemVerilog primepower_beta
  65. 22:16:00 (snpslmd) MV-Opt                PhysOpt-VH        Formality-TX
  66. 22:16:00 (snpslmd) Formality-Distributed PhysOpt-Integration PhysOpt-Beta-Milkyway
  67. 22:16:00 (snpslmd) PhysOpt-Beta-SI PhysOpt-Beta-CTS PhysOpt-Beta-Route
  68. 22:16:00 (snpslmd) Test-Fault-Max        PAW                PsynGui-ChipMap
  69. 22:16:00 (snpslmd) Formality-ESP        PhysOpt-XG        PsynGui-AARender
  70. 22:16:00 (snpslmd) Test-Compression-ATPG Test-Compression-Synthesis HDL-Compiler-Old
  71. 22:16:00 (snpslmd) VHDL-Compiler-Old Test-Mbist-Program Test-Mbist-Bitstream
  72. 22:16:00 (snpslmd) Galileo                Galileo-PSYN        Galileo-PnR
  73. 22:16:00 (snpslmd) Galileo-GUI        NanoTime        NanoTime-PathMill-Shared
  74. 22:16:00 (snpslmd) Galileo-Internal-Only PhysOpt-MV        Astro-MV
  75. 22:16:00 (snpslmd) Galaxy-GUI-PSYN Galaxy-GUI-PNR        Galaxy-Beta
  76. 22:16:00 (snpslmd) Galaxy-Internal-Only PrimeTime-New-Technology PrimeRail
  77. 22:16:00 (snpslmd) Power-Optimization-Beta1 Power-Optimization-Beta2 Formality-Beta1
  78. 22:16:00 (snpslmd) Formality-Beta2 Galaxy-MCMM        PrimeTime-PX
  79. 22:16:00 (snpslmd) DB-Mode                DC-Topographical snps_fs_nwave
  80. 22:16:00 (snpslmd) Pathmill-migrate Pathmill-plus-migrate NanoTime-ultra
  81. 22:16:00 (snpslmd) Galaxy-CCS        Galaxy_FP_Beta        Galaxy_MultiRoute4
  82. 22:16:00 (snpslmd) Galaxy_MultiRoute8 PrimeTime-VX        Galaxy-AdvRules
  83. 22:16:00 (snpslmd) Galaxy-FlipChip Galaxy-FP-Hier        Test-SDD-Timing
  84. 22:16:00 (snpslmd) Galaxy-AdvOpt        Galaxy-CTMesh        Galaxy-Zroute
  85. 22:16:00 (snpslmd) Test-Power        Test-Physical        DCT-Congestion
  86. 22:16:00 (snpslmd) DCT-GUI                DC-Extension        Galaxy-FP-MV
  87. 22:16:00 (snpslmd) Galaxy-FP-AdvCTS Galaxy-FP-AdvTech NCX
  88. 22:16:00 (snpslmd) Galaxy-SPG        PrimeTime-PX-Statistical PrimeTime-PX-New-Technology
  89. 22:16:00 (snpslmd) PrimeRail-New-Technology PrimeRail-static PrimeRail-adv
  90. 22:16:00 (snpslmd) Test-CompressionPlus-Syn Test-CompressionPlus-ATPG NCX-addon
  91. 22:16:00 (snpslmd) DC-FPGA-Add-On-to-DC DESIGNWARE-AMBA-VIP DESIGNWARE-I2C-VIP
  92. 22:16:00 (snpslmd) DESIGNWARE-REGRESSION DESIGNWARE-SIO-VIP DESIGNWARE-VERIFICATION
  93. 22:16:00 (snpslmd) DWC-AHB-ICTL-Source DWC-AHB-Source        DWC-AMBA-Fabric-Source
  94. 22:16:00 (snpslmd) DWC-APB-Advanced-Source DWC-APB-ICTL-Source DWC-APB-Periph-Source
  95. 22:16:00 (snpslmd) DWC-DMA-Controller-Source DWC-DMAC-Source DWC-GPIO-Source
  96. 22:16:00 (snpslmd) DWC-I2C-Source        DWC-INTC-CNTL-Source DWC-MEMCTL-Source
  97. 22:16:00 (snpslmd) DWC-RAP-Source        DWC-RTC-Source        DWC-SSI-Source
  98. 22:16:00 (snpslmd) DWC-TIMERS-Source DWC-UART-SRC        DWC-UART-Source
  99. 22:16:00 (snpslmd) DWC-WDT-Source        DesignWare-MEMCTL-Source JupiterXT_VF
  100. 22:16:00 (snpslmd) SABER_GUIDE        VT_LCA_Language VT_NTB
  101. 22:16:00 (snpslmd) VT_SVDesign        aPrv                sharp
  102. 22:16:00 (snpslmd) simif                VHDLAMS_TAURILI VHDLAMS_TAURI
  103. 22:16:00 (snpslmd) MODPEX_AWB        MODPEX_CTC        MODPEX_ELDO
  104. 22:16:00 (snpslmd) MODPEX_MARELLI        MODPEX_NOPOWER        MODPEX_PTFT
  105. 22:16:00 (snpslmd) MODPEX_SABER        MODPEX_STATIS        MODPEX_TVS
  106. 22:16:00 (snpslmd) MONTE_CARLO        MONTE_CARLO_MEMSSE MOS_TOOL
  107. 22:16:00 (snpslmd) MOS_TOOL_MEMSSE MOTOR_DCPM_TOOL MOTOR_DCPM_TOOL_MEMSSE
  108. 22:16:00 (snpslmd) OPT_TEMPLATE_LIB_MEMSSE PLACEHOLDER        PNET_LIBRARY
  109. 22:16:00 (snpslmd) PNEUM_HYD_PRG1        PNEU_HYD_LIBRARY POLARIS_SCOPE
  110. 22:16:00 (snpslmd) POLARIS_X        POWER_EXPRESS        SABER_SKETCH_NETLISTER
  111. 22:16:00 (snpslmd) SABER_SKETCH_NETLISTER_MEMSSE SABER_TSP        SABER_VERILOG_MM
  112. 22:16:00 (snpslmd) SABER_VERILOG_MM_MEMSSE SABER_VHDLAMS        SABER_VHDLAMS_MEMSSE
  113. 22:16:00 (snpslmd) SABER_VIEWSIM_MM SABER_VIEWSIM_MM_MEMSSE SCAN_TOOL
  114. 22:16:00 (snpslmd) SCAN_TOOL_MEMSSE SENSITIVITY        SENSITIVITY_MEMSSE
  115. 22:16:00 (snpslmd) SJCL_LIBRARY        SPECTRAL        SPECTRAL_MEMSSE
  116. 22:16:00 (snpslmd) STATEBENCH        STRESS                STRESS_MEMSSE
  117. 22:16:00 (snpslmd) SYMLIB                SYMLIB_JAPANESE SYMLIB_JAPANESE_MEMSSE
  118. 22:16:00 (snpslmd) SYMLIB_MEMSSE        SYMLIB_PLUS        SYMLIB_PLUS_MEMSSE
  119. 22:16:00 (snpslmd) SABERRT_ADI        SABERRT_ADI_MEMSSE SABERRT_AP2633
  120. 22:16:00 (snpslmd) SABERRT_FE        SABERRT_FE_MEMSSE SABERRT_HIL
  121. 22:16:00 (snpslmd) SABERRT_HIL_MEMSSE SABER_DEV_MM        SABER_GUIDE_MEMSSE
  122. 22:16:00 (snpslmd) SABER_INTERFACE_MEMSSE SABER_LEAPFROG_MM SABER_MODELSIM_MM
  123. 22:16:00 (snpslmd) SABER_MODELSIM_MM_MEMSSE SABER_MODELSIM_PLUS_MM SABER_MODELSIM_PLUS_MM_MEMSSE
  124. 22:16:00 (snpslmd) SABER_MODELSIM_VHDL_MM SABER_MODELSIM_VHDL_MM_MEMSSE SABER_MODELSIM_VLOG_MM
  125. 22:16:00 (snpslmd) SABER_PLUGNSIM_MM SABER_QSIM_MM        SABER_QVSPRO_MM
  126. 22:16:00 (snpslmd) SABER_RT_MM        SABER_RT_MM_MEMSSE SABER_RUNTIME
  127. 22:16:00 (snpslmd) SABER_SCOPE_MEMSSE SABER_SIMMATRIX_MM SABER_SIMULATOR_MEMSSE
  128. 22:16:00 (snpslmd) SABER_SKETCH_MEMSSE SYMLIB_POWER        SYMLIB_POWER_MEMSSE
  129. 22:16:00 (snpslmd) TESTIFY                TESTIFY_MEMSSE        TESTIFY_NETLISTER_MEMSSE
  130. 22:16:00 (snpslmd) THERM_TOOL        THERM_TOOL_MEMSSE TLU_TOOL
  131. 22:16:00 (snpslmd) TLU_TOOL_MEMSSE TR_ANALYSIS        TR_ANALYSIS_MEMSSE
  132. 22:16:00 (snpslmd) VEHICLE_ELECTRIC_LIB_MEMSSE VENDOR_LIBRARY        VENDOR_LIBRARY_MEMSSE
  133. 22:16:00 (snpslmd) VERIAS_HSPICE_COMPILER VERIAS_SIMULATOR VIEWLOGIC_FRAMEWAY
  134. 22:16:00 (snpslmd) VIEWLOGIC_FRAMEWAY_MEMSSE VIEWLOGIC_NET_MEMSSE WF_API_HSPICE
  135. 22:16:00 (snpslmd) WF_API_HSPICE_MEMSSE WF_API_MEMSSE        WF_API_STARSIM
  136. 22:16:00 (snpslmd) WF_API_STARSIM_MEMSSE EDIF_NETLISTER        EDIF_NETLISTER_MEMSSE
  137. 22:16:00 (snpslmd) EXPT_EDITOR        MAST_COMPILER        MEASURE
  138. 22:16:00 (snpslmd) MEASURE_MEMSSE        MEMS                MENTOR_FRAMEWAY
  139. 22:16:00 (snpslmd) MENTOR_FRAMEWAY_MEMSSE MENTOR_NETLISTER MENTOR_NETLISTER_MEMSSE
  140. 22:16:00 (snpslmd) MICROCOSM_LIB        MICROCOSM_LIB2        MICROCOSM_LIB2_MEMSSE
  141. 22:16:00 (snpslmd) MICROCOSM_LIB3        MICROCOSM_LIB3_MEMSSE MICROCOSM_LIB4
  142. 22:16:00 (snpslmd) MICROCOSM_LIB4_MEMSSE MICROCOSM_LIB5        MICROCOSM_LIB5_MEMSSE
  143. 22:16:00 (snpslmd) MICROCOSM_LIB6        MICROCOSM_LIB6_MEMSSE MICROCOSM_LIB7
  144. 22:16:00 (snpslmd) MICROCOSM_LIB7_MEMSSE MICROCOSM_LIB_MEMSSE MODEL_ARCHITECT
  145. 22:16:00 (snpslmd) MODEL_ENCRYPTION_MEMSSE MODEL_SYNTHESIS_MEMSSE MODPEX
  146. 22:16:00 (snpslmd) MODPEX_AQUEDUCT MODPEX_ASIM        MODPEX_ATFT
  147. 22:16:00 (snpslmd) HARNESS_CATIA        HARNESS_MCADREAD HARNESS_PROCABLE
  148. 22:16:00 (snpslmd) HARNESS_UNIGRAPHICS HSPICE_MODEL_LIBRARY_MEMSSE IC_DESIGN_LIB
  149. 22:16:00 (snpslmd) IMECH_LIBRARY        IQBUS_AUTHOR_MEMSSE IQBUS_DESIGNER
  150. 22:16:00 (snpslmd) IQBUS_LIB_MEMSSE LINK_MATLAB        LINK_MATLAB_MEMSSE
  151. 22:16:00 (snpslmd) LINK_XMATH        LOAD_TOOL        LOAD_TOOL_MEMSSE
  152. 22:16:00 (snpslmd) LSA_MEMSSE        LSA                LTX_LIBRARY
  153. 22:16:00 (snpslmd) COVENTOR_LIB10        COVENTOR_LIB10_MEMSSE COVENTOR_LIB11
  154. 22:16:00 (snpslmd) COVENTOR_LIB11_MEMSSE COVENTOR_LIB12        COVENTOR_LIB12_MEMSSE
  155. 22:16:00 (snpslmd) COVENTOR_LIB13        COVENTOR_LIB13_MEMSSE COVENTOR_LIB14
  156. 22:16:00 (snpslmd) COVENTOR_LIB14_MEMSSE COVENTOR_LIB15        COVENTOR_LIB15_MEMSSE
  157. 22:16:00 (snpslmd) COVENTOR_LIB8        COVENTOR_LIB8_MEMSSE COVENTOR_LIB9
  158. 22:16:00 (snpslmd) COVENTOR_LIB9_MEMSSE DESIGNSTAR        DESIGNSTAR_NET
  159. 22:16:00 (snpslmd) DIODE_TOOL        DIODE_TOOL_MEMSSE DRCYCLE_TOOL
  160. 22:16:00 (snpslmd) DRCYCLE_TOOL_MEMSSE ABB_CHCRC_LIBRARY AIM_DEBUG_MEMSSE
  161. 22:16:00 (snpslmd) AIM_DEVELOPER_MEMSSE AUT_NUMBER_MAJOR_PACKAGES BASIC_ANALYSES
  162. 22:16:00 (snpslmd) BASIC_ANALYSES_MEMSSE BATCH_MEASURE        BATCH_MEASURE_MEMSSE
  163. 22:16:00 (snpslmd) BATT_TOOL        BATT_TOOL_MEMSSE BETA_LIBRARY
  164. 22:16:00 (snpslmd) BUILD_DATE        BUILD_NUMBER        BUNDLE_MCAD_PROJECTION
  165. 22:16:00 (snpslmd) CADENCE_DIVA_NETLISTER CADENCE_FRAMEWAY CADENCE_FRAMEWAY_MEMSSE
  166. 22:16:00 (snpslmd) CADENCE_NETLISTER CADENCE_NETLISTER_MEMSSE COMPONENT_LIBRARY_MEMSSE
  167. 22:16:00 (snpslmd) CONCEPT_FRAMEWAY CONCEPT_NETLISTER CORENL_CHAR
  168. 22:16:00 (snpslmd) CORENL_CHAR_MEMSSE COSMOS_GUIDE        COSMOS_SKETCH
  169. 22:16:00 (snpslmd) COSMOS_SKETCH_BACK_ANN COSMOS_SKETCH_NETLISTER EXPT_EDITOR_MEMSSE
  170. 22:16:00 (snpslmd) EXPT_EDITOR_PLUS EXPT_EDITOR_PLUS_MEMSSE FAILURE_MODE
  171. 22:16:00 (snpslmd) FAILURE_MODE_MEMSSE FASTPARTS        FUSE_CHAR
  172. 22:16:00 (snpslmd) FUSE_CHAR_MEMSSE XC4000E                XC4000EX
  173. 22:16:00 (snpslmd) XC4000L                XC4000XL        XC4000XLA
  174. 22:16:00 (snpslmd) XC4000XV        XC5200                XC9500
  175. 22:16:00 (snpslmd) XC9500XL        XC9500XV        xp
  176. 22:16:00 (snpslmd) XVCSDebugger        XVCSiDebugger        VSS-CompiledSim
  177. 22:16:00 (snpslmd) VSS-Debugger        VSS-Falcon-Interface VSS-GateSim
  178. 22:16:00 (snpslmd) VSS-LAI-Models        VSS-Lib-Tools        VSS-LMSI
  179. 22:16:00 (snpslmd) VSS-Model-Developer VSS-NEC-Tran        VSS-SDF-Interface
  180. 22:16:00 (snpslmd) VSS-SGE-Tool        VSS-Simulator        VSS-SmartModels
  181. 22:16:00 (snpslmd) VSS-SPC                VSS-Tran        VSS-Utilities
  182. 22:16:00 (snpslmd) VSS-Verilog-PLI VSS-VIP-Interface VSS-Wave-Display
  183. 22:16:00 (snpslmd) VSS-XP-Accelerator VT_AssertionIP        VT_Assertions
  184. 22:16:00 (snpslmd) VT_AssertionsRuntime VT_Coverage        VT_CoverageRuntime
  185. 22:16:00 (snpslmd) VT_CoverageURG        VT_Testbench        VT_TestbenchRuntime
  186. 22:16:00 (snpslmd) VT_VCS_BETA_Features VT_VCS_LCA_Features VT_Visual
  187. 22:16:00 (snpslmd) vtran                WhatIfAnalysis        WRITE
  188. 22:16:00 (snpslmd) XC3000                XC4000                VIRTEXE
  189. 22:16:00 (snpslmd) VIRTEXEA        Vivace-Code-Generator Vivace-Core
  190. 22:16:00 (snpslmd) Vivace-Debug        Vivace-Elaborator Vivace-Expert
  191. 22:16:00 (snpslmd) Vivace-Express        Vivace-GUI        Vivace-HDL-Analyzer
  192. 22:16:00 (snpslmd) Vivace-Model-Compiler Vivace-Pro        Vivace-Simulator
  193. 22:16:00 (snpslmd) Vivace-VHDL-Analyzer vlog_epic_pif        vlog2e
  194. 22:16:00 (snpslmd) vlsi2000        vlsi500                VMCCompiler
  195. 22:16:00 (snpslmd) VMCCore                VMCEvaluation        VMCExpress_Compiler
  196. 22:16:00 (snpslmd) VMCGeneratorUnlocked VMCRuntime        VPC
  197. 22:16:00 (snpslmd) vsea-calib_all        VSP_DRIVER        VSS-Analyzer
  198. 22:16:00 (snpslmd) VSS-Backplane        VSS-Cadence-Interface VSS-CLI
  199. 22:16:00 (snpslmd) vera_comp        vera_debug        vera_ip
  200. 22:16:00 (snpslmd) vera_rtime        Verdi                Verification-Token
  201. 22:16:00 (snpslmd) Verilog                verilog_writer        Verilog-Netlist-Writer
  202. 22:16:00 (snpslmd) Verilog-Parser        Verilog-To-BE        Verilog-VirSim
  203. 22:16:00 (snpslmd) vertue                vhdl_compiler        VHDL-Analyzer
  204. 22:16:00 (snpslmd) VHDL-Compiler        VHDL-Cycle-Sim        VHDL-Elaborator
  205. 22:16:00 (snpslmd) VHDL-Event-Sim        VHDLi-Elaborator VHDLi-Event-Sim
  206. 22:16:00 (snpslmd) VHDL-Netlist-Writer VHDL-ScSim        VHDL-To-BE
  207. 22:16:00 (snpslmd) VHDL-Tools        VHDL-VirSim        VHMC-Eval
  208. 22:16:00 (snpslmd) VHMC-GenUnlocked VHMC-Runtime        viewlogic
  209. 22:16:00 (snpslmd) viewlogic_epic        VIEWLOGIC_NET        VirSim
  210. 22:16:00 (snpslmd) VIRTEX                VIRTEX2                VIRTEX2P
  211. 22:16:00 (snpslmd) VCSNativeCode        VCSNativeCode_Net VCSNativeCode_Node
  212. 22:16:00 (snpslmd) VCSOldPostProcDebugger_Net VCSOldPostProcDebugger_Node VCSParallelCompiler
  213. 22:16:00 (snpslmd) VCSParallelCompiler_Net VCSParallelCompiler_Node VCSParallelRuntime
  214. 22:16:00 (snpslmd) VCSParallelRuntime_Net VCSParallelRuntime_Node VCSParallelThread
  215. 22:16:00 (snpslmd) VCSParallelThread_Net VCSParallelThread_Node VCSPostProcDebugger
  216. 22:16:00 (snpslmd) VCSPostProcDebugger_Net VCSPostProcDebugger_Node VCSRuntime
  217. 22:16:00 (snpslmd) VCSRuntime_Net        VCSRuntime_Node VCSRuntimeLimited
  218. 22:16:00 (snpslmd) VCSRuntimeLimited_Net VCSRuntimeLimited_Node VCSStd
  219. 22:16:00 (snpslmd) VCSStd_Net        VCSStd_Node        VCSTools
  220. 22:16:00 (snpslmd) VCSTools_Net        VCSTools_Node        VDesktop-Debug
  221. 22:16:00 (snpslmd) VDesktop-GUI        VDesktop-VCDTrans VDesktop-Verilog
  222. 22:16:00 (snpslmd) VDesktop-VHDL        VEHICLE_ELECTRIC_LIB Vera
  223. 22:16:00 (snpslmd) Ultra37000        VANTIS                vcd2e
  224. 22:16:00 (snpslmd) vcsace                VCSAMSCompiler        VCSAMSCompiler_Net
  225. 22:16:00 (snpslmd) VCSAMSRuntime        VCSAMSRuntime_Net VCSCompile
  226. 22:16:00 (snpslmd) VCSCompile_Net        VCSCompile_Node VCSCompiler
  227. 22:16:00 (snpslmd) VCSCompiler_Net VCSCompiler_Node VCSDebugger
  228. 22:16:00 (snpslmd) VCSDebugger_Net VCSDebugger_Node VCS-Express-Compile
  229. 22:16:00 (snpslmd) VCS-Express-Runtime VCSiCompile        VCSiCompile_Net
  230. 22:16:00 (snpslmd) VCSiCompile_Node VCSiCompiler        VCSiCompiler_Net
  231. 22:16:00 (snpslmd) VCSiCompiler_Node VCSiDebugger        VCSiDebugger_Net
  232. 22:16:00 (snpslmd) VCSiDebugger_Node VCSiRuntime        VCSiRuntime_Net
  233. 22:16:00 (snpslmd) VCSiRuntime_Net(3) VCSiRuntime_Node VCSiRuntimeLimited
  234. 22:16:00 (snpslmd) VCSlm_Hm        VCSlm_Hm_Net        VCSlm_Hm_Node
  235. 22:16:00 (snpslmd) Test-Mbist-Algorithm Test-Mbist-CAM        Test-Mbist-Diagnosis
  236. 22:16:00 (snpslmd) Test-Mbist-DRAM Test-Mbist-FLASH Test-Mbist-Multiport
  237. 22:16:00 (snpslmd) Test-PR-1        Test-PR-2        Test-PR-3
  238. 22:16:00 (snpslmd) Test-PR-4        Test-RTL-Check        Test-RTL-Tristate
  239. 22:16:00 (snpslmd) Test-ScanRoute        TestSim                TestVE
  240. 22:16:00 (snpslmd) tfm                timemill        timemill/ace
  241. 22:16:00 (snpslmd) timemill/av        timemill/bcx        timemill/bdc
  242. 22:16:00 (snpslmd) timemill/beta_status timemill/btm        timemill/csx
  243. 22:16:00 (snpslmd) timemill/internal_use timemill/msx        timemill/nsaddon
  244. 22:16:00 (snpslmd) TimingAnalysis        TLM_Synthesis        TRUE
  245. 22:16:00 (snpslmd) tSchema                turboSchema        turboState
  246. 22:16:00 (snpslmd) turboTracer        TurboWave        turbowave_epic
  247. 22:16:00 (snpslmd) Test-BIST        Test-BSDL        Test-CA
  248. 22:16:00 (snpslmd) Test-CA-2        Test-CA-3        Test-CA-4
  249. 22:16:00 (snpslmd) Test-Compile        Test-Compile-Max Test-Compiler
  250. 22:16:00 (snpslmd) Test-Compile-Remodel Test-Compiler-Plus Test-Compiler-Remodel
  251. 22:16:00 (snpslmd) Test-Compile-Share Test-Core-Integration Test-Core-Wrapper
  252. 22:16:00 (snpslmd) Test-CTL-Model        Test-Custom-Protocols Test-Delay
  253. 22:16:00 (snpslmd) TestDesignCorrelation Test-DFTC-TMAX        Test-DFT-Top
  254. 22:16:00 (snpslmd) Test-Diagnosis        Test-Eval        Test-Faultsim
  255. 22:16:00 (snpslmd) Test-Faultsim-8L Test-Format        Test-IDDQ
  256. 22:16:00 (snpslmd) Test-IEEE-Std-1149-1 TESTIFY_NETLISTER testing
  257. 22:16:00 (snpslmd) Test-LBIST-ATPG Test-LBIST-Synthesis Test-Library
  258. 22:16:00 (snpslmd) TestManager        Test-Map        Test-Mbist
  259. 22:16:00 (snpslmd) SynLib-Seq        SynLib-VerilogSimMdl SynLib-VHDLSimMdl
  260. 22:16:00 (snpslmd) Synopsys        Synopsys-Queue        Synopsys-Release
  261. 22:16:00 (snpslmd) TBM-Manager-UI        TBM-VSS-Check        TBS
  262. 22:16:00 (snpslmd) TC-Beta                TDL-Interface        TDL-Reader
  263. 22:16:00 (snpslmd) TDL-Writer        Tdx_all                techviewer
  264. 22:16:00 (snpslmd) Tecplot_all        TecplotSmall_all Ted_all
  265. 22:16:00 (snpslmd) TedSmall_all        Test-Accelerator Test-Analysis
  266. 22:16:00 (snpslmd) Test-Analysis-GUI Test-Analysis-RTL Test-ATPG
  267. 22:16:00 (snpslmd) Test-ATPG-30        Test-ATPG-Limited Test-ATPG-Max
  268. 22:16:00 (snpslmd) Test-ATPG-PRO        Test-ATPG-Ultra Test-ATPG-XP
  269. 22:16:00 (snpslmd) Test-Beta        Test-Beta-2        Test-Beta-3
  270. 22:16:00 (snpslmd) Test-Beta-4        Test-Beta-5        Test-Beta-6
  271. 22:16:00 (snpslmd) stars_aryred        stars_cmi        stars_csdf
  272. 22:16:00 (snpslmd) stars_hsplnk        stars_ish        stars_linred
  273. 22:16:00 (snpslmd) stars_mr        stars_wsf        starsim
  274. 22:16:00 (snpslmd) starsimxt        STAR-SYN2STAR        start_aed
  275. 22:16:00 (snpslmd) start_analysis        start_bin        STAR-TCAD
  276. 22:16:00 (snpslmd) startime        STAR-XREF        StarXtract
  277. 22:16:00 (snpslmd) sup2lig_all        swb_all                swb-advanced_all
  278. 22:16:00 (snpslmd) sx_cdslink        sx_chip                sx_daiclink
  279. 22:16:00 (snpslmd) sx_drc                sx_wva                Sxtract_all
  280. 22:16:00 (snpslmd) SYNARIO                SynLib-AdvMath        SynLib-ALU
  281. 22:16:00 (snpslmd) SynLib-Control        SynLib-DSPFIR        SynLib-Eval
  282. 22:16:00 (snpslmd) SynLib-FltTol        SynLib-PCIbasic Syn-Library-Compiler
  283. 22:16:00 (snpslmd) sprocessmpp_all sprocess-parallel_all sprocess-parallel4_all
  284. 22:16:00 (snpslmd) sptopography2d_all ST_LIBRARY        Stamp-Compiler
  285. 22:16:00 (snpslmd) STAR-ASCII        STAR-CR                STAR-DC
  286. 22:16:00 (snpslmd) STAR-EX                STAR-EX_ERC        STAR-FILTER
  287. 22:16:00 (snpslmd) STAR-GAZER        STAR-LD2LTL        STAR-R
  288. 22:16:00 (snpslmd) STAR-RC                STAR-RC2        STAR-RC2_MANAGER
  289. 22:16:00 (snpslmd) STAR-RC2-AEO        STAR-RC2-ANAL        STAR-RC2-ASCII
  290. 22:16:00 (snpslmd) STAR-RC2-CLOCK        STAR-RC2-DB        STAR-RC2-DISTRIB10
  291. 22:16:00 (snpslmd) STAR-RC2-GUI        STAR-RC2-NETLIST STAR-RC2-PROBER
  292. 22:16:00 (snpslmd) STAR-RC2-TCAD        STAR-RC2-VIEWER STAR-RC2-XSTOR1
  293. 22:16:00 (snpslmd) STAR-RC2-XSTOR2 STAR-RC2-XTRACT STAR-RC2-XTR-AEO
  294. 22:16:00 (snpslmd) STAR-RC-GUI        STAR-R-GUI        stars_analog
  295. 22:16:00 (snpslmd) SGE-Tool        SGE-Verilog-Interface SGE-VHDL-Interface
  296. 22:16:00 (snpslmd) ShortCut-DC-Expert ShortCut-DC-Pro Shortcut-FPGA
  297. 22:16:00 (snpslmd) Siloti                Siloti_fe        Siloti_o2
  298. 22:16:00 (snpslmd) SilVE                SimVE                simwave
  299. 22:16:00 (snpslmd) simwave_epic        SKDB_Import        SNPS-CSL
  300. 22:16:00 (snpslmd) SNPS-Keygen        SNPS-MOTIVE        SolarGAII
  301. 22:16:00 (snpslmd) SolarII                sparallel_all        SPARTAN
  302. 22:16:00 (snpslmd) SPARTAN2        SPARTAN2E        SPARTANXL
  303. 22:16:00 (snpslmd) spcmcalib_all        spcmstd_all        spice_explorer
  304. 22:16:00 (snpslmd) spice_parser        sprocess_all        sprocess2d_all
  305. 22:16:00 (snpslmd) sprocess2dmc_all sprocess3d_all        sprocess3dmc_all
  306. 22:16:00 (snpslmd) sprocess-an-imp3d_all sprocesskmc_all sprocessmc_all
  307. 22:16:00 (snpslmd) SC-HLS                scratch                SC-RTL
  308. 22:16:00 (snpslmd) sda                sde_all                sde3d_all
  309. 22:16:00 (snpslmd) sdevcie-laser_all sdevice_all        sdevice-3d_all
  310. 22:16:00 (snpslmd) sdevice-densitygrad_all sdevice-ferro_all sdevice-floatinggate_all
  311. 22:16:00 (snpslmd) sdevice-gateleakage_all sdevice-hetero_all sdevice-hydro_all
  312. 22:16:00 (snpslmd) sdevice-kpgain_all sdevice-laser_all sdevice-led_all
  313. 22:16:00 (snpslmd) sdevice-mixedmode_all sdevicemonosemicond_all sdevice-montecarlo_all
  314. 22:16:00 (snpslmd) sdevice-noise_all sdevice-optic_all sdevice-parallel_all
  315. 22:16:00 (snpslmd) sdevice-parallel4_all sdevice-pmi_all sdevice-radiation_all
  316. 22:16:00 (snpslmd) sdevice-reliability_all sdevice-schroedinger_all sdevice-sige_all
  317. 22:16:00 (snpslmd) sdevice-thermo_all sdevice-traps_all sdevice-vectoroptic_all
  318. 22:16:00 (snpslmd) SEU                SGE-DC-Interface SGE-EDIF-Interface
  319. 22:16:00 (snpslmd) railmill/gbx        railmill/internal_use railmill/msx
  320. 22:16:00 (snpslmd) railmill/power        railmill/rvfp        railmill/snx
  321. 22:16:00 (snpslmd) railmill/spnx        railmill/ssnx        RCXTEO
  322. 22:16:00 (snpslmd) Reusner                rm_eee                route66
  323. 22:16:00 (snpslmd) RouteCompiler        rslv3d                rslv3dviewer
  324. 22:16:00 (snpslmd) RT54SXS                RTL-Analyzer        RTL-Analyzer-DAP
  325. 22:16:00 (snpslmd) RTL-Analyzer-Shell RTL-Analyzer-Shell-DAP RtlGateCorrelation
  326. 22:16:00 (snpslmd) RTL-Power-Analysis SABER_BUNDLE        SABER_DEV_MMP
  327. 22:16:00 (snpslmd) SABER_HARNESS        SABER_HARNESS_NETLISTER SABER_IF
  328. 22:16:00 (snpslmd) SABER_INTERFACE SABER_SCOPE        SABER_SCOPE_NETLIST
  329. 22:16:00 (snpslmd) SABER_SIMULATOR SABER_SKETCH        SABER_SKETCH_NETLIST
  330. 22:16:00 (snpslmd) SC-BC                SC-COSIM        SC-FPGA
  331. 22:16:00 (snpslmd) PPPRT                PrimeTime        PrimeTime_gui
  332. 22:16:00 (snpslmd) PrimeTime-Plus        PrimeTime-SI        prmspx_visual_all
  333. 22:16:00 (snpslmd) Prolyt_all        ProMA-L1        ProMA-L2
  334. 22:16:00 (snpslmd) ProMA-LD        ProMA-P1        ProMA-P2
  335. 22:16:00 (snpslmd) ProMA-PD        Protocol-Compiler-Analysis Protocol-Compiler-COutput
  336. 22:16:00 (snpslmd) Protocol-Compiler-FML Protocol-Compiler-Synth Protocol-Compiler-UI
  337. 22:16:00 (snpslmd) provhdl_checker PS_CTS                PS_Extraction
  338. 22:16:00 (snpslmd) PS_Noise_Optimization psf                PSG-SDE
  339. 22:16:00 (snpslmd) pwga                QLOGIC                Quantum38k
  340. 22:16:00 (snpslmd) rad                RailMacro        railmill
  341. 22:16:00 (snpslmd) railmill/ace        railmill/av        railmill/bcx
  342. 22:16:00 (snpslmd) railmill/beta_status PhysOpt-Extraction PhysOpt-GUI
  343. 22:16:00 (snpslmd) PhysOpt-Hierarchy PhysOpt-Onroute PhysOpt-Parallel
  344. 22:16:00 (snpslmd) PhysOpt-Route        PhysOpt-Route-TD PhysOpt-Routing
  345. 22:16:00 (snpslmd) PhysOpt-SI        PhysOpt-Ultra        PlanetPL
  346. 22:16:00 (snpslmd) PlanetRTL        pmga                polaris-cbs
  347. 22:16:00 (snpslmd) polaris-com        polaris-int        polaris-mt
  348. 22:16:00 (snpslmd) polaris-signalscan Power-Analysis        powerarc
  349. 22:16:00 (snpslmd) powergate        Power-Optimization Power-Optimization-Upgrade
  350. 22:16:00 (snpslmd) primerail_hsim        powrmill        powrmill/ace
  351. 22:16:00 (snpslmd) powrmill/av        powrmill/bcx        powrmill/beta_status
  352. 22:16:00 (snpslmd) powrmill/btm        powrmill/csx        powrmill/internal_use
  353. 22:16:00 (snpslmd) powrmill/msx        powrmill/nsaddon powrmill/power
  354. 22:16:00 (snpslmd) powrmill/svcz        powrmill/vlog_a nProp
  355. 22:16:00 (snpslmd) nSC                nSchema                nSchemaOnly
  356. 22:16:00 (snpslmd) nState                nTE                nTiming
  357. 22:16:00 (snpslmd) nTrace                nTree                nTX
  358. 22:16:00 (snpslmd) nWave                OPT_TEMPLATE_LIB OptimISE-DOE_all
  359. 22:16:00 (snpslmd) OptimISE-Iterative_all OptimISE-RSMOpt_all OptimISE-Statistical_all
  360. 22:16:00 (snpslmd) ORCA2A                ORCA2TB                ORCA3C
  361. 22:16:00 (snpslmd) ORCA3FPSC        ORCA3L                ORCA4E
  362. 22:16:00 (snpslmd) ParDiSo_all        Parse-Tree-Translator pathfinder
  363. 22:16:00 (snpslmd) pathmill        pathmill/cso        pathmill/ctx
  364. 22:16:00 (snpslmd) pathmill/dsx        pathmill/pfx        pathmill/sfx
  365. 22:16:00 (snpslmd) pathmill_plus        PC-Expert        PhysOpt
  366. 22:16:00 (snpslmd) PhysOpt-Beta        PhysOpt-ClockTree MVerilog
  367. 22:16:00 (snpslmd) MWAPIaccess        MWAPIdev        nAnalyzer
  368. 22:16:00 (snpslmd) nanosim                nanosim/ace        nanosim/ace_cosim
  369. 22:16:00 (snpslmd) nanosim/av        nanosim/bcx        nanosim/bdc
  370. 22:16:00 (snpslmd) nanosim/beta_status nanosim/btm        nanosim/gui
  371. 22:16:00 (snpslmd) nanosim/internal_use nanosim/msx        nanosim/postlayout_har
  372. 22:16:00 (snpslmd) nanosim/power        nanosim/vlog_a        nBench
  373. 22:16:00 (snpslmd) nClock                nCompare        nECO
  374. 22:16:00 (snpslmd) nESL                NET-TRAN        nlcc
  375. 22:16:00 (snpslmd) nLint                nLint_either        nLint_mixed
  376. 22:16:00 (snpslmd) nLint_sv        nLint_verilog        nLint_vhdl
  377. 22:16:00 (snpslmd) nMonitor        Noffset-2D_all        Noffset-3D_all
  378. 22:16:00 (snpslmd) Nova-ExploreRTL-Verilog npi                MC-Pro-RP
  379. 22:16:00 (snpslmd) MC-Retime        MDataCheck        MDataPrep
  380. 22:16:00 (snpslmd) MDynLink        MEMPRO                MEMPRO-LIB
  381. 22:16:00 (snpslmd) mentor/f        Mentor-Interface MERCURY
  382. 22:16:00 (snpslmd) Mesh1D_all        Mesh2D_all        Mesh3D_all
  383. 22:16:00 (snpslmd) metaencrypt3des metawaves        metawaveswin
  384. 22:16:00 (snpslmd) mg_falcon_epic        MIF-Reader        MIF-Writer
  385. 22:16:00 (snpslmd) Milkyway        Milkyway-Interface Millennium-ATPG-EE
  386. 22:16:00 (snpslmd) Millennium-ATPG-STD Millennium-Beta Millennium-DRC
  387. 22:16:00 (snpslmd) Millennium-Eval Millennium-FS        milltools
  388. 22:16:00 (snpslmd) misc                Mixed-Language        Mixed-Paradigm
  389. 22:16:00 (snpslmd) MODEL_ENCRYPTION MODEL_SYNTHESIS MOTIVE-PrimeTime
  390. 22:16:00 (snpslmd) mti_epic        MV-Astro-Opt        LigamentFE_all
  391. 22:16:00 (snpslmd) LINYE                LMCSwift        LMCSwift_Net
  392. 22:16:00 (snpslmd) LSI-Interface        lsim_parser        LSS4E
  393. 22:16:00 (snpslmd) LTL-100                LTL-100_CIF        LTL-100_GDS
  394. 22:16:00 (snpslmd) LTL-100_NDW        MACH1                MACH2
  395. 22:16:00 (snpslmd) MACH4                MACH5                MAdv
  396. 22:16:00 (snpslmd) Mars                MAX3000A        MAX7000
  397. 22:16:00 (snpslmd) MAX7000A        MAX7000AE        MAX7000B
  398. 22:16:00 (snpslmd) MAX7000E        MAX7000S        MAX9000
  399. 22:16:00 (snpslmd) MCD                MCE                MCE-Base
  400. 22:16:00 (snpslmd) MCE-Eval        MCE-Lib-ALU        MCE-Lib-Arith1
  401. 22:16:00 (snpslmd) MCE-Lib-Arith2        MCE-Lib-Arith3        MCE-Lib-Logic
  402. 22:16:00 (snpslmd) MC-Pro                ispLSI5K        ispLSI6K
  403. 22:16:00 (snpslmd) ispLSI8K        ispMACH4000        JUAdvOptA
  404. 22:16:00 (snpslmd) JUAdvOptB        JUAOPAS                JUAPlan
  405. 22:16:00 (snpslmd) JUATime                JUAUD                JUClock
  406. 22:16:00 (snpslmd) JUDP                JUOPAS                Jupiter
  407. 22:16:00 (snpslmd) JupiterXT        JUPlan                JUTime
  408. 22:16:00 (snpslmd) JUUD                JUVS                Key-Generator
  409. 22:16:00 (snpslmd) Laker_AMS        Laker_iDRC        Laker_iLVS
  410. 22:16:00 (snpslmd) Laker_L1        Laker_L2        Laker_L3
  411. 22:16:00 (snpslmd) Laker_T1        Laker_T1_LE        Laker_Viewer
  412. 22:16:00 (snpslmd) Leakage-Power        leda_checker        leda_mx
  413. 22:16:00 (snpslmd) leda-mx                libarc                Library-Compiler
  414. 22:16:00 (snpslmd) Ligament_all        HLS-FPGA-SystemC HLS-SystemC
  415. 22:16:00 (snpslmd) hsim                hsim-cosim        hsim-xl
  416. 22:16:00 (snpslmd) hspice                hspice_adv        hspice_cosim
  417. 22:16:00 (snpslmd) hspice_gui        HSPICE_MODEL_LIBRARY hspice_mt
  418. 22:16:00 (snpslmd) hspice_rf        hspice_rf_char        hspice3des
  419. 22:16:00 (snpslmd) hspicecmidev        hspicecmirt        hspicemt
  420. 22:16:00 (snpslmd) hspicerf        hspiceva        hspicewin
  421. 22:16:00 (snpslmd) hspice-XO        hspicext        hsptest
  422. 22:16:00 (snpslmd) hspui                Hsp-vacomp        ICInteractive
  423. 22:16:00 (snpslmd) Inspect_all        Interface-Shell Interfise_all
  424. 22:16:00 (snpslmd) IQBUS_AUTHOR        IQBUS_LIB        IROI
  425. 22:16:00 (snpslmd) ISExtract_all        ispLSI1K        ispLSI2K
  426. 22:16:00 (snpslmd) ispLSI2KE        ispLSI3K        ispLSI5000S
  427. 22:16:00 (snpslmd) ispLSI5000SE        HERCULES_HLVS        HERCULES_HLVS-DEBUG
  428. 22:16:00 (snpslmd) HERCULES_HLVS-HTML HERCULES_LVS        HERCULES_MANAGER
  429. 22:16:00 (snpslmd) HERCULES_MASK        HERCULES_RCE        HERCULES_VUE
  430. 22:16:00 (snpslmd) HERCULES-CRYPT_XREF_DATA HERCULES-DISTRIBUTED HERCULES-DISTRIBUTED-2
  431. 22:16:00 (snpslmd) HERCULES-DISTRIBUTED-24 HERCULES-DISTRIBUTED-24/2000.4 HERCULES-DISTRIBUTED-4
  432. 22:16:00 (snpslmd) HERCULES-DP_MT        HERCULES-EXPLORER_DRC HERCULES-EXPLORER_FILTERS
  433. 22:16:00 (snpslmd) HERCULES-EXPLORER_LVS HERCULES-FINDSHORT HERCULES-NETLIST
  434. 22:16:00 (snpslmd) HERCULES-RUN_TRAN hicdr_test        hicdr_test/test1
  435. 22:16:00 (snpslmd) hicdr_test/test2 hicdr_test/test3 hicdr_test/test4
  436. 22:16:00 (snpslmd) hicdr_test/test5 hicdr_test/test6 hicdr_test/test7
  437. 22:16:00 (snpslmd) hicdr_test/test8 HighLevel-Power-Analysis HighLevel-Power-Optimization
  438. 22:16:00 (snpslmd) him_mb                him_mb_dsml        him_mod
  439. 22:16:00 (snpslmd) him_sml                Gsim_framework_basic Gsim_snapshot
  440. 22:16:00 (snpslmd) Gsim_wave        GuidedTraceAnalysis hd_foundation
  441. 22:16:00 (snpslmd) hd_pna                hd_special1        hd_special2
  442. 22:16:00 (snpslmd) hd_special3        hd_utils        HDL
  443. 22:16:00 (snpslmd) HDL2SC_mixed        HDL2SC_verilog        HDL2SC_vhdl
  444. 22:16:00 (snpslmd) HDL-Advisor        HDL-Advisor-Estimator HDL-Advisor-Estimator-Package
  445. 22:16:00 (snpslmd) HDL-Advisor-Package HDL-Advisor-Shell HDL-Advisor-Shell-Estimator
  446. 22:16:00 (snpslmd) HDL-Advisor-Shell-Estm-Package HDL-Advisor-Shell-Package HDL-Compiler
  447. 22:16:00 (snpslmd) hdlin                hdlin_mixed        hdlin_verilog
  448. 22:16:00 (snpslmd) hdlin_vhdl        HERCULES_DEBUGGER HERCULES_DEVICE
  449. 22:16:00 (snpslmd) HERCULES_DRC        HERCULES_ERC        HERCULES_HDRC
  450. 22:16:00 (snpslmd) HERCULES_HDRC-HTML HERCULES_HERC-ADV HERCULES_HERC-BASIC
  451. 22:16:00 (snpslmd) HERCULES_HLPE        FPGA-Library-Compiler FPGA-Option
  452. 22:16:00 (snpslmd) FPGA-VHDL-Bundle FPPRT                FPTA
  453. 22:16:00 (snpslmd) FPTime                Fridge-GUI        Fridge-Interpolator
  454. 22:16:00 (snpslmd) Fridge-Simulation FSM-Reader        FSM-Writer
  455. 22:16:00 (snpslmd) FusionVantageLmcInterface Gaia                Galaxy-AdvCTS
  456. 22:16:00 (snpslmd) Galaxy-AdvTech        Galaxy-Common        Galaxy-DFT
  457. 22:16:00 (snpslmd) Galaxy-DFY        Galaxy-FP        Galaxy-ICC
  458. 22:16:00 (snpslmd) Galaxy-IU        Galaxy-MV        Galaxy-PNR
  459. 22:16:00 (snpslmd) Galaxy-Power        Galaxy-Prototype Galaxy-PSYN
  460. 22:16:00 (snpslmd) Gate2LayoutCorrelation Gate2RTLCorrelation gemini_hspice
  461. 22:16:00 (snpslmd) GENERICVSP        GENESISe_all        gentech
  462. 22:16:00 (snpslmd) GRAPHICS_INTERFACE Gsim_dump_advance Gsim_dump_basic
  463. 22:16:00 (snpslmd) Gsim_framework_advance FPGA-Express-A42MX-Optimizer FPGA-Express-A54SX-Optimizer
  464. 22:16:00 (snpslmd) FPGA-Express-APEX2-Optimizer FPGA-Express-APROA-Optimizer FPGA-Express-Constraint-Mgr
  465. 22:16:00 (snpslmd) FPGA-Express-EP20k-Optimizer FPGA-Express-EPF10k-Optimizer FPGA-Express-EPF6k-Optimizer
  466. 22:16:00 (snpslmd) FPGA-Express-EPF8k-Optimizer FPGA-Express-EPM7k-Optimizer FPGA-Express-EPM9k-Optimizer
  467. 22:16:00 (snpslmd) FPGA-Express-GAT FPGA-Express-isp1K-Optimizer FPGA-Express-isp2K-Optimizer
  468. 22:16:00 (snpslmd) FPGA-Express-isp3K-Optimizer FPGA-Express-ISP4000-Optimizer FPGA-Express-isp4K-Optimizer
  469. 22:16:00 (snpslmd) FPGA-Express-ISP5000-Optimizer FPGA-Express-isp5K-Optimizer FPGA-Express-isp6K-Optimizer
  470. 22:16:00 (snpslmd) FPGA-Express-isp7K-Optimizer FPGA-Express-isp8K-Optimizer FPGA-Express-MERCURY-Optimizer
  471. 22:16:00 (snpslmd) FPGA-Express-Open-Optimizer FPGA-Express-ORCA2-Optimizer FPGA-Express-ORCA3-Optimizer
  472. 22:16:00 (snpslmd) FPGA-Express-Synario-Optimizer FPGA-Express-VHDL-Base FPGA-Express-VHDL-Training
  473. 22:16:00 (snpslmd) FPGA-Express-VIRTEX-Optimizer FPGA-Express-VLOG-Base FPGA-Express-XC3k-Optimizer
  474. 22:16:00 (snpslmd) FPGA-Express-XC4k-Optimizer FPGA-Express-XC5k-Optimizer FPGA-Express-XC9k-Optimizer
  475. 22:16:00 (snpslmd) FPGA-HDL-Bundle ficdr_test/tio        FL_cosim_run
  476. 22:16:00 (snpslmd) FL_ice_run        FL_multichip_partition FL_recalc
  477. 22:16:00 (snpslmd) Flash370i        FLE_main        FLEX10K
  478. 22:16:00 (snpslmd) FLEX10KA        FLEX10KB        FLEX10KE
  479. 22:16:00 (snpslmd) FLEX6000        FLEX8000        Floops-1D_all
  480. 22:16:00 (snpslmd) Floops-1D-MC_all Floops-2D_all        Floops-2D-MC_all
  481. 22:16:00 (snpslmd) Floops-3D_all        Floops-3D-MC_all Floops-Parallel_all
  482. 22:16:00 (snpslmd) Floops-Parallel4_all Floorplan-Management Formality
  483. 22:16:00 (snpslmd) Formality-DV        Formality-E1        Formality-TransForm
  484. 22:16:00 (snpslmd) Formality-Transit FPABP                FPDP
  485. 22:16:00 (snpslmd) FPGA_Express-APROA-Optimizer FPGA-Compiler        FPGA-Express
  486. 22:16:00 (snpslmd) FPGA-Express-32OODx-Optimizer FPGA-Express-A1200XL-Optimizer FPGA-Express-A1400-Optimizer
  487. 22:16:00 (snpslmd) FPGA-Express-A3200DX-Optimizer emw-uniform-2d_all emw-uniform-3d_all
  488. 22:16:00 (snpslmd) ENACE                ENACS                encore
  489. 22:16:00 (snpslmd) encrypt                Enterprise        Enterprise_VO
  490. 22:16:00 (snpslmd) Equation-Reader Equation-Writer Espresso-Reader
  491. 22:16:00 (snpslmd) Espresso-Writer EssentialSignalAnalysis Estm-HDL-Advisor
  492. 22:16:00 (snpslmd) Estm-HDL-Advisor-Package etran                EV-ACCESS
  493. 22:16:00 (snpslmd) EV-ACCESS_UTIL        Eview                eX
  494. 22:16:00 (snpslmd) example_feature EXCALIBUR_ARM        EXCALIBUR_MIPS
  495. 22:16:00 (snpslmd) Extraction        FCII-Altera-Edition FCO
  496. 22:16:00 (snpslmd) features        ficdr_test        ficdr_test/gds
  497. 22:16:00 (snpslmd) ficdr_test/goa        ficdr_test/io        ficdr_test/nc
  498. 22:16:00 (snpslmd) ficdr_test/poly ficdr_test/size ficdr_test/sizeOr
  499. 22:16:00 (snpslmd) ficdr_test/stmp DW-IP-Consultant DW-IP-DEBUG
  500. 22:16:00 (snpslmd) DW-IP-Developer E5                E502
  501. 22:16:00 (snpslmd) E505                E520                Early-Access-Technology
  502. 22:16:00 (snpslmd) ECL-Compiler        ECO-Compiler        edif2e
  503. 22:16:00 (snpslmd) EDIF-Netlist-Read-DC EDIF-Netlist-Write-DC EDIF-Netlist-Writer
  504. 22:16:00 (snpslmd) EDIF-Reader        EDIF-Schematic-Writer electromigration_drc
  505. 22:16:00 (snpslmd) ELGRECO_Davis        ELGRECO_DesignCenter ELGRECO_Simulator
  506. 22:16:00 (snpslmd) Emlab_all        Emlab-Dessis_all Emlab-Farfield_all
  507. 22:16:00 (snpslmd) Emlab-Nonuniform-2D_all Emlab-Nonuniform-3D_all Emlab-Static_all
  508. 22:16:00 (snpslmd) Emlab-Thermal_all Emlab-Uniform-2D_all Emlab-Uniform-3D_all
  509. 22:16:00 (snpslmd) emw_all                emw-farfield_all emw-nonuniform-2d_all
  510. 22:16:00 (snpslmd) emw-nonuniform-3d_all emw-sdevice_all emw-static_all
  511. 22:16:00 (snpslmd) emw-thermal_all Dessis-Optic_all Dessis-Parallel_all
  512. 22:16:00 (snpslmd) Dessis-Parallel4_all Dessis-PMI_all        Dessis-Radiation_all
  513. 22:16:00 (snpslmd) Dessis-Reliability_all Dessis-Schroedinger_all Dessis-SiGe_all
  514. 22:16:00 (snpslmd) Dessis-Thermo_all Dessis-Traps_all Dessis-VectorOptic_all
  515. 22:16:00 (snpslmd) Devise_all        Devise-3D_all        Dfisetools_all
  516. 22:16:00 (snpslmd) Dfisetools-Topo_all Dios_all        Dios-3D_all
  517. 22:16:00 (snpslmd) Dios-MC_all        Dios-PDEF_all        Dios-SDO_all
  518. 22:16:00 (snpslmd) DiosSmall_all        Dip_all                DIRECTMEM
  519. 22:16:00 (snpslmd) DS-Schem-Gen        DS-Schem-Gen-Estimator-Pa DS-Schem-Gen-Estimator-Package
  520. 22:16:00 (snpslmd) DS-Schem-Gen-Package DS-Verinet        DS-Verinet-Estimator-Pack
  521. 22:16:00 (snpslmd) DS-Verinet-Estimator-Package DS-Verinet-Package DS-Vhdlnet
  522. 22:16:00 (snpslmd) DS-Vhdlnet-Estimator-Pack DS-Vhdlnet-Estimator-Package DS-Vhdlnet-Package
  523. 22:16:00 (snpslmd) DW-Developer        DesignWare-MPEG2 DesignWare-MPEG2-Source
  524. 22:16:00 (snpslmd) DesignWare-MPEG2-VDEC DesignWare-MPEG2-VDEC-Source DesignWare-MPEG-Source
  525. 22:16:00 (snpslmd) DesignWare-Package DesignWare-PCI        DesignWare-PCIbasic
  526. 22:16:00 (snpslmd) DesignWare-PCI-Source DesignWare-PCI-X DesignWare-PCI-X-Source
  527. 22:16:00 (snpslmd) DesignWare-SystemIO DesignWare-SystemIO-Source DesignWare-TCA
  528. 22:16:00 (snpslmd) DesignWare-TCA-Source DesignWare-USB        DesignWare-USB2
  529. 22:16:00 (snpslmd) DesignWare-USB2-Source DesignWare-USB-Source DesignWare-VERA
  530. 22:16:00 (snpslmd) Dessis_all        Dessis-3D_all        Dessis-BONSIM_all
  531. 22:16:00 (snpslmd) Dessis-DensityGrad_all Dessis-Ferro_all Dessis-FloatingGate_all
  532. 22:16:00 (snpslmd) Dessis-GateLeakage_all Dessis-Hetero_all Dessis-Hydro_all
  533. 22:16:00 (snpslmd) Dessis-kpGain_all Dessis-Laser_all Dessis-LED_all
  534. 22:16:00 (snpslmd) Dessis-MixedMode_all Dessis-Mono-Semicond_all Dessis-MonteCarlo_all
  535. 22:16:00 (snpslmd) Dessis-Noise_all Design-Budgeting Design-Compiler
  536. 22:16:00 (snpslmd) Design-Estimator Design-Estimator-FPI DesignSource
  537. 22:16:00 (snpslmd) DesignSource-Estimator-Package DesignSource-Package DesignTime
  538. 22:16:00 (snpslmd) Design-Vision        DesignWare        DesignWare-1394
  539. 22:16:00 (snpslmd) DesignWare-1394-Source DesignWare-6811-Source DesignWare-8051
  540. 22:16:00 (snpslmd) DesignWare-8051MCU DesignWare-8051-Source Designware-Basic
  541. 22:16:00 (snpslmd) DesignWare-BIST DesignWare-BIST-Source DesignWare-Cardbus
  542. 22:16:00 (snpslmd) Designware-Developer DesignWare-Developer-MGI DesignWare-ETHERNET-Source
  543. 22:16:00 (snpslmd) DesignWare-FloatingPoint DesignWare-Foundation DesignWare-Foundation-Exp
  544. 22:16:00 (snpslmd) DesignWare-Foundation-Expert DesignWare-Foundation-Power DesignWare-Foundation-Ultra
  545. 22:16:00 (snpslmd) Designware-FPGA-Basic DesignWare-ISA-PnP DesignWare-MemoryBist
  546. 22:16:00 (snpslmd) DesignWare-MemoryBist-Source DesignWare-MGI        DesignWare-MPEG
  547. 22:16:00 (snpslmd) Cyclone-Elaborator Cyclone-GUI        Cyclone-HDL-Analyzer
  548. 22:16:00 (snpslmd) Cyclone-Simulator Cyclone-VHDL-Analyzer CYPRESS
  549. 22:16:00 (snpslmd) DataExpansion        DataExpansionCoverage DataExpansionSim
  550. 22:16:00 (snpslmd) DATAIO                DataReplay        DataReplaySim
  551. 22:16:00 (snpslmd) DC64                DC-Beta                DC-Cadence-Interface
  552. 22:16:00 (snpslmd) DC-Expert        DCExpert-PrimeTime DC-Falcon-Interface
  553. 22:16:00 (snpslmd) DC-FPGA-Accelerator DC-FPGA-Add-On        DC-FPGA-Features
  554. 22:16:00 (snpslmd) DC-Layout-Interface DCM-Delay-Calculation DC-Min-Area-Retime
  555. 22:16:00 (snpslmd) DC-SDF-Interface DC-Ultra        DC-Ultra-Features
  556. 22:16:00 (snpslmd) DC-Ultra-Opt        DC-XG                Debussy
  557. 22:16:00 (snpslmd) Debussy_shared        delaymill        Delta39k
  558. 22:16:00 (snpslmd) DEMO                Design-Analyzer Design-Analyzer-DAP
  559. 22:16:00 (snpslmd) COSSAP_matlab        COSSAP_mfd        COSSAP_mpeg2
  560. 22:16:00 (snpslmd) COSSAP_pdc        COSSAP_qed        COSSAP_sds
  561. 22:16:00 (snpslmd) COSSAP_srcfd        COSSAP_vcg_generic COSSAP_vcg_synopsys
  562. 22:16:00 (snpslmd) COSSAP_vcg_vantage COSSAP_vdefcg        COSSAP_vdefcg_vlgxl
  563. 22:16:00 (snpslmd) COSSAP_vsiccg        COSSAP_vsiccg_cyc COSSAP_vsiccg_mti
  564. 22:16:00 (snpslmd) COSSAP_vsiccg_mtivlg COSSAP_vsiccg_vcs COSSAP_vsiccg_vlgxl
  565. 22:16:00 (snpslmd) COSSAP_vsivcg        COSSAP_vsivcg_vlgxl COSSAP_xdcg
  566. 22:16:00 (snpslmd) COSSAP_xvcg        COSSAP_xvsi        CoverMeter
  567. 22:16:00 (snpslmd) CoverMeterOBC        CoverMeterOBCVCSAMSCompiler CPI-100
  568. 22:16:00 (snpslmd) CRS_COVERMETER        CRS_VCM                CRS_VCS
  569. 22:16:00 (snpslmd) CRS_VCSi        CTV-Interface        CUSTOM_LIB
  570. 22:16:00 (snpslmd) Cyclone-Code-Generator Cyclone-Core        Cyclone-cosim
  571. 22:16:00 (snpslmd) COSSAP_cw_filter_sds COSSAP_dab        COSSAP_dcg_ad21020
  572. 22:16:00 (snpslmd) COSSAP_dcg_ansic COSSAP_dcg_ariel32c COSSAP_dcg_fe
  573. 22:16:00 (snpslmd) COSSAP_dcg_gc        COSSAP_dcg_krc        COSSAP_dcg_lsic30s
  574. 22:16:00 (snpslmd) COSSAP_dcg_m96000 COSSAP_dcg_mp        COSSAP_ddk_arm
  575. 22:16:00 (snpslmd) COSSAP_ddk_devlp COSSAP_ddk_dsp16000 COSSAP_ddk_dsp1610
  576. 22:16:00 (snpslmd) COSSAP_ddk_hawk COSSAP_ddk_nec        COSSAP_ddk_oak
  577. 22:16:00 (snpslmd) COSSAP_ddk_pine COSSAP_ddk_ssp16xx COSSAP_ddk_tic5x
  578. 22:16:00 (snpslmd) COSSAP_ddk_tic5xx COSSAP_dect        COSSAP_dvb
  579. 22:16:00 (snpslmd) COSSAP_ecc        COSSAP_gsmdve        COSSAP_gsmdve_utils
  580. 22:16:00 (snpslmd) COSSAP_gsmefrsc COSSAP_gsmeq        COSSAP_gsmfrcc
  581. 22:16:00 (snpslmd) COSSAP_gsmfrsc        COSSAP_gsmhrcc        COSSAP_gsmhrsc
  582. 22:16:00 (snpslmd) COSSAP_gsmphy        COSSAP_is136        COSSAP_is95
  583. 22:16:00 (snpslmd) CoCentric-SYS-Davis CoCentric-SYS-DesignCenter CoCentric-SYS-HWflow
  584. 22:16:00 (snpslmd) CoCentric-SYS-HWSimIF CoCentric-SYS-RDK-adsl CoCentric-SYS-RDK-cdma2000
  585. 22:16:00 (snpslmd) CoCentric-SYS-RDK-docsis CoCentric-SYS-Simulator Columbia
  586. 22:16:00 (snpslmd) ColumbiaTE        COMPONENT_LIBRARY Constraint_Translation
  587. 22:16:00 (snpslmd) Converter        COOLRUNNER        COOLRUNNER2
  588. 22:16:00 (snpslmd) coreAssembler        coreBuilder        coreConsultant
  589. 22:16:00 (snpslmd) coremill        coreSynthesis        COSIM-LFG
  590. 22:16:00 (snpslmd) COSIM-MTI        COSIM-NCV        COSIM-SRO
  591. 22:16:00 (snpslmd) COSIM-VCS        COSIM-VXL        COSMOS_VO
  592. 22:16:00 (snpslmd) COSSAP_adpcm        COSSAP_adsl        COSSAP_amr
  593. 22:16:00 (snpslmd) COSSAP_arm        COSSAP_bde        COSSAP_celp
  594. 22:16:00 (snpslmd) COSSAP_chart        COSSAP_cw_filter_hdl CBA-Logical-MA
  595. 22:16:00 (snpslmd) CBA-Physical-DS CBA-Physical-MA CBA-Transport
  596. 22:16:00 (snpslmd) CD-Compiled-Lib-Gen CD-Compiled-Sys-Gen CD-GDI
  597. 22:16:00 (snpslmd) CD-GDII-Link        CD-Model-Developer CD-MSSC-Cross-Probe
  598. 22:16:00 (snpslmd) CD-MSSC-Netlist CD-Present-Builder CD-Present-Layer-Gen
  599. 22:16:00 (snpslmd) CD-REX                cdsaavmx        cdsaawaves
  600. 22:16:00 (snpslmd) cdsmetalib        cdsnet                CD-Vhdlgen-Gen
  601. 22:16:00 (snpslmd) CD-Vhdlgen-GUI        chipviewer        cmod
  602. 22:16:00 (snpslmd) cmod/ax                cmod/cbx        cmod/drc
  603. 22:16:00 (snpslmd) cmod/gx                cmod/gxadv        cmod/hdrc
  604. 22:16:00 (snpslmd) cmod/hlvs        cmod/ipc        cmod/lvs
  605. 22:16:00 (snpslmd) cmod/viewer        CmView                CoCentric-FXD-GUI
  606. 22:16:00 (snpslmd) CoCentric-FXD-Interpolator CoCentric-FXD-Simulation avanwaveswin
  607. 22:16:00 (snpslmd) awe_rcr                BC-FPGA                BC-FPGA-HDL
  608. 22:16:00 (snpslmd) BC-FPGA-VHDL        BC-HDL                BC-Schedule
  609. 22:16:00 (snpslmd) BC-VHDL                Behavioral-Analyzer Behavioral-Compiler
  610. 22:16:00 (snpslmd) BOA-BRT                c_exe_ax        c_exe_cbx
  611. 22:16:00 (snpslmd) c_exe_drc        c_exe_gx        c_exe_ipc
  612. 22:16:00 (snpslmd) c_exe_lvs        CA-Chip-Edit        CA-CP-Advanced
  613. 22:16:00 (snpslmd) CA-CP-Basic        CA-CP-Standard        cadence
  614. 22:16:00 (snpslmd) cadence_epic        CA-Foundation        CA-Frame
  615. 22:16:00 (snpslmd) CA-Hier-Timer        CA-Optimization CA-Timer
  616. 22:16:00 (snpslmd) CA-Utils        CBA-ApolloGA-Interface CBA-Blk-Export
  617. 22:16:00 (snpslmd) CBA-Blk-Import        CBA-CadenceSE-Interface CBA-DS-Beta
  618. 22:16:00 (snpslmd) CBA-Frame        CBA-Logical-DS        arc/ppx
  619. 22:16:00 (snpslmd) arc/pro                arc/r3x                arc1
  620. 22:16:00 (snpslmd) arc2                arcexpert        arcfc
  621. 22:16:00 (snpslmd) arcviewer        arcviewer/raph        arcxl
  622. 22:16:00 (snpslmd) ARKOS-A                ARKOS-B                ARKOS-C
  623. 22:16:00 (snpslmd) ARKOS-D                ARKOS-E                ARKOS-Ice
  624. 22:16:00 (snpslmd) ARKOS-Mcomp        ARKOS-Rtlcomp        ARKOS-Scomp
  625. 22:16:00 (snpslmd) ARKOS-Simul        ARM7TDMI        Astro
  626. 22:16:00 (snpslmd) AstroBeta        AstroExp        Astro-Express
  627. 22:16:00 (snpslmd) AstroGA                AstroRail        Astro-Rail
  628. 22:16:00 (snpslmd) AstroRailSA        AstroSpecialBeta AstroXtalk
  629. 22:16:00 (snpslmd) Astro-Xtalk        ATMEL                ATMWB_ATMLAYER
  630. 22:16:00 (snpslmd) ATMWB_UTOPIA        avanwaves        APACM
  631. 22:16:00 (snpslmd) APATD                APCS                APDP
  632. 22:16:00 (snpslmd) APEX20K                APEX20KC        APEX20KE
  633. 22:16:00 (snpslmd) APEXII                APGA4AP                APGACS
  634. 22:16:00 (snpslmd) APGADP                APGAHPO                APGApwr
  635. 22:16:00 (snpslmd) APGASolar        APGASolarII        APGATime
  636. 22:16:00 (snpslmd) APHPO                Apollo                ApolloGA
  637. 22:16:00 (snpslmd) APPower                APpwr                APSolar
  638. 22:16:00 (snpslmd) APSolarII        APTime                APXtalk
  639. 22:16:00 (snpslmd) arc                arc/bcx                arc/c2x
  640. 22:16:00 (snpslmd) arc/c3x                arc/cns                arc/dnx
  641. 22:16:00 (snpslmd) arc/dpx                arc/gds2        arc/giper
  642. 22:16:00 (snpslmd) arc/lefdef        A3200DX                A42MX
  643. 22:16:00 (snpslmd) A500K                A54SX                A54SXA
  644. 22:16:00 (snpslmd) A7                AARKOS-A        ace_core
  645. 22:16:00 (snpslmd) acega                acehdl                acehdl/beta_status
  646. 22:16:00 (snpslmd) acehdl/internal_use acehdl_beta        acehdl_gui
  647. 22:16:00 (snpslmd) ACEX1K                ACS                ACT2-1200XL
  648. 22:16:00 (snpslmd) ACT3                AdvanceCalibration_all AdvancedCalibration_all
  649. 22:16:00 (snpslmd) AIM_DEBUG        AIM_DECRYPT        AIM_DEVELOPER
  650. 22:16:00 (snpslmd) AIM_ENCRYPT        aiu_foundation        alien2lig_all
  651. 22:16:00 (snpslmd) ALTGEN1                ALTGEN2                amat-calib_all
  652. 22:16:00 (snpslmd) amga                amps                amps/cso
  653. 22:16:00 (snpslmd) amps/pfx        amps/tr                AN-Impl3D_all
  654. 22:16:00 (snpslmd) any_technology
  655. 22:16:00 (snpslmd)
  656. 22:16:00 (snpslmd) Licenses are case sensitive for TE_CATS
  657. 22:16:00 (snpslmd)
  658. 22:16:00 (snpslmd) EXTERNAL FILTERS are OFF
  659. 22:16:00 (lmgrd) snpslmd using TCP-port 45297
  660. 22:16:00 (snpslmd) Serving features for the following vendor names:
  661. snpslmd  CADABRA  EPIC  ISE-TCADd  TE_CATS  adalmd  anagram  archprod  avantd  chrysalisd  everest  hscd  innologd  la_dmon  leda  metasoftd  nassd  numeritchd  saber_dmn  sandwork  sigmacd  slat  snpsOEM1  snpsOEM2  snpsOEM3  snpsOEM4  snpsOEM5  snpsOEM6  snpsOEM7  snpsOEM8  snpsOEM9  ssilmd  synopsysd  tmald  vcsd
  662. 22:16:01 (snpslmd) ------------------------------------------------------------------
  663. 22:16:01 (snpslmd) Checking the integrity of the license file....
  664. 22:16:01 (snpslmd) Valid SSS feature found.
  665. 22:16:01 (snpslmd) The feature is needed to enable the other keys in your license file.
  666. 22:16:01 (snpslmd) ------------------------------------------------------------------
  667. 22:16:24 (snpslmd) TCP_NODELAY NOT enabled
  668.
    复制代码
 楼主| 发表于 2016-1-28 16:25:46 | 显示全部楼层
Need help friends
My lmgrd report : http://pastebin.com/raw/P3Q7XLAD
发表于 2016-1-28 18:04:56 | 显示全部楼层
use the recommanded OS, namely RHEL or CentOS
 楼主| 发表于 2016-1-28 19:06:15 | 显示全部楼层
回复 4# qfliuyang
   Is this OS issue?
I have CentOS 4.4 (32 bit)  ,  Will this problem solve by using CentOS 4.4 (32 bit).
发表于 2016-1-28 22:15:21 | 显示全部楼层
回复 5# jithinsmmb
   Maybe, It's happened to me once. But Check your /etc/hosts file first, make sure your hostname points to 127.0.0.1   here's the official supporting OS http://www.synopsys.com/Support/ ... atformsRoadmap.aspx
发表于 2016-1-29 07:32:39 | 显示全部楼层
"export LM_LICENSE_FILE=/usr/synopsys/synopsys.dat" this is used for node-lock license.
" /usr/synopsys/10.9.3/linux/bin/lmgrd -c /usr/synopsys/synopsys.dat -l ou5.log" this is used for floating license.
they are different.  do you have checked the ou5.log file?
 楼主| 发表于 2016-1-29 15:09:25 | 显示全部楼层
回复 7# daviehj
   My out5.log is given as pastebin link.
 楼主| 发表于 2016-1-29 15:14:46 | 显示全部楼层
回复 7# daviehj
   Check my third post.out5.log file is there in pastebin link
 楼主| 发表于 2016-1-30 18:53:38 | 显示全部楼层
回复 6# qfliuyang
Hostname points to same 127.0.0.1   .
Now I tested with CentOS 4.4 but same result .
Help me
GMT+8, 2025-12-27 01:31 , Processed in 0.029216 second(s), 5 queries , Gzip On, Redis On.
