查看: 6895|回复: 4
[求助] PT保持时间违例,removal违例,min_capacitance违例,求解决办法
发表于 2016-1-27 22:06:05 | 显示全部楼层 |阅读模式
PT所用的约束与DC所用约束除操作条件不同之外,其余基本不变
将时钟保持时间的不确定性改为0.5,则保持时间违例修正,removal 数减少;输入驱动单元buffer已是最小的最大输出电容负载,求修正min_capacitance方式
最初始的违例部分报告如下:
Report : constraint
        -all_violators
        -path slack_only
Design : SPI_S
Version: D-2010.06-SP3
Date   : Wed Jan 27 21:35:32 2016
   min_delay/hold ('clk_in' group)
   Endpoint                                                  Slack
   ACR[7]                                                    -1.17  (VIOLATED)
   SSYNC                                                     -1.17  (VIOLATED)
   ODAC[7]                                                   -1.17  (VIOLATED)
   misoe                                                     -1.17  (VIOLATED)
   RESET                                                     -1.16  (VIOLATED)
   DRDY_f                                                    -1.14  (VIOLATED)
   uut_spi_slave/r_dorc_reg/D                                -1.13  (VIOLATED)
   misoo                                                     -1.12  (VIOLATED)
   uut_spi_slave/uut_reset_DRDY/reset_DRDY_reg/D             -1.12  (VIOLATED)
   uut_spi_slave/reset_order_reg/D                           -1.11  (VIOLATED)
   uut_spi_slave/MODU_reg[0]/D                               -1.11  (VIOLATED)
   uut_spi_slave/MODU_reg[1]/D                               -1.11  (VIOLATED)
   uut_spi_slave/MODU_reg[4]/D                               -1.11  (VIOLATED)
   uut_spi_slave/MODU_reg[5]/D                               -1.11  (VIOLATED)
   uut_spi_slave/MODU_reg[6]/D                               -1.11  (VIOLATED)
   uut_spi_slave/SETUP_reg[2]/D                              -1.11  (VIOLATED)
   uut_spi_slave/SETUP_reg[3]/D                              -1.11  (VIOLATED)
   uut_spi_slave/uut_reset_DRDY/DRDY_state_reg[2]/D          -1.11  (VIOLATED)
removal
   Endpoint                                                  Slack
   uut_Reset_Synchronizer/rff1_reg/CDN                       -2.02  (VIOLATED)
   uut_Reset_Synchronizer/rst_n_reg/CDN                      -2.02  (VIOLATED)
   uut_sync_detect/SYNC_r1_reg/CDN                           -1.63  (VIOLATED)
   uut_sync_detect/SYNC_r2_reg/CDN                           -1.63  (VIOLATED)
   uut_spi_slave/MODU_reg[0]/CDN                             -1.63  (VIOLATED)
   uut_spi_slave/MODU_reg[1]/CDN                             -1.36  (VIOLATED)
   uut_spi_slave/MODU_reg[2]/CDN                             -1.36  (VIOLATED)
   uut_spi_slave/MODU_reg[3]/CDN                             -1.36  (VIOLATED)
   uut_spi_slave/DRDY_f_reg/CDN                              -1.33  (VIOLATED)
min_capacitance
                             Required        Actual
   Pin                      Capacitance    Capacitance       Slack
   uut_spi_slave/U259/Z         0.02           0.01           0.00  (VIOLATED: increase significant digits)
   uut_spi_slave/U262/Z         0.02           0.01           0.00  (VIOLATED: increase significant digits)
   uut_spi_slave/U284/Z         0.02           0.01           0.00  (VIOLATED: increase significant digits)
   uut_spi_slave/U305/Z         0.02           0.01           0.00  (VIOLATED: increase significant digits)
   uut_spi_slave/U313/Z         0.02           0.01           0.00  (VIOLATED: increase significant digits)
   uut_spi_slave/U321/Z         0.02           0.01           0.00  (VIOLATED: increase significant digits)
发表于 2016-1-28 19:24:09 | 显示全部楼层
hold和removal可以垫buffer垫掉,不过你这violation太大了,估计要垫好多buffer。min_capacitance可以size up这些Z端的cell
 楼主| 发表于 2016-1-28 20:50:58 | 显示全部楼层
回复 2# jingest
   我把时钟不确定性改小了,保持时间违例便修正了。removal通过插buffer,改器件大小已修正。现还有min_capacitance违例,最大负松弛为-0.0350035,最小负松弛-0.0000682799。想问一下:PT工具手动插入buffer后,如何删除?用指令老是错误。。。。有没有PT软件的使用教程啊?想改错,电路图中好难找到cell
发表于 2020-12-4 19:46:39 | 显示全部楼层
请问一下解决了吗
发表于 2023-5-19 17:31:41 | 显示全部楼层
jingest 发表于 2016-1-28 19:24
hold和removal可以垫buffer垫掉,不过你这violation太大了,估计要垫好多buffer。min_capacitance可以size  ...
谢谢
GMT+8, 2025-12-16 02:07 , Processed in 0.020424 second(s), 6 queries , Gzip On, Redis On.
