查看: 3030|回复: 3
[原创] 奖品转让 DE5-NET Stratix V
发表于 2015-12-29 17:37:15 | 显示全部楼层 |阅读模式
DE5-NET Stratix  V
开发板,配件齐全,比赛所得九成新,适合高端应用,原价8万,现6万转让
有意者联系  QQ:2067407003
FPGA
Altera Stratix  V GX FPGA (5SGXEA7N2F45C2)
FPGA Configuration
On-Board USB Blaster II or JTAG header for FPGA programming
Fast passive parallel (FPPx32) configuration via MAX II CPLD and flash memory
Memory
Up to 8GB DDR3 800 MHz SO-DIMM SDRAM
32MB SRAM (ISSI QUADP for DE5-Net 450,  GSI SigmaQuad-II+ for DE5-Net 550, Cypress QDRII+ for DE5-Net 500)
256MB FLASH
Communication Ports
Four SFP+ connectors
Two Serial ATA host ports
Two Serial ATA device ports
PCI Express (PCIe) x8 edge connector (includes Windows x32-bits/64-bits PCIe drivers)
One RS422 transceiver with RJ45 connector
Others
General user input / output:
4 LEDs
1 LED Array
4 push-buttons
4 slide switches
2 seven-segment displays
SMA clock input / output
On-Board Clock
50MHz Oscillator
Programmable oscillators Si570, CDCM61001 and CDCM61004
System Monitor and Control
Temperature sensor
Fan control
Power
PCI Express 6-pin power connector, 12V DC Input
PCI Express edge connector power
Mechanical Specification
PCI Express standard height and 3/4-length
The DE5-Net Stratix V FPGA Development Kit is perfectly suited for extreme high speed needs including cloud computing, high frequency trading, and security networks. Featuring an ultra-high bandwidth memory architecture, low-latency SFP+ interfaces, expandable memory, and PCIe communication, the DE5-Net allows for maximum flexibility in terms of low-power, speed, and performance.
发表于 2015-12-30 18:57:07 | 显示全部楼层
买得起这板子的也不在乎多花2万块吧……
发表于 2016-1-4 09:23:17 | 显示全部楼层
楼上说得非常在理。
 楼主| 发表于 2016-1-4 17:49:23 | 显示全部楼层
回复 3# tigerf49
   我也觉得在理
GMT+8, 2025-10-24 23:24 , Processed in 0.020096 second(s), 9 queries , Gzip On, Redis On.
