查看: 2117|回复: 2
[求助] pt读入spef文件有问题,请各位帮忙
发表于 2015-12-24 13:18:13 | 显示全部楼层 |阅读模式
ICC 导出Verilog和spef文件
write_verilog  -no_physical_only_cells final.v
write_parasitics -format spef -output final.spef
1.  pt读入Verilog时出现以下warning
Warning:Module 'FSUBC_0' in file '/home/final.v' is not used in the current design
Warning:Module 'FSUBC_1' in file '/home/final.v' is not used in the current design
Warning:Module 'LATCHin 8_0' file '/home/final.v' is not used in the current design
==>请问是什么原因产生的?
2. pt读入spef时出现以下大量error
Error:Cannot find port/pin 'U2/START_STOP/U101/A' in design 'SPI_PCM'
Error:Cannot find port/pin 'U2/START_STOP/U101/N18496' in design 'SPI_PCM'
Error:Cannot  resolve net ''U2/START_STOP/U101/N15042'
==>请问是什么原因产生的?如何解决?
请各位大侠不吝赐教,小妹万分感激。
发表于 2015-12-24 15:41:47 | 显示全部楼层
write_verilog之前加个change_name -rule verilog试试
 楼主| 发表于 2015-12-29 10:55:09 | 显示全部楼层
回复 2# yahemao123
    试了成功了
    谢谢!
GMT+8, 2025-12-14 15:27 , Processed in 0.023322 second(s), 7 queries , Gzip On, Redis On.
