查看: 1799|回复: 0
[解决] ATF1504AS,Found wrong device(s) in hardware
发表于 2015-12-23 08:36:59 | 显示全部楼层 |阅读模式
用atmisp通过byteblaster2向ATF1504AS编写程序,结果ATMISP报错,错误信息如下:Found wrong device(s) in hardware。在下查了查帮助文档上的内容,出现这个错误为:The devices specified in the ATMISP chain file do not match the actual devices found in the JTAG hardware chain. At the beginning of a JTAG programming process, ATMISP will read the device IDs from all of the devices in the JTAG chain and then compare them with the expected device IDs。
这个该如何去解决,有知道的大神吗,赐教一下好吗
GMT+8, 2025-12-19 22:22 , Processed in 0.014090 second(s), 7 queries , Gzip On, Redis On.
