查看: 7050|回复: 5
HSPICE仿真问题
发表于 2007-5-27 11:50:48 | 显示全部楼层 |阅读模式
CSM.25的两个hspice模型文件:xxx.bin.hspice,xxx.hspice。前一个精度高,后一个精度低。
用hspiceD进行仿真,用xxx.hspice时可以正常仿真,但是结果不够精确(和spectre相比)。用xxx.bin.hspice仿真没有任何结果,.out文件如下:
******  HSPICE W-2005.03        (20050128) 12:54:22  05/26/2007  linux
  Copyright (C) 2005 Synopsys, Inc. All Rights Reserved.
  Unpublished-rights reserved under US copyright laws.
  This program is protected by law and is subject to the
  terms and conditions of the ****** agreement found in:
    /******.txt
  Use of this program is your acceptance to be bound by this
  ****** agreement. HSPICE is the trademark of Synopsys, Inc.
  Input File: input.ckt
lic:
lic: FLEXlm: v8.4b
lic: USER:   root                 HOSTNAME: localhost.localdomain
lic: HOSTID: 001921e5ef26         PID:      7956
lic: Using FLEXlm ****** file:
lic: /tools/hspice/hspice/******.dat
lic: Checkout hspice;  Encryption code: 8CFD037DDD14A01D864E
lic: ******/Maintenance for hspice will expire on 1-jan-0/2019.12
lic: NODE LOCKED DEMO ****** on host 001921e5ef26
lic:
lic:
lic: FLEXlm: v8.4b
lic: Checkout cdsaawaves;  Encryption code: CCFDE3CD939DBE706F2C
lic: ******/Maintenance for cdsaawaves will expire on 1-jan-0/2019.12
lic:
circuit parameter definitions
  parameter          =  value
constants  - tnom         kt           vt           gapsi        ni
            2.981e+02    4.116e-21    2.569e-02    1.115e+00    1.256e+16
1 ******  HSPICE W-2005.03        (20050128) 12:54:22  05/26/2007  linux
** generated for: hspiced                                         ^@
  ******  circuit element summary          tnom=  25.000 temp=  25.000
**** independent sources
     name         node1        node2      dc volt    ac mag    ac phase    type
        0:v0             0:net027         0:0           0.       1.000e+00    0.      sin
             offset.......     0.
             amplitude....   2.000e+00
             frequency....   9.999e+02
             delay........     0.
             theta........     0.
             phase........     0.
**warning** associated with encrypted blocks weresuppressed due to encrypted content
  ******  temperature-adjusted values      tnom=  25.000 temp=  25.000
constants  - temp         kt           vt           gapsi        ni
*** capacitors
    name        eff val
*** mosfet element parameters
name           rd eff   rs eff   cdsat    cssat     vto      beta
  ******  operating point information      tnom=  25.000 temp=  25.000
***** operating point status is all       simulation time is     0.
    node    =voltage      node    =voltage      node    =voltage
****  voltage sources
subckt
element  0:v0
  volts      0.
  current  6.530e-16
  power      0.
     total voltage source power dissipation=    0.            watts
     total current source power dissipation=   0.            watts
***** operating point status is ^B,I4,^Bx,  simulation time is     0.
subckt
element  0:v0
  volts   -1.470e-15
  current -7.981e-09
  power   -1.173e-23
     total voltage source power dissipation= -1.173e-23       watts
          ***** job concluded
  ******  job statistics summary           tnom=  25.000 temp=  25.000
           total memory used       1144 kbytes
  # nodes =     9 # elements=    12
  # diodes=     0 # bjts    =     0 # jfets   =     0 # mosfets =     6 # va device =     0
     analysis      time      # points  tot. iter  conv.iter
     op point          0.01         1        89
     dc sweep          0.63      4001      8035
     ac analysis       0.01       121       121
     transient         0.57     30001     12006      6003 rev=     0
     readin            4.82
     errchk            0.03
     setup             0.00
     output            0.00
           total cpu time          6.07 seconds
               job started at  12:54:22  05/26/2007
               job ended   at  12:54:29  05/26/2007
lic: Release hspice token(s)
lic: Release cdsaawaves token(s)
netlist如下:
** Generated for: hspiceD
** Generated on: May 26 12:54:22 2007
** Design library name: testcir
** Design cell name: act
** Design view name: schematic
.GLOBAL vss! vdd!
.AC DEC 10 1e-3 1e9
.DC v0 -2.0 2.0 1e-3
.OP all 0
.TRAN 100e-9 3e-3 START=0.0
.TEMP 25
.OPTION
+    ARTIST=2
+    INGOLD=2
+    MEASOUT=1
+    PARHIER=LOCAL
+    PSF=2
.LIB "/root/process/charter/pdk/models/spice/sm079003-1h-bin.hspice" typical
** Library name: testcir
** Cell name: act
** View name: schematic
c1 net024 net29 1e-12
c0 net29 net027 250e-15
v0 net027 0 DC=0 AC 1 SIN 0 2 1e3
v6 vdd! 0 DC=1.25
v7 vss! 0 DC=-1.25
i0 vdd! net17 DC=10e-6
m3 net048 net048 vdd! vdd! pmos_tn L=1e-6 W=5e-6 M=1
m2 net024 net048 vdd! vdd! pmos_tn L=1e-6 W=5e-6 M=1
m5 net17 net17 vss! vss! nmos_tn L=1e-6 W=5e-6
m4 net30 net17 vss! vss! nmos_tn L=1e-6 W=5e-6
m1 net048 0 net30 vss! nmos_tn L=1e-6 W=5e-6
m0 net024 net29 net30 vss! nmos_tn L=1e-6 W=5e-6
.END
完了。谢谢耐心看到这里。
我想用精度高的xxx.bin.hspice仿真,请问怎么解决?
发表于 2008-4-30 02:10:07 | 显示全部楼层
学习学习
发表于 2008-4-30 08:53:46 | 显示全部楼层
吧你的hspice for linux 共享一下如何?
发表于 2008-4-30 08:58:14 | 显示全部楼层
.bin的可能是二进制文件吧?
发表于 2008-5-10 20:42:44 | 显示全部楼层
.option accurate 再试试看
发表于 2013-11-21 20:14:33 | 显示全部楼层
rom where i can get library files
GMT+8, 2025-12-25 01:18 , Processed in 0.026389 second(s), 6 queries , Gzip On, Redis On.
