楼主: yy641737606
[资料] Antenna magus 5.1.0 Pro安装加破解
发表于 2017-1-11 19:58:54 | 显示全部楼层
要200多信元呀!!!
发表于 2017-1-11 19:59:36 | 显示全部楼层
回复 521# ztxxcm
   要200多信元呀!!!
发表于 2017-1-11 22:46:23 | 显示全部楼层
O(∩_∩)O谢谢楼主分享
发表于 2017-1-13 12:13:52 | 显示全部楼层
回复 1# yy641737606
楼主,首先感谢您的分享,经过一段时间终于下载完成了,但readme里的说明mac address( ZSKTBIWKFENBUPMP ), 怎么多了两组?俺尝试去掉后面两组,可是还是无法成;还有这个是需要联网安装还是断网安装?有安装成功的分享一下安装经验否?
另外提示一下,若是安装在Win32位OS下的友友们,注意第6步,中的文件路径正确如下:
6-run command prompt with admin privillage and run follow command:
“cd C:\Program Files\Antenna Magus Floating Licence Manager”
"secmagusd --install"
1-make sure you date and time sync.2-install Antenna magus 5.1.0
3-install Antenna magus LM(Antenna magus LM, Mac_address tool)
4-license
-In the license file you will see ''plasmon-canada" at the first line, which must be replaced with your pc's name.
-change your Machine code to "ZSKTBIWKFENBUPMP" by using the file(Mac_Address) which  has attached with the Antenna magus LM file(download from 2).
5-goto "C:\ProgramData\Antenna Magus Floating Licence Manager" and put your license file there.
"cd C:\Program Files (x86)\Antenna Magus Floating Licence Manager"
7-run antenna magus and click connect in activation window.
8-enjoy!
if you have done all of the steps correctly, you must see screenshot
发表于 2017-1-13 13:42:08 | 显示全部楼层
请问有成功安装的友友们吗?方便分享一下安装说明否?谢谢!
发表于 2017-1-13 13:56:32 | 显示全部楼层
要200多信元呀!!!
发表于 2017-1-13 13:57:44 | 显示全部楼层
回复 526# ztxxcm
   要200多信元呀!!!
发表于 2017-1-13 13:59:26 | 显示全部楼层
要200多信元呀!!!
发表于 2017-1-13 14:00:44 | 显示全部楼层
回复 528# ztxxcm
   要200多信元呀!!!
发表于 2017-1-13 14:01:28 | 显示全部楼层
要200多信元呀!!!
GMT+8, 2025-12-25 09:49 , Processed in 0.022308 second(s), 3 queries , Gzip On, Redis On.
