查看: 4257|回复: 1
[原创] linux svn hook pre-commit 防非管理员用户误删除操作
发表于 2015-11-4 13:52:53 | 显示全部楼层 |阅读模式
最近在配置svn hook 防止非管理员用户误删除操作,编写了以下脚本,友情提醒以下此脚本在pre-commit中使用;
#!/bin/sh
# PRE-COMMIT HOOK
# The pre-commit hook is invoked before a Subversion txn is
# committed.  Subversion runs this hook by invoking a program
# (script, executable, binary, etc.) named 'pre-commit' (for which
# this file is a template), with the following ordered arguments:
#   [1] REPOS-PATH   (the path to this repository)
#   [2] TXN-NAME     (the name of the txn about to be committed)
#   [STDIN] LOCK-TOKENS ** the lock tokens are passed via STDIN.
#   If STDIN contains the line "LOCK-TOKENS:\n" (the "\n" denotes a
#   single newline), the lines following it are the lock tokens for
#   this commit.  The end of the list is marked by a line containing
#   only a newline character.
#   Each lock token line consists of a URI-escaped path, followed
#   by the separator character '|', followed by the lock token string,
#   followed by a newline.
# The default working directory for the invocation is undefined, so
# the program should set one explicitly if it cares.
# If the hook program exits with success, the txn is committed; but
# if it exits with failure (non-zero), the txn is aborted, no commit
# takes place, and STDERR is returned to the client.   The hook
# program can use the 'svnlook' utility to help it examine the txn.
# On a Unix system, the normal procedure is to have 'pre-commit'
# invoke other programs to do the real work, though it may do the
# work itself too.
#   ***  NOTE: THE HOOK PROGRAM MUST NOT MODIFY THE TXN, EXCEPT  ***
#   ***  FOR REVISION PROPERTIES (like svn:log or svn:author).   ***
#   This is why we recommend using the read-only 'svnlook' utility.
#   In the future, Subversion may enforce the rule that pre-commit
#   hooks should not modify the versioned data in txns, or else come
#   up with a mechanism to make it safe to do so (by informing the
#   committing client of the changes).  However, right now neither
#   mechanism is implemented, so hook writers just have to be careful.
# Note that 'pre-commit' must be executable by the user(s) who will
# invoke it (typically the user httpd runs as), and that user must
# have filesystem-level permission to access the repository.
# On a Windows system, you should name the hook program
# 'pre-commit.bat' or 'pre-commit.exe',
# but the basic idea is the same.
# The hook program typically does not inherit the environment of
# its parent process.  For example, a common problem is for the
# PATH environment variable to not be set to its usual value, so
# that subprograms fail to launch unless invoked via absolute path.
# If you're having unexpected problems with a hook program, the
# culprit may be unusual (or missing) environment variables.
# Here is an example hook script, for a Unix /bin/sh interpreter.
# For more examples and pre-written hooks, see those in
# the Subversion repository at
# http://svn.apache.org/repos/asf/ ... tools/hook-scripts/ and
# http://svn.apache.org/repos/asf/ ... ntrib/hook-scripts/
REPOS="$1"
TXN="$2"
# Make sure that the log message contains some text.
SVNLOOK=/usr/bin/svnlook
USER=`svnlook author -t $TXN $REPOS`
SCMLIST="svnadmin"
OPT=`svnlook changed -t $TXN $REPOS`
if [ `echo $SCMLIST|grep -w $USER|wc -l` -eq 0 ]
then
    LOG=`$SVNLOOK log -t "$TXN" "$REPOS"`
    LOGMSG=`$SVNLOOK log -t "$TXN" "$REPOS" | grep "[a-zA-Z0-9]" | wc -c`
    if [ `$SVNLOOK log -t "$TXN" "$REPOS" | grep "[a-zA-Z0-9]" | wc -c` -eq 0 ]
    then
        echo -e "\n must input note and commit command" >&2
        exit 1
    fi
    if [ `$SVNLOOK changed -t $TXN $REPOS |grep "^D "|wc -l` -gt 0 ]
    then
        echo -e "\n You Don't have the pemmision of delete "  >&2
        echo -e "if you need delect file. please notice admin." >&2
        echo -e "if you recover file , please input svn revert file_name" >&2
        exit 1
    fi
fi
# Check that the author of this commit has the rights to perform
# the commit on the files and directories being modified.
#commit-access-control.pl "$REPOS" "$TXN" commit-access-control.cfg || exit 1
# All checks passed, so allow the commit.
exit 0
发表于 2015-11-7 10:34:52 | 显示全部楼层
赞一个~
GMT+8, 2025-12-23 20:40 , Processed in 0.022631 second(s), 5 queries , Gzip On, Redis On.
