查看: 4472|回复: 4
[求助] mdl文件中参数代表什么物理量?
发表于 2015-10-31 09:48:41 | 显示全部楼层 |阅读模式
这是smic .18工艺的mdl文件,请问其中哪个参数代表MOS的Kn?
  1. ************************************************************************************                              1.8V CORE NMOS MODEL                               ************************************************************************************.model n18 nmos+LEVEL    = 49                  ** GENERAL PARAMETERS*+CALCACM  = 1+LMIN     = 1.5E-7              LMAX     = 1.0E-5              WMIN     = 1.9E-7              +WMAX     = 1.0E-4              TNOM     = 25.0                VERSION  = 3.24                +TOX      = '3.87E-09+DTOX_N18' TOXM     = 3.87E-09            XJ       = 1.6000000E-07       +NCH      = 3.8694000E+17       LLN      = 1.1205959           LWN      = 0.9200000           +WLN      = 1.0599999           WWN      = 0.8768474           LINT     = 1.5757085E-08       +LL       = 2.6352781E-16       LW       = -2.2625584E-16      LWL      = -2.0576711E-22      +WINT     = -1.4450482E-09      WL       = -2.3664573E-16      WW       = -3.6409690E-14      +WWL      = -4.0000000E-21      MOBMOD   = 1                   BINUNIT  = 2                   +XL       = '1.8E-8+DXL_N18'    XW       = '0.00+DXW_N18'      DWG      = -5.9600000E-09      +DWB      = 4.5000000E-09         * DIODE PARAMETERS+ACM      = 12                  LDIF     = 7.00E-08            HDIF     = 2.00E-07            +RSH      = 7.08                RD       = 0                   RS       = 0                   +RSC      = 1.7                 RDC      = 1.7                 ** THRESHOLD VOLTAGE PARAMETERS*+VTH0     = '0.39+DVTH_N18'     WVTH0    = -2.9709472E-08      PVTH0    = '5.0000000E-16+DPVTH0_N18'       +K1       = 0.6801043           WK1      = -2.4896840E-08      PK1      = 1.3000000E-15       +K2       = -4.9977830E-02      K3       = 10.0000000          DVT0     = 1.3000000           +DVT1     = 0.5771635           DVT2     = -0.1717554          DVT0W    = 0.00                +DVT1W    = 0.00                DVT2W    = 0.00                NLX      = 7.5451030E-08       +W0       = 5.5820150E-07       K3B      = -3.0000000                 ** MOBILITY PARAMETERS*+VSAT     = 8.2500000E+04       PVSAT    = -8.3000000E-10      UA       = -1.0300000E-09      +LUA      = 7.7349790E-19       PUA      = -1.0000000E-24      UB       = 2.3666682E-18       +UC       = 1.2000000E-10       PUC      = 1.5000000E-24       RDSW     = 55.5497200          +PRWB     = -0.2400000          PRWG     = 0.4000000           WR       = 1.0000000           +U0       = 3.4000000E-02       LU0      = 2.3057663E-11       WU0      = -3.1009695E-09      +A0       = 0.8300000           KETA     = -3.0000000E-03      LKETA    = -1.7000000E-09      +A1       = 0.00                A2       = 0.9900000           AGS      = 0.3200000           +B0       = 6.0000000E-08       B1       = 0.00                ** SUBTHRESHOLD CURRENT PARAMETERS*+VOFF     = -0.1030000          LVOFF    = -3.3000000E-09      NFACTOR  = 1.2500000           +LNFACTOR = 4.5000000E-08       CIT      = 0.00                CDSC     = 0.00                +CDSCB    = 0.00                CDSCD    = 1.0000000E-04       ETA0     = 2.8000001E-02       +ETAB     = -2.7000001E-02      DSUB     = 0.4000000           ** ROUT PARAMETERS*+PCLM     = 1.2000000           PPCLM    = 2.9999999E-15       PDIBLC1  = 2.5000000E-02       +PDIBLC2  = 3.8000000E-03       PPDIBLC2 = 2.7000001E-16       PDIBLCB  = 0.00                +DROUT    = 0.5600000           PSCBE1   = 3.4500000E+08       PSCBE2   = 1.0000000E-06       +PVAG     = 0.00                DELTA    = 1.0000000E-02       ALPHA0   = 1.7753978E-08       +ALPHA1   = 0.1764000           LALPHA1  = 7.6250000E-09       BETA0    = 11.1683940  ** TEMPERATURE EFFECTS PARAMETERS*+KT1      = -0.2572866          KT2      = -4.0000000E-02      AT       = 3.7000000E+04       +PAT      = -7.5000000E-10      UTE      = -1.5500000          UA1      = 1.7600000E-09       +LUA1     = 6.0000000E-18       WUA1     = -1.1000000E-16      PUA1     = -5.0000000E-25      +UB1      = -2.4000000E-18      UC1      = -1.0000000E-10      LUC1     = 1.6999999E-17       +PUC1     = -3.0000000E-24      KT1L     = -1.0000000E-09      PRT      = -55.0000000       *    * NOISE PARAMETERS*+NOIMOD   = 2                   NOIA     = 8.2282E+19            NOIB     = 1.3327E+04    +NOIC     = -2.4937E-14         EM       = 1.7767E+07            EF       = 8.1800E-01 ** CAPACITANCE PARAMETERS*+CJ       = '9.68E-04+DCJ_N18'     MJ       = 0.346                PB       = 0.7                   +CJSW     = '7.95E-11+DCJSW_N18'   MJSW     = 0.538                PBSW     = 1                 +CJSWG    = '4.18E-10+DCJSWG_N18'  MJSWG    = 0.538                PBSWG    = 1+TCJ      = 8.42E-04               TCJSW    = 6.69E-04             TCJSWG   = 6.69E-04      +TPB      = 1.47E-03               TPBSW    = 8.68E-04             TPBSWG   = 8.68E-04+JS       = 3.52E-07               JSW      = 3.0E-13              NJ       = 1.0392 +XTI      = 3.25                   NQSMOD   = 0                    ELM      = 5+CGDO     = '3.70E-10+DCGDO_N18'   CGSO     = '3.70E-10+DCGSO_N18' TLEVC    = 1            +CAPMOD   = 3                      XPART    = 1                    CF       = 0.00                   +ACDE     = 0.64                   MOIN     = 24                   NOFF     = 1.2025                 +DLC      = 8.5E-09                DWC      = 4.5E-08
    复制代码
发表于 2015-11-1 01:21:55 | 显示全部楼层
kn=cox*un,需要自己算,建议自己参考BISM3V3手册,上面有介绍BISM3V3 model各参数的意义
回复 支持 0 反对 1
发表于 2015-11-1 01:28:30 | 显示全部楼层
cox只能根据tox来计算,书上的按照spice level1来讲的,计算机仿真现在主要用bsim3 或bsim4模型
发表于 2017-3-13 21:24:32 | 显示全部楼层
回复 2# lovekeduo
你好,请问你有你所说的BISM3V3手册吗?
发表于 2017-3-13 21:26:16 | 显示全部楼层
其实是BSIM……
GMT+8, 2025-10-22 07:30 , Processed in 0.021067 second(s), 5 queries , Gzip On, Redis On.
