查看: 3721|回复: 1
[求助] 请教一个upf问题
发表于 2015-10-17 22:55:33 | 显示全部楼层 |阅读模式
请教一个问题,谢谢了~!!
在ICC中,加入power switch之后,check_mv_design时报错。
Error: Supply net connection cannot be determined for power_pin TVDD on cell u_module1/headedfooter1_HDRSID0_R0_C1. (UPF-067)
Failure Reason: No parent power switch for switch cell instance
Error: Power net hookup for power domain is not specified properly. (MV-053)
发表于 2015-10-19 09:56:47 | 显示全部楼层
可能是upf里面 没指定好吧
GMT+8, 2025-12-23 12:32 , Processed in 0.016572 second(s), 5 queries , Gzip On, Redis On.
