楼主: wwm101
晶体振荡器启振
 楼主| 发表于 2007-6-14 15:40:20 | 显示全部楼层
模型有问题???
你们说模型有问题
请指教啊
至于C1C2接高压还是接地
其实在小信号模型下并没有实质上的不同啊
而且实际操作中我也基本上是把这两个接地!
“这个电路的基本原理是负电阻”
如果是其它问题还请指教
谢谢!
ps:文献我已经看了一大把了
发表于 2007-6-14 16:03:52 | 显示全部楼层
图片看不到!
如果电路没有问题,那可以在晶体模型的电容或电感上加初始值
 楼主| 发表于 2007-6-14 21:21:03 | 显示全部楼层
我有加初始值
加入初始值,是可以迅速启振
但是我碰到了是
振荡一段时间后
振荡波形迅速衰减。
发表于 2007-6-15 04:53:22 | 显示全部楼层
The problem is your feedback resistor. That resistance can neither be large nor be small. If it is too large, the operating point of inverter-amplifier will shift to GND. If it is too small, the resistor feedback loop will dominate. Thus, fine tune that resistor is a must.
In your case, the resistance is definitely small. You may use small W/L ratio for the feedback transistors. Good luck!
 楼主| 发表于 2007-6-15 10:24:57 | 显示全部楼层
原帖由 lianggu 于 2007-6-15 04:53 发表
The problem is your feedback resistor. That resistance can neither be large nor be small. If it is too large, the operating point of inverter-amplifier will shift to GND. If it is too small, the  ...
Thank you very much
can you tell how to confirm the min and max?
 楼主| 发表于 2007-6-15 11:14:06 | 显示全部楼层
thank you very much
can you tell how to confirm the min and mix feedback resistor?
thank you!
发表于 2007-6-15 13:34:15 | 显示全部楼层
First, make sure the inverting amplifier will NOT be outside amplifying region (become latch) as resistor goes high, R-max is found. Second, make sure the oscillation has no attenuation as resistor goes low, R-min is found.
You may pick up R-min<R<R-max. For CMOS, the first step may be ignored since input impedence of inverter is close to infinity.
By the way, if you have Cadence Spectre, I suggest to use it instead of Hspice. Spectre can make crystal oscillator to start up more easy and quickly.
 楼主| 发表于 2007-6-15 15:42:18 | 显示全部楼层
feedback res
原帖由 lianggu 于 2007-6-15 13:34 发表
First, make sure the inverting amplifier will NOT be outside amplifying region (become latch) as resistor goes high, R-max is found. Second, make sure the oscillation has no attenuation as resist ...
can you offer expample about how to confirm!
because i simulation a crystal osc as follow in pspice,but when i change the feedback res from 5.55meg to 5.7meg ,i find to have great effect .it can oscillate at 5.55meg ,but cann't oscillator when i change the feedback res.
that's why?
thank you
netlist
* source 100K
C_C4         N00619 N00563  1.72169576e-012
M_M1         N00563 N00619 N01138 0 nmos
+ L=16u
+ W=0.8u
+ M=10
M_M2         N00563 N00619 N01172 N01467 pmos
+ L=16u
+ W=0.8u
+ M=22
V_V1         N01467 0
+PWL 0 0 20u 3v 30u 0 40u 3v
R_R1         N01172 N01467  1000k
R_R3         N00619 N11450  18.5k
R_R2         0 N01138  1000k
C_C1         0 N00619  5p
C_C2         0 N00563  5p
L_L1         N11450 N03952  588.873289 IC=1uA
R_Rf         N00619 N00563  {r}
C_C3         N03952 N00563  4.30423941e-015
.PARAM  r=5.55meg
.model pmos pmos vto=-0.70 kp=50u gamma=0.57 lambda=0.05 phi=
+0.8 mj=0.5 mjsw=0.35 cgbo=700p cgso=220p cgdo=200p cj=
+560u cjsw=350p ld=0.014u tox=14n
.model nmos nmos vto=0.70 kp=110u gamma=0.4 lambda=0.04 phi=
+0.7 mj=0.5 mjsw=0.38 cgbo=700p cgso=220p cgdo=200p cj=
+770u cjsw=380p ld=0.016u tox=14n
发表于 2007-6-16 07:48:08 | 显示全部楼层
Why is there a 1Mohm resistor between sub and power? Why is the power stimulus applied through PSUB? Strange!
The simulation results match the analysis under different Rf condition, respectively, after removing those 2 resistor. (Refer to attachments)
Keep in mind that horn-shape waveform means correct results, just like waveform under 500M Rf condition.
cosc.rar
19.11 KB, 下载次数: 108 , 下载积分: 资产 -2 信元, 下载支出 2 信元
发表于 2007-6-16 07:49:20 | 显示全部楼层
Actually, you use 100kHz crystal, right?
GMT+8, 2025-12-30 23:33 , Processed in 0.020897 second(s), 6 queries , Gzip On, Redis On.
