查看: 2354|回复: 0
[求助] AMS mixed signal simulation problem
发表于 2015-9-28 16:03:45 | 显示全部楼层 |阅读模式
I tried to run AMS mixed signal simulation with "ams" simulator and "spectre" solver. The connectLib has been set to be right.
The netlist and run mode: I selected the "Cellview based netlister", not "OSS-based netlister with irun", because "Cellview based netlister can run "complie" successfully.
The model library had been set correctly.
But when I run simulation, elaberating failed with the following error report.
elaberating failed
elaberating failed
Does someone know the problem and how to solve this error.
Thanks.
GMT+8, 2025-12-26 07:14 , Processed in 0.015042 second(s), 6 queries , Gzip On, Redis On.
