查看: 8932|回复: 24
High-Performance RF Mixer and Operational Amplifier BiCMOS Circuits
发表于 2007-5-21 09:49:01 | 显示全部楼层 |阅读模式
High-Performance RF Mixer and Operational Amplifier BiCMOS Circuits Using Parasitic Vertical Bipolar Transistor in CMOS Technology
Abstract—The electrical characteristics of the parasitic vertical
NPN (V-NPN) BJT available in deep n-well 0.18- m CMOS
technology are presented. It has about 20 of current gain, 7 V
of collector-emitter breakdown voltage, 20 V of collector-base
breakdown voltage, 40 V of Early voltage, about 2 GHz of cutoff
frequency, and about 4 GHz of maximum oscillation frequency at
room temperature. The corner frequency of 1 noise is lower
than 4 kHz at 0.5 mA of collector current. The double-balanced
RF mixer using V-NPN shows almost free 1 noise as well as
an order of magnitude smaller dc offset compared with CMOS
circuit and 12 dB flat gain almost up to the cutoff frequency.
The V-NPN operational amplifier for baseband analog circuits
has higher voltage gain and better input noise and input offset
performance than the CMOS ones at the identical current. These
circuits using V-NPN provide the possibility of high-performance
direct conversion receiver implementation in CMOS technology.
Index Terms—BiCMOS, deep n-well CMOS, direct conversion
receiver, offset, operational amplifier, parasitic vertical bipolar
transistor, RF mixer, 1 noise.
[ 本帖最后由 lingzhi 于 2007-5-21 10:23 编辑 ]
abbr_796c8e9b4a54a808d8103fde96113489.pdf
1.5 MB, 下载次数: 164 , 下载积分: 资产 -2 信元, 下载支出 2 信元
 楼主| 发表于 2007-5-21 12:29:36 | 显示全部楼层
挺好的,为什么没人关注呢
发表于 2007-5-21 23:02:47 | 显示全部楼层
关键是不适用啊
没事谁去倒腾bicmos啊
发表于 2008-1-30 08:58:56 | 显示全部楼层
非常感谢!
发表于 2008-2-2 20:29:56 | 显示全部楼层
Thanks!
发表于 2008-4-2 19:15:33 | 显示全部楼层
bicmos工艺的不了解啊
发表于 2008-11-13 09:49:51 | 显示全部楼层
顶起来 !!!
发表于 2008-11-13 13:48:41 | 显示全部楼层
xie xie
发表于 2009-7-31 12:40:21 | 显示全部楼层
xie xie
发表于 2009-8-7 14:39:05 | 显示全部楼层
xiexie
GMT+8, 2025-12-22 16:23 , Processed in 0.024716 second(s), 8 queries , Gzip On, Redis On.
