查看: 5307|回复: 4
[求助] 用ic5141+csmc05时出现warning
发表于 2015-9-17 20:28:51 | 显示全部楼层 |阅读模式
*WARNING* You cannot redefine stipple "X" for display "display".
          It is a system reserved stipple name.
          Please rename stipple X to another name for display "display" in display.drf.
          and reassign the stipple of all packets which use stipple X to the new named stipple for display "display".
*WARNING* You cannot redefine stipple "X" for display "psb".
          Please rename stipple X to another name for display "psb" in display.drf.
          and reassign the stipple of all packets which use stipple X to the new named stipple for display "psb".
*WARNING* (reader): suspicious newline found after the operator .
SYNTAX ERROR found at line 1 column 113 of file *ciwInPort*
*Error* lineread/read: syntax error encountered in input
这是出现的警告  库可以正常打开  这错误可以忽略么 求助各位大神
发表于 2019-10-18 19:04:26 | 显示全部楼层
请问一下后来怎么解决的呢?
发表于 2022-1-10 09:17:36 | 显示全部楼层
解决了吗
发表于 2022-2-15 14:47:45 | 显示全部楼层
请问您是如何解决的呢
发表于 2023-5-19 17:27:25 | 显示全部楼层
有人知道怎么解决没
GMT+8, 2025-12-23 22:31 , Processed in 0.017651 second(s), 5 queries , Gzip On, Redis On.
