查看: 2565|回复: 2
[求助] ic5141安装问题
发表于 2015-9-6 15:11:43 | 显示全部楼层 |阅读模式
CadenceIC5141的安装:
进入usr5的解压包的CDROM1
cd /home/install/ic5141usr5/CDROM1
./SETUP.SH  (运行安装文件)
在“Specify path of install directory \c
[OR type [RETURN] to exit]: \c”的提示下输入安装目录:/home /cadence/5141/ic5141
在“Do you want o start softload? [y/n]: \c”的提示下输入
y
显示的信息如下,根据下面的说明进行安装。
Warning: Software administration should not be done as root because it could cause file permissions problems while extracting software
Press [Return] to proceed, q to quit : (return)
本来应该在点击return之后,会出现下一步的,如下图:
-------------------MAIN MENU----------------------
The available options are:
1) Load Available Products
2) List Installed Products
3) Remove Installed Products
4) (unavailable option) Configure Installed Products
5) (unavailable option) Test Installed Products
6) Update Installed Products
h) Help
q) Quit
Type your choice: [ 1 ]1
但是一直出现不了,不知道是为什么,求大神解答
发表于 2017-10-22 00:13:12 | 显示全部楼层
顶顶l顶顶顶l顶顶顶l顶
发表于 2017-10-22 12:21:46 | 显示全部楼层
现在都用IC617了,下载和安装帖子如下:
http://bbs.eetop.cn/viewthread.php?from=notice&tid=662814
GMT+8, 2025-12-19 00:32 , Processed in 0.015218 second(s), 4 queries , Gzip On, Redis On.
