楼主: xykix325
[WIN] HSPICE J-2014 + License + Installation guide
发表于 2015-11-2 22:13:19 | 显示全部楼层
初学者,慢慢学习中。感谢楼主分享
发表于 2015-11-3 09:14:17 | 显示全部楼层
谢谢楼主分享
发表于 2015-11-4 17:53:45 | 显示全部楼层
thnx!
发表于 2015-11-6 16:53:37 | 显示全部楼层
回复 27# xykix325
   Thank you! thank you! thank you!I really appreciate your help
发表于 2015-11-8 21:13:00 | 显示全部楼层
回复 1# xykix325
   Hi,
First of all thank you for the upload
Secondly, I have installed it on Windows 10 (64-bit) platform (in fact I tried installing it thrice.) And all the time I have failed to get HPSICE-J-2014 up and running. By 'Up and running' I mean to run an actual simulation. Whenever I try to run the simulation (a BSIM4 MOSFET Cell) I get a license error and the application 'HSPICE.EXE' quits.
Then on the second install I noticed that during the cracking process I am not getting the output as mentioned in your install note. Some features are garbled is the message that I get. I don't know why. I have installed and tested it twice with my antivirus switched off (both Kaspersky and Windows Defender). Despite this HSPICE J-2014 is giving me problems.
Is there any remedy for this? If there is kindly do share it, it would be of great help to me. The reason being that I have switched back to HSPICE 2008.09 version as of now and it doesn't support the FinFET BSIM-CMG models. In fact I was trying to change the MOSFET models to FinFET models.
Your valuable time is greatly appreciated. Have a nice day
Thank you.
发表于 2015-11-11 03:33:37 | 显示全部楼层
I did everything as described in the manual several times. I am having following error in Windows 10,  64bit
Checking the integrity of the license file...
(snpslmd) The SSS features are garbled.
All revenue keys ("SN=RK:..." on feature line) have been excluded.
Can anybody help?
发表于 2015-11-14 20:28:36 | 显示全部楼层
没有信元!!
发表于 2015-11-15 00:18:19 | 显示全部楼层
Is it available for linux?
发表于 2015-11-16 10:28:37 | 显示全部楼层
謝謝分享
发表于 2015-11-16 11:00:13 | 显示全部楼层
谢谢~~~~~~~~~~~
GMT+8, 2025-12-17 00:15 , Processed in 0.021732 second(s), 5 queries , Gzip On, Redis On.
