楼主: xykix325
[WIN] HSPICE J-2014 + License + Installation guide
发表于 2015-11-16 21:33:20 | 显示全部楼层
回复 86# lopolo2
   Hi,
@lopola2: Even I had the same problem. You first uninstall all the HSPICE 2014 files from your system and reboot. On rebooting stop or quit all your antivirus or security programs including Windows Defender. After doing this install the files on to your system AND do not restart your system after installation. The final stage will say that some of the inputs are garbled and excluding and so on; just ignore this, and Dont run the LMTOOLS.EXE at this time. Just restart the system.  After restarting run the LMTOOLS stuff and do the rest as in the instruction, and go on to add the environment variable LM_License_file and point it to 27000@<your-pc-name>. It should work. Just try out a sample spice deck sim and see for yourself.
I have made this version of HSpice work on my Windows 10 64-bit PC like this. I had downloaded this a few weeks back but couldn't make this work somehow, but I finally cracked it last thursday :-)
Thank you.
发表于 2015-11-16 21:33:56 | 显示全部楼层
回复 86# lopolo2
   Hi,
Thank you.
发表于 2015-11-16 22:18:14 | 显示全部楼层
You have done a great job!
发表于 2015-11-16 23:39:23 | 显示全部楼层
Well done
发表于 2015-11-20 00:22:39 | 显示全部楼层
总算找到license啦,多谢
发表于 2015-11-22 13:54:19 | 显示全部楼层
Reply 95 # lishuomountain
    Hi,i am attaching the license file for the 2013_03 version also. This license will allow you to use CustomWaveView and CustomExplorer along with your HSPICE-J-2014 installation. You only have to add it to your license environment variable!
Enjoy
The (Additional) license file: [Attach] 638668 [/ attach]
Synopsys_H2013_03_SP2 -License file.zip
19.12 KB, 下载次数: 59 , 下载积分: 资产 -2 信元, 下载支出 2 信元
For use with HSP-J-2014
发表于 2015-11-22 14:06:50 | 显示全部楼层
   Do a search for waveview or related to find the corresponding thread. Once you download and install it, you can use it with the above license file.  Also both HSPICE 2013 and 2014 works fine with Custom WaveView/Explorer. And yes dont forget to add the path to waveview (SX.EXE) in the hspice config file. Enjoy
发表于 2015-11-22 18:27:08 | 显示全部楼层
为什么解压不成功呢?
发表于 2015-11-22 18:28:37 | 显示全部楼层
我全部都下载下来了,放在同一个文件夹里,请问有人知道为什么吗?
发表于 2015-11-22 18:29:56 | 显示全部楼层
回复 4# xykix325
楼主,您好,请问为什么我解压没成功呢?我全部都下载了,谢谢!
GMT+8, 2025-12-17 00:15 , Processed in 0.021300 second(s), 4 queries , Gzip On, Redis On.
