查看: 5006|回复: 0
[求助] ic616 + mmsim 配置问题
发表于 2015-8-28 19:39:08 | 显示全部楼层 |阅读模式
大家好,我刚刚安装了ic设计环境,安装在了rhel 6.5中,原理图版图设计可以使用,就是在版图设计里面,仿真功能用不了,提示如下:
Netlisting Statistics:
Number of components:    3
Elapsed time:          1.0s (3.00/s)
Errors: 0        Warnings: 0
...successful.
compose simulator input file
Loading devCheck.cxt
...successful.
start simulator if needed...
...successful.
Loading paraplot.cxt
ERROR (ADE-3036): Errors encountered during simulation.
The simulator run log has not been generated.
Possible cause could be an invalid command line option for the version of the simulator
you are running.
Choose Setup->Environment and verify that the command line options
specified in the userCmdLineOption field are supported for the simulator.
Alternatively, run the simulator standalone using the runSimulation file in the netlist
directory to know the exact cause of the error.
我在 Setup->Environment中已经选择了64位运行。我的环境配置脚本文件内容如下:
# .bashrc
if [ -f /etc/bashrc ]; then
         . /etc/bashrc
fi
echo "set env ..."
export CADHOME=/opt/cadence
export OA_HOME=/opt/cadence/IC616/oa_v22.43.018
export LM_LICENSE_FILE=/opt/cadence/license.dat
export LANG=C
export CDS=$CADHOME/IC616
export CDSDIR=$CDS
export CDSHOME=$CDS
export CADENCE_DIR=$CDS
export CDS_INST_DIR=$CDS
export SPECTRE_DEFAULTS=-E
export CDS_Netlisting_Mode=Analogexport CDS_SPECTRERF_FBENABLE=1
export CDS_AUTO_64BIT=ALL
export PATH=$CDSDIR/binCDSDIR/tools/dfII/binCDSDIR/tools/binCDSDIR/tools/plot/bin:$PATH
export ASSURAHOME=$CADHOME/ASSURA41
export PATH=$PATH:$ASSURAHOME/bin:$ASSURAHOME/tools/bin:$ASSURAHOME/tools/assura/bin
export QRC_HOME=$CADHOME/EXT132
export PATH=$QRC_HOME/bin:$QRC_HOME/tools/bin:$PATH
export MMSIMHOME=$CADHOME/MMSIM13
export PATH=$MMSIMHOME/bin:$MMSIMHOME/tools/bin:$PATH
export PATH=$CADHOME/EDI132/bin:$CADHOME/EDI132/tools/bin:$PATH
export PATH=$CADHOME/CONFRML131/bin:$CADHOME/CONFRML131/tools/bin:$PATH
export PATH=$CADHOME/INCISIV132/bin:$CADHOME/INCISIV132/tools/bin:$PATH
export PATH=$PATH:$CADHOME/IC616/bin
export OA_HOME=$CDSDIR/oa_v22.43.040
export OA_UNSUPPORTED_PLAT="linux_rhel50_gcc44x"
export CDS_LOAD_ENV=CWDElseHome
export CDK_DIR=/opt/PDKs/ncsu-cdk-1.6.0.beta
export MOZILLA_HOME=/usr/bin/firefox
export CALIBRE_HOME=/opt/mentor/Calibre2013/ixl_cal_2013.3_39.24
export MGLS_LICENSE_FILE=4688@liht.localdomain
export PATH=$CALIBRE_HOME/bin:${PATH}
export CALIBRE_OS_MSG_LEVEL=2
hostname liht
which virtuoso
echo "set env ends."
/etc/hosts文件内容:
#文件内容
127.0.0.1   localhost localhost.localdomain localhost4 localhost4.localdomain4
::1
             localhost localhost.localdomain localhost6 localhost6.localdomain6
127.0.0.1   lihongtao lihongtao
附件是我的工作路径,在库管理里面tutorial_1是我建的库,仿真没有试成功。
CMOSedu.rar (37.68 KB , 下载次数: 8 )
GMT+8, 2025-10-9 05:49 , Processed in 0.044339 second(s), 8 queries , Gzip On, Redis On.
