查看: 1941|回复: 0
[招聘] 【实习】AMD上海招聘Validation Intern
发表于 2015-8-21 13:39:11 | 显示全部楼层 |阅读模式
Job Location: ShanghaiJOB DESCRIPTION1.Execute tests (functional stress) on AMD APU/GPU projects with internal and external applications & tools under different OSes.2.Track test status correctly and finish test report in time.3.Write correct issue report independently.4.Work with validation engineer / debug engineer to find failure root cause.5.Attend meetings periodically and provide weekly report to leaders.6.Other duties as assigned by team leader7.Demonstrates discipline in execution of tasks and flexibility/adaptability 8. frequent changes.REQUIREMENT1.Can work at least 4 days a week and last for at least 6 months2.Knowledge of PC products (CPU, graphic card, motherboard) and peripherals (DIMM, Hard Disk, Monitor, SD, SATA, USB….)3.Understand discrete Graphic Card and x86 architecture. 4.Familiar with Windows OSes. Experience in system management will be a plus.Experience of Linux is a plus. 5.Willing to perform shift hours when required.6.Good team worker and willing to work overtime and work under pressure.7.Good solder skill and hardware test background(e.g. experience on operating scope) is a plus8.CET-4. CET-6 will be a plus.实习要求每周4天,不少于6个月,符合条件的同学请将简历以附件形式发送至berlin.luo@amd.commaggie1.zhang@amd.com以及Ryan.Kong@amd.com 邮件主题标明姓名-年级-学校-实习时长-应聘岗位,谢谢。
GMT+8, 2025-12-20 11:13 , Processed in 0.012575 second(s), 5 queries , Gzip On, Redis On.
