查看: 2635|回复: 4
[求助] preroute
发表于 2015-8-13 11:30:32 | 显示全部楼层 |阅读模式
假如两个macro cell之间有nets连接,我希望在floorplan阶段把他们以最短的路径连接上,不需要考虑timing,只是单纯的金属线连上就行,应该怎么做??
发表于 2015-8-13 17:45:35 | 显示全部楼层
手拉  或者route_zrt_group
 楼主| 发表于 2015-8-14 09:18:45 | 显示全部楼层
回复 2# icfbicfb
    版主,还有一个问题,我用create_zrt_shield做出来的shield是一条一条的,有什么办法可以做一整片覆盖的吗?
发表于 2015-8-14 14:36:13 | 显示全部楼层
icc_shell> create_zrt_shield -help
Usage: create_zrt_shield    # auto shield routing
        [-mode new | unshield | reshield]
                               (mode to create new shield, or unshield, or reshield specified nets; (default new))
        [-with_ground net_name]
                               (shield nets with specific P/G net; (default is ground net))
        [-nets {collection_of_nets}]
                               (list of nets to shield; (default is nets with shielding rules are only shielded))
        [-ignore_shielding_net_pins (false|true)]
                               (don't create tie-off connection to P/G pins of cells; (default false))
        [-ignore_shielding_net_rails (false|true)]
                               (don't create tie-off connection to standard cell rails; (default false))
        [-coaxial_below (false|true)]
                               (create coaxial shielding below the shielded segment layer; (default false))
        [-coaxial_above (false|true)]
                               (create coaxial shielding above the shielded segment layer; (default false))
自己研究吧,可能可以的
发表于 2015-8-17 21:59:42 | 显示全部楼层
这种连线可以放到route阶段再连,route的时候一开始就先连这些线好了。
floorplan阶段就有signal连线可能会对后续的place cts有影响
GMT+8, 2025-11-2 12:41 , Processed in 0.020872 second(s), 6 queries , Gzip On, Redis On.
