查看: 26829|回复: 82
IEEE fellow 系列之二 Phillip E.Allen
发表于 2007-5-13 17:29:00 | 显示全部楼层 |阅读模式
将自己多年来收藏的几个IEEE fellow发表过或指导的论文打包,供大家下载。绝对超值!
各压缩包中的论文给出了列表,论文名字后面的数字是该论文发表的时间和页数。
IEEE fellow 系列之一 Phillip E.Allen
压缩包1:
70 MHz CMOS gm-C IF filter 2005 4
101 ways to make a circuit fail 1994  6
A 1 GHz, low-phase-noise CMOS frequency synthesizer with integrated LC VCO for wireless communications 1998
A 1.1-V current-mode and piecewise-linear curvature-corrected bandgap reference 1998
A 1.5 V four-quadrant analog multiplier 1994
Allen, P.E1.rar
1.65 MB, 下载次数: 228 , 下载积分: 资产 -2 信元, 下载支出 2 信元
 楼主| 发表于 2007-5-13 17:32:33 | 显示全部楼层
压缩包2:
A 1.5V multirate multibit sigma delta modulator for GSM_WCDMA in a 90 nm digital CMOS process 2005 4
A 1.9GHz image-reject front-end with automatic tuning in a 0.15_spl mu_m CMOS technology 2003
A 7-MHz process, temperature and supply compensated clock oscillator in 0.25 _spl mu_m CMOS 2003
A behavioral model of an analog voltage comparator 1989
A delta-modulated analog-to-digital conversion technique for digital microsensors 1994
Allen, P.E2.rar
1.77 MB, 下载次数: 209 , 下载积分: 资产 -2 信元, 下载支出 2 信元
 楼主| 发表于 2007-5-13 17:35:09 | 显示全部楼层
压缩包3:
A design of a low-power, high-accuracy, and constant-Q-tuning continuous-time bandpass filter 2002
A fast switching PLL frequency synthesizer with an on-chip passive discrete-time loop filter in 0.25-_spl mu_m
CMOS 2003 10
A high-efficiency multistage Doherty power amplifier for WCDMA 2003
A highly accurate step-response-based successive-approximation frequency tuning scheme for high-Q continuous-
time bandpass filters 2003
A low-voltage CMOS op amp with rail-to-rail constant-gm input stage and high-gain output stage  1995
Allen, P.E3.rar
1.8 MB, 下载次数: 200 , 下载积分: 资产 -2 信元, 下载支出 2 信元
 楼主| 发表于 2007-5-13 17:36:37 | 显示全部楼层
压缩包4:
A low-voltage, bulk-driven MOSFET current mirror for CMOS technology 1995 4
A new analytical scalable substrate network model for RF MOSFETs 2004
A new fourth-order single-loop delta-sigma modulator for audio applications 1996
A non-iterative DC analysis program for analog circuits 1991 4
A one-volt, 120-μW, 1-MHz OTA for standard CMOS technology 1996
Allen, P.E4.rar
1.49 MB, 下载次数: 166 , 下载积分: 资产 -2 信元, 下载支出 2 信元
 楼主| 发表于 2007-5-13 17:41:38 | 显示全部楼层
压缩包5:
A process, voltage, and temperature compensated CMOS constant current reference 2004
A rule-based DC analysis program for analog integrated circuits 1992
A table look-up MOSFET model for analog applications 1988
Accurate two-transistor current mirrors 1994 4
Analog circuit layout with optimized performance 1989
Allen, P.E5.rar
1.53 MB, 下载次数: 179 , 下载积分: 资产 -2 信元, 下载支出 2 信元
 楼主| 发表于 2007-5-13 17:43:32 | 显示全部楼层
压缩包6:
Analysis and design of a high-efficiency multistage Doherty power amplifier for WCDMA 2003
Analysis and design of a high-efficiency multistage Doherty power amplifier for wireless communications 2005 9
Behavioral simulation of a 3-bit flash ADC 1990
CMOS high-linear wide-dynamic range RF on-chip filters using Q-enhanced LC filters 2005
CMOS integrated transformer-feedback Q-enhanced LC bandpass filter for wireless receivers 2004
Allen, P.E6.rar
1.68 MB, 下载次数: 153 , 下载积分: 资产 -2 信元, 下载支出 2 信元
 楼主| 发表于 2007-5-13 17:46:04 | 显示全部楼层
压缩包7:
Comments on “Designing 1-V op-amps using standard digital CMOS technology” and reply 1999
Comparison of mixed analog-digital simulators 1990
Current state of the art in nontraditional analog circuit simulation 1992
Design considerations for a GaAs pipelined A_D converter 1991
Design considerations in bandgap references over process variations 2005
Allen, P.E7.rar
1.28 MB, 下载次数: 171 , 下载积分: 资产 -2 信元, 下载支出 2 信元
 楼主| 发表于 2007-5-13 17:47:35 | 显示全部楼层
压缩包8:
Design issues in GaAs oversampled A_D converters 1991 4
Graphical analysis of matched transistor current sinks_sources 1974
High dynamic range CMOS filter 2005
LC notch filter for image-reject applications using on-chip inductors 2001
Linear RF CMOS power amplifier with improved efficiency and linearity in wide power levels 2005
Allen, P.E8.rar
2.02 MB, 下载次数: 160 , 下载积分: 资产 -2 信元, 下载支出 2 信元
 楼主| 发表于 2007-5-13 17:50:04 | 显示全部楼层
压缩包9:
Low-power, low-phase-noise CMOS voltage-controlled-oscillator with integrated LC resonator 1998
Low-voltage analog IC design in CMOS technology 1995
Low-voltage CMOS transconductance cell based on parallel operation of triode and saturation transconductors 1994
Low-voltage, four-quadrant, analogue CMOS multiplier 1994
Low-voltage, supply independent CMOS bias circuit 2002
Allen, P.E9.rar
1.25 MB, 下载次数: 146 , 下载积分: 资产 -2 信元, 下载支出 2 信元
 楼主| 发表于 2007-5-13 17:52:14 | 显示全部楼层
压缩包10:
Operational amplifiers and linear integrated circuits 1983
PC-based interactive computational server for educational purposes 1992
Performance driven analog layout compiler 1990
SiGe HBT power amplifier for IS-95 CDMA using a novel process, voltage, and temperature insensitive biasing
scheme 2003
Single-loop delta-sigma modulator with swing suppression 1995
Allen, P.E10.rar
1.56 MB, 下载次数: 180 , 下载积分: 资产 -2 信元, 下载支出 2 信元
GMT+8, 2025-12-23 17:45 , Processed in 0.037172 second(s), 6 queries , Gzip On, Redis On.
